02-26-2022, 16:14 | #1 (permalink) |
Freak Poster Join Date: Apr 2007 Location: turkey Age: 35
Member: 495542 Status: Offline Sonork: 100.1650191 Thanks Meter: 45 | LM-G810EAW Repair IMEI Question [Solved] Code: Log file "C:\Program Files (x86)\Octoplus\Octoplus_LG\LOG\26-02-2022_16-21-32.log" created. 26/02/2022 04:21:35 م > Searching for server... 26/02/2022 04:21:37 م > Trying to ping server...0 26/02/2022 04:21:38 م > Trying to ping server...126/02/2022 04:21:38 م > ok 26/02/2022 04:21:38 م > Trying connect to server... 26/02/2022 04:21:39 م > Searching installed cards... 26/02/2022 04:21:39 م > Found card with s/n: 00009045 26/02/2022 04:21:39 م > Server check... 26/02/2022 04:21:40 م > Server Check succesfull! 26/02/2022 04:21:40 م > Server Check succesfull! 26/02/2022 04:21:44 م > Welcome to Octoplus/Octopus Box LG Software version 3.1.7 26/02/2022 04:21:44 م > Card S/N : 0000009045 26/02/2022 04:21:58 م > INI FUpdateInfo Done! 26/02/2022 04:21:58 م > INI FShowUpdateInfo start 26/02/2022 04:21:58 م > INI FShowInfo start 26/02/2022 04:21:58 م > INI FShowInfo show News Form 26/02/2022 04:22:27 م > -------------------------------------------------------------------------------- 26/02/2022 04:22:27 م > Transport: Connected 26/02/2022 04:22:28 م > Authorized. 26/02/2022 04:22:31 م > Work ID: 00000000016F3C0B 26/02/2022 04:22:32 م > Checking data...26/02/2022 04:22:33 م > OK 26/02/2022 04:22:33 م > Platform: LG Qualcomm 26/02/2022 04:22:33 م > Selected port: COM89 26/02/2022 04:22:33 م > Selected model: G810EA 26/02/2022 04:22:33 م > Reading info... 26/02/2022 04:22:35 م > Model ID: LM-G810EAW 26/02/2022 04:22:35 م > IMEI: 356070-10-609979-2 26/02/2022 04:22:35 م > Android version: 11 26/02/2022 04:22:35 م > Battery level: 46% 26/02/2022 04:22:35 م > Mode: Normal 26/02/2022 04:22:35 م > Firmware compiled date: Nov 11 2021 26/02/2022 04:22:35 م > Firmware compiled time: 21:00:00 26/02/2022 04:22:35 م > Firmware released date: Jan 14 2022 26/02/2022 04:22:35 م > Firmware released time: 13:48:56 26/02/2022 04:22:35 م > SW Version: 26/02/2022 04:22:35 م > MPSS.HE.1.0.c4-00116-SM8150_GEN_PACK-1.445324.3.449605.7 26/02/2022 04:22:35 م > IMEI: 356070-10-609979-2 26/02/2022 04:22:36 م > SPC: 000000 26/02/2022 04:22:36 م > Fixing IMEI... 26/02/2022 04:22:36 م > New IMEI: 352118-06-169433-1 26/02/2022 04:22:37 م > Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? 26/02/2022 04:22:40 م > Initializing ADB...26/02/2022 04:22:42 م > OK 26/02/2022 04:22:42 م > Waiting for phone...26/02/2022 04:22:45 م > OK 26/02/2022 04:22:46 م > Model ID: LM-G810EAW 26/02/2022 04:22:46 م > Phone firmware version: LMG810AT-00-V30b-LAO-COM-JAN-14-2022+0 26/02/2022 04:22:46 م > Kernel version: 4.14.190-perf+ (jenkins@si-ch1-bld118) (clang version 10.0.7 for Android NDK, GNU ld (binutils-2.27-bd24d23f) 2.27.0.20170315) #1 SMP PREEMPT Fri Jan 14 14:58:26 IST 202 26/02/2022 04:22:46 م > Android version: 11 26/02/2022 04:22:47 م > Hardware: Qualcomm Technologies, Inc SM8150 AArch64 Processor rev 14 (aarch64) 26/02/2022 04:22:47 م > Target operator: OPEN 26/02/2022 04:22:47 م > Connecting to server 0...26/02/2022 04:23:08 م > Failed!26/02/2022 04:23:08 م > OK 26/02/2022 04:23:08 م > Connecting to server 1...26/02/2022 04:23:29 م > Failed!26/02/2022 04:23:29 م > OK 26/02/2022 04:23:29 م > Connecting to server 2...26/02/2022 04:23:50 م > Failed!26/02/2022 04:23:50 م > OK 26/02/2022 04:23:50 م > Connecting to server 3...26/02/2022 04:24:11 م > Failed!26/02/2022 04:24:11 م > OK 26/02/2022 04:24:11 م > Performed by 3.1.7 Software version. 