01-20-2017, 21:08 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | LG H791 screen or bootloader lock help I do bootloader unlock but I can't what model should i put the phone on it? Code: -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM268 Selected model: H791 Reading info... Model ID: LGH791 IMEI: 353627-07-391030-2 Android version: Battery level: 100% Mode: Emergency Initializing flash...OK SW version: LGH791AT-00-V10f-NXS-XXX-OCT-03-2015-16G-MDA89E- US LAF Version: 1.2 Product ID: YE05S151026000538 IMEI: 353627-07-391030-2 Target operator: GOOGLE Hardware: Performed by 2.4.0 software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM268 Selected model: H791 Reading info... Model ID: LGH791 IMEI: 353627-07-391030-2 Android version: Battery level: 100% Mode: Emergency Initializing flash...OK SW version: LGH791AT-00-V10f-NXS-XXX-OCT-03-2015-16G-MDA89E- US LAF Version: 1.2 Product ID: YE05S151026000538 IMEI: 353627-07-391030-2 Target operator: GOOGLE Hardware: This operation is not supported in emergency mode! Performed by 2.4.0 software version. |
01-20-2017, 22:10 | #2 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | I try Reset FRP Lock and phone freeze on google logo loading Code: Welcome to Octoplus/Octopus Box LG Software version 2.4.7 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM18 Selected model: H791 Please, put the phone into download mode manually (Power phone OFF, press and hold "Vol+" button and connect the cable). Reading info... Model ID: LGH791 IMEI: 353627-07-391030-2 Android version: Battery level: 97% SW Version: LGH791AT-00-V10f-NXS-XXX-OCT-0 Mode: Emergency Initializing flash...OK SW version: LGH791AT-00-V10f-NXS-XXX-OCT-03-2015-16G-MDA89E- US Android version: 6.0 LAF Version: 1.2 Product ID: YE05S151026000538 IMEI: 353627-07-391030-2 Target operator: GOOGLE Hardware: Reading partitions...OK Resetting FRP Lock...OK Resetting screen lock successfully completed! Performed by 2.4.7 Software version. I am downloading now flash file to flash LGH791AT-00-V10n-NXS-XXX-Nov.... |
01-21-2017, 09:34 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Currently we don't have such firmware. If we manage to find it - file will be available in the Support Area. |
03-14-2017, 22:09 | #10 (permalink) | |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Quote:
Code: -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM13 Selected model: H791 Reading info... Model ID: LGH791 IMEI: 353627-07-391030-2 Android version: Battery level: 40% SW Version: LGH791AT-00-V10f-NXS-XXX-OCT-0 Mode: Emergency Initializing flash...OK SW version: LGH791AT-00-V10f-NXS-XXX-OCT-03-2015-16G-MDA89E- US Android version: 6.0 LAF Version: 1.2 Product ID: YE05S151026000538 IMEI: 353627-07-391030-2 Target operator: GOOGLE Hardware: Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! Opening "LGH791AT-00-V10n-NXS-XXX-NOV-23-2015-32G- FACTORY.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Writing PrimaryGPT...OK Writing modem...OK Writing pmic...OK Writing sbl1...OK Writing tz...OK Writing sdi...OK Writing hyp...OK Writing rpm...OK Writing aboot...OK Writing sbl1bak...OK Writing pmicbak...OK Writing tzbak...OK Writing hypbak...OK Writing rpmbak...OK Writing abootbak...OK Writing sec...OK Writing persist...OK Writing imgdata...OK Writing laf...OK Writing keymaster...OK Writing cmnlib...OK Writing keymasterbak...OK Writing cmnlibbak...OK Writing oem...OK Writing boot...OK Writing recovery...OK Writing vendor...OK Writing cache...OK Writing system...OK Writing userdata...OK Writing BackupGPT...OK Reading partitions...OK Formating RCT...Failed! Formating MPT...Failed! Finalizing...OK Writing firmware done! Performed by 2.4.7 Software version. the phone restart the freeze on "WARNING.. Not Support QEM = 0" | |
03-17-2017, 08:46 | #13 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Now try to re-flash your device using "Nexus Root Toolkit, You can download stock firmware through that Software. |
03-28-2017, 02:38 | #14 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | I keep try to flash when phone reboot doen't goes to normal to enable debug so can you help what steps because I try but not help for me Code: Nexus Root Toolkit v2.1.9 Masterlists: - LatestToolkitFiles.ini 3150 - AndroidDeviceListFull.ini 3150 - AndroidDeviceListFlash.ini 3150 BULLHEAD-BULLHEAD: Android 7.1.1 - Build: NMF26F Live log initiated [2017-03-28]: Checking ADB/FASTBOOT Connectivity adb devices * daemon not running. starting it now on port 5037 * * daemon started successfully * fastboot devices 00e950c7d9b9d10c fastboot Refreshing adb server... adb devices + Fastboot Device Connected + Bootloader Status: Locked. adb devices fastboot devices 00e950c7d9b9d10c fastboot Checking bootloader unlock ability: + OEM Unlocking Disabled Checking ADB/FASTBOOT Connectivity adb devices fastboot devices 00e950c7d9b9d10c fastboot + Fastboot Device Connected Rebooting your device... Waiting for your device... Device Detected Checking ADB/FASTBOOT Connectivity adb devices fastboot devices Checking ADB/FASTBOOT Connectivity adb devices fastboot devices 00e950c7d9b9d10c fastboot + Fastboot Device Connected + Bootloader Status: Locked. adb devices fastboot devices 00e950c7d9b9d10c fastboot Checking bootloader unlock ability: + OEM Unlocking Disabled Checking ADB/FASTBOOT Connectivity adb devices fastboot devices 00e950c7d9b9d10c fastboot + Fastboot Device Connected Rebooting your device... Waiting for your device... Device Detected Checking ADB/FASTBOOT Connectivity adb devices fastboot devices Checking ADB/FASTBOOT Connectivity adb devices fastboot devices Checking ADB/FASTBOOT Connectivity adb devices fastboot devices 00e950c7d9b9d10c fastboot + Fastboot Device Connected + Bootloader Status: Locked. Attempting to automatically enable this feature adb shell input keyevent 7 adb shell input keyevent 7 adb shell input keyevent 7 adb shell input keyevent 7 Checking ADB/FASTBOOT Connectivity adb devices fastboot devices 00e950c7d9b9d10c fastboot + Fastboot Device Connected Rebooting your device... Waiting for your device... Device Detected Checking OEM Unlockable Status: + Status: Disabled Copied to clipboard. Checking ADB/FASTBOOT Connectivity adb devices fastboot devices Checking ADB/FASTBOOT Connectivity adb devices fastboot devices 00e950c7d9b9d10c fastboot + Fastboot Device Connected + Bootloader Status: Locked. adb devices fastboot devices 00e950c7d9b9d10c fastboot Checking bootloader unlock ability: + OEM Unlocking Disabled Checking ADB/FASTBOOT Connectivity adb devices fastboot devices 00e950c7d9b9d10c fastboot + Fastboot Device Connected Rebooting your device... Waiting for your device... Device Detected Checking ADB/FASTBOOT Connectivity adb devices fastboot devices #### Procedure Cancelled #### Attempting to automatically enable this feature + OEM Unlocking Canceled adb devices fastboot devices adb devices fastboot devices 00e950c7d9b9d10c fastboot Checking bootloader unlock ability: + OEM Unlocking Disabled Checking ADB/FASTBOOT Connectivity adb devices fastboot devices 00e950c7d9b9d10c fastboot + Fastboot Device Connected Rebooting your device... Waiting for your device... Device Detected Attempting to automatically enable this feature + OEM Unlocking Canceled adb devices fastboot devices adb devices fastboot devices 00e950c7d9b9d10c fastboot |
03-28-2017, 08:15 | #15 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to re-flash the device with V10f firmware from the Support Area. Post here full Software log. Last edited by Octopus box; 03-28-2017 at 08:28. |
