Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus LG/Octoplus LG
Old 01-20-2017, 21:08   #1 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
LG H791 screen or bootloader lock help
When power up the phone after google logo loading its ask for pin I am not sure that a bootloader lock that I already do factory reset.
I do bootloader unlock but I can't what model should i put the phone on it?
Platform: LG Qualcomm
Selected port: COM268
Selected model: H791
Reading info...
Model ID: LGH791
IMEI: 353627-07-391030-2
Android version:
Battery level: 100%
Mode: Emergency
Initializing flash...OK
SW version: LGH791AT-00-V10f-NXS-XXX-OCT-03-2015-16G-MDA89E-
US
LAF Version: 1.2
Product ID: YE05S151026000538
Target operator: GOOGLE
Hardware:
Performed by 2.4.0 software version.
Checking data...OK
Reading info...
Model ID: LGH791
Android version:
Battery level: 100%
Mode: Emergency
US
LAF Version: 1.2
Hardware:
This operation is not supported in emergency mode!
Old 01-20-2017, 22:10   #2 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
I try Reset FRP Lock and phone freeze on google logo loading
Welcome to Octoplus/Octopus Box LG Software version 2.4.7
Checking data...OK
Selected port: COM18
Please, put the phone into download mode manually (Power phone OFF,
press and hold "Vol+" button and connect the cable).
Reading info...
Model ID: LGH791
Android version:
Battery level: 97%
SW Version: LGH791AT-00-V10f-NXS-XXX-OCT-0
Mode: Emergency
US
Android version: 6.0
LAF Version: 1.2
Hardware:
Reading partitions...OK
Resetting FRP Lock...OK
Resetting screen lock successfully completed!
Performed by 2.4.7 Software version.
I am downloading now flash file to flash LGH791AT-00-V10n-NXS-XXX-Nov....
Old 01-20-2017, 22:35   #3 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
request this file add to support please
"LGH791AT-00-V10f-NXS-XXX-OCT-03-2015-16G-MDA89E-
US"
Old 01-21-2017, 09:34   #4 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,413
Hello.
Currently we don't have such firmware. If we manage to find it - file will be available in the Support Area.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 03-14-2017, 00:32   #5 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
I still waiting to flash phone back to normal
Old 03-14-2017, 00:46   #6 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
Medusa box can solve my problems?
Old 03-14-2017, 09:48   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
Unfortunately, this phone model is not supported at the moment.
Old 03-14-2017, 12:45   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
Try to reflash the phone with firmware from the Support Area, after post here full Software log.
Old 03-14-2017, 22:01   #9 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
true that not support I check it
Old 03-14-2017, 22:09   #10 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
Checking data...OK
Selected port: COM13
Reading info...
Model ID: LGH791
Android version:
Battery level: 40%
Mode: Emergency
US
LAF Version: 1.2
Hardware:
Writing phone firmware without real necessity is at your own risk.
Downgrade may lead to phone damage!
Please, make sure the phone's battery is fully charged.
Disconnect all other devices from the computer (including phones,
modems, etc.) and close all other running programs.
To avoid errors in the flashing process, use a clean PC (without any
installed drivers for other Qualcomm-based devices).
You should not run any other programs or attach new devices to your
computer during the flashing!
Opening "LGH791AT-00-V10n-NXS-XXX-NOV-23-2015-32G-
FACTORY.oct"...OK
Setting options...OK
Formating USERDATA...OK
Writing PrimaryGPT...OK
Writing modem...OK
Writing pmic...OK
Writing sbl1...OK
Writing tz...OK
Writing sdi...OK
Writing hyp...OK
Writing rpm...OK
Writing aboot...OK
Writing sbl1bak...OK
Writing pmicbak...OK
Writing tzbak...OK
Writing hypbak...OK
Writing rpmbak...OK
Writing abootbak...OK
Writing sec...OK
Writing persist...OK
Writing imgdata...OK
Writing laf...OK
Writing keymaster...OK
Writing cmnlib...OK
Writing keymasterbak...OK
Writing cmnlibbak...OK
Writing oem...OK
Writing boot...OK
Writing recovery...OK
Writing vendor...OK
Writing cache...OK
Writing system...OK
Writing userdata...OK
Writing BackupGPT...OK
Formating RCT...Failed!
Formating MPT...Failed!
Finalizing...OK
Writing firmware done!
Its display that phone has been programme with different operations
the phone restart the freeze on "WARNING.. Not Support QEM = 0"
Old 03-15-2017, 08:54   #11 (permalink)
Member: 1146942
Sonork: 100.1587278
Now try to re-flash your device using "Nexus Root Toolkit".
Old 03-16-2017, 22:53   #12 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
how can I flash with .oct flash file?
Old 03-17-2017, 08:46   #13 (permalink)
Member: 1146942
Sonork: 100.1587278
Now try to re-flash your device using "Nexus Root Toolkit, You can download stock firmware through that Software.
Old 03-28-2017, 02:38   #14 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
I keep try to flash when phone reboot doen't goes to normal to enable debug so can you help what steps because I try but not help for me
Nexus Root Toolkit v2.1.9
Masterlists:
- LatestToolkitFiles.ini	3150
- AndroidDeviceListFull.ini	3150
- AndroidDeviceListFlash.ini	3150
BULLHEAD-BULLHEAD: Android 7.1.1 - Build: NMF26F
Live log initiated [2017-03-28]:
Checking ADB/FASTBOOT Connectivity
adb devices
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
fastboot devices
00e950c7d9b9d10c	fastboot
Refreshing adb server...
adb devices
 + Fastboot Device Connected
 + Bootloader Status: Locked.
adb devices
fastboot devices
Checking bootloader unlock ability:
 + OEM Unlocking Disabled
adb devices
fastboot devices
Rebooting your device...
Waiting for your device...
Device Detected
adb devices
fastboot devices
adb devices
fastboot devices
adb devices
fastboot devices
adb devices
fastboot devices
Device Detected
adb devices
fastboot devices
adb devices
fastboot devices
adb devices
fastboot devices
Attempting to automatically enable this feature
adb shell input keyevent 7
adb devices
fastboot devices
Device Detected
Checking OEM Unlockable Status:
 + Status: Disabled
Copied to clipboard.
adb devices
fastboot devices
adb devices
fastboot devices
adb devices
fastboot devices
adb devices
fastboot devices
Device Detected
adb devices
fastboot devices
#### Procedure Cancelled ####
 + OEM Unlocking Canceled
adb devices
fastboot devices
adb devices
fastboot devices
adb devices
fastboot devices
Device Detected
adb devices
fastboot devices
adb devices
fastboot devices
Old 03-28-2017, 08:15   #15 (permalink)
Member: 1146942
Sonork: 100.1587278
Try to re-flash the device with V10f firmware from the Support Area. Post here full Software log.
Page generated in 0.26237 seconds with 9 queries