26/02/2022 04:24:12 م > Elapsed Time: 12:01:45 ص 26/02/2022 04:25:51 م > -------------------------------------------------------------------------------- 26/02/2022 04:25:51 م > Transport: Connected 26/02/2022 04:25:59 م > -------------------------------------------------------------------------------- 26/02/2022 04:26:02 م > Can not connect. 26/02/2022 04:26:02 م > Error: ہ~" 26/02/2022 04:26:02 م > Work ID: 00000000016F3C0B 26/02/2022 04:26:02 م > Checking data...26/02/2022 04:26:03 م > OK 26/02/2022 04:26:03 م > Platform: LG Qualcomm 26/02/2022 04:26:03 م > Selected port: COM89 26/02/2022 04:26:03 م > Selected model: G810EA 26/02/2022 04:26:03 م > Reading info... 26/02/2022 04:26:05 م > Model ID: LM-G810EAW 26/02/2022 04:26:05 م > IMEI: 356070-10-609979-2 26/02/2022 04:26:05 م > Android version: 11 26/02/2022 04:26:06 م > Battery level: 48% 26/02/2022 04:26:06 م > Mode: Normal 26/02/2022 04:26:06 م > Firmware compiled date: Nov 11 2021 26/02/2022 04:26:06 م > Firmware compiled time: 21:00:00 26/02/2022 04:26:06 م > Firmware released date: Jan 14 2022 26/02/2022 04:26:06 م > Firmware released time: 13:48:56 26/02/2022 04:26:06 م > SW Version: 26/02/2022 04:26:06 م > MPSS.HE.1.0.c4-00116-SM8150_GEN_PACK-1.445324.3.449605.7 26/02/2022 04:26:06 م > IMEI: 356070-10-609979-2 26/02/2022 04:26:06 م > SPC: 000000 26/02/2022 04:26:06 م > Fixing IMEI... 26/02/2022 04:26:06 م > New IMEI: 352118-06-169433-1 26/02/2022 04:26:07 م > Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? 26/02/2022 04:26:10 م > Initializing ADB...26/02/2022 04:26:12 م > OK 26/02/2022 04:26:12 م > Waiting for phone...26/02/2022 04:27:13 م > Failed! 26/02/2022 04:27:13 م > Please, reconnect phone, enable USB debugging, and try again. 26/02/2022 04:27:13 م > To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager. 26/02/2022 04:27:13 م > Performed by 3.1.7 Software version. 26/02/2022 04:27:13 م > Elapsed Time: 12:01:14 ص 26/02/2022 04:27:23 م > -------------------------------------------------------------------------------- 26/02/2022 04:27:23 م > Transport: Connected 26/02/2022 04:27:24 م > Authorized. 26/02/2022 04:27:24 م > Work ID: 00000000016F3DC0 26/02/2022 04:27:24 م > Checking data...26/02/2022 04:27:25 م > OK 26/02/2022 04:27:25 م > Platform: LG Qualcomm 26/02/2022 04:27:25 م > Selected port: COM89 26/02/2022 04:27:25 م > Selected model: G810EA 26/02/2022 04:27:25 م > Reading info... 26/02/2022 04:27:27 م > Model ID: LM-G810EAW 26/02/2022 04:27:28 م > IMEI: 356070-10-609979-2 26/02/2022 04:27:28 م > Android version: 11 26/02/2022 04:27:28 م > Battery level: 49% 26/02/2022 04:27:28 م > Mode: Normal 26/02/2022 04:27:28 م > Firmware compiled date: Nov 11 2021 26/02/2022 04:27:28 م > Firmware compiled time: 21:00:00 26/02/2022 04:27:28 م > Firmware released date: Jan 14 2022 26/02/2022 04:27:28 م > Firmware released time: 13:48:56 26/02/2022 04:27:28 م > SW Version: 26/02/2022 04:27:28 م > MPSS.HE.1.0.c4-00116-SM8150_GEN_PACK-1.445324.3.449605.7 26/02/2022 04:27:28 م > IMEI: 356070-10-609979-2 26/02/2022 04:27:28 م > SPC: 000000 26/02/2022 04:27:28 م > Fixing IMEI... 26/02/2022 04:27:28 م > New IMEI: 352118-06-169433-1 26/02/2022 04:27:29 م > Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? 26/02/2022 04:27:31 م > Initializing ADB...26/02/2022 04:27:33 م > OK 26/02/2022 04:27:33 م > Waiting for phone...26/02/2022 04:27:36 م > OK 26/02/2022 04:27:37 م > Model ID: LM-G810EAW 26/02/2022 04:27:37 م > Phone firmware version: LMG810AT-00-V30b-LAO-COM-JAN-14-2022+0 26/02/2022 04:27:38 م > Kernel version: 4.14.190-perf+ (jenkins@si-ch1-bld118) (clang version 10.0.7 for Android NDK, GNU ld (binutils-2.27-bd24d23f) 2.27.0.20170315) #1 SMP PREEMPT Fri Jan 14 14:58:26 IST 202 26/02/2022 04:27:38 م > Android version: 11 26/02/2022 04:27:38 م > Hardware: Qualcomm Technologies, Inc SM8150 AArch64 Processor rev 14 (aarch64) 26/02/2022 04:27:38 م > Target operator: OPEN 26/02/2022 04:27:38 م > Connecting to server 0...26/02/2022 04:27:39 م > OK 26/02/2022 04:27:39 م > Octopus smart card is present. 26/02/2022 04:27:39 م > Checking smart card...26/02/2022 04:27:45 م > OK 26/02/2022 04:27:45 م > Username: uaeunlock 26/02/2022 04:27:45 م > Authorizing...26/02/2022 04:27:48 م > OK 26/02/2022 04:27:48 م > Checking balance...26/02/2022 04:27:49 م > OK 26/02/2022 04:27:49 م > Checking operation...26/02/2022 04:27:52 م > OK 26/02/2022 04:27:52 م > Sending device information...26/02/2022 04:27:54 م > OK 26/02/2022 04:27:54 م > Get credits, needed for current operation...26/02/2022 04:27:55 م > OK 26/02/2022 04:27:55 م > Your balance: 100 credits. 26/02/2022 04:27:55 م > To perform "Repair IMEI" operation you need to have 100 credits. 26/02/2022 04:28:02 م > Sending loader... 26/02/2022 04:28:28 م > dem size00000160 26/02/2022 04:28:31 م > Prepairing for change protect status...26/02/2022 04:28:55 م > OK 26/02/2022 04:29:00 م > Reading QCN... 26/02/2022 04:29:00 م > Send SPC...26/02/2022 04:29:00 م > OK 26/02/2022 04:29:00 م > Reading Mobile Property...26/02/2022 04:29:00 م > OK 26/02/2022 04:29:00 م > Reading Feature Mask...26/02/2022 04:29:00 م > OK 26/02/2022 04:29:00 م > Reading Roaming List 0...26/02/2022 04:29:00 م > OK 26/02/2022 04:29:00 م > Reading NV_Numbered Items...26/02/2022 04:34:29 م > OK 26/02/2022 04:34:29 م > Reading NV_Numbered SIM1 Items...26/02/2022 04:36:03 م > OK 26/02/2022 04:36:03 م > Reading NV_Numbered SIM2 Items...26/02/2022 04:37:38 م > OK 26/02/2022 04:37:38 م > Reading NV Items...26/02/2022 04:37:38 م > OK 26/02/2022 04:37:38 م > Reading EFS...26/02/2022 04:37:39 م > OK 26/02/2022 04:37:39 م > Reading Provisioning Items...26/02/2022 04:37:52 م > OK 26/02/2022 04:37:52 م > Reading QCN done! 26/02/2022 04:37:52 م > Backup saved to "G810EA_356070106099792_26-02-2022_16-29-00.qcn" 26/02/2022 04:37:52 م > Switching to Download mode...26/02/2022 04:38:17 م > OK 26/02/2022 04:38:17 م > Initializing flash...26/02/2022 04:38:20 م > OK 26/02/2022 04:38:21 م > Platform: msmnile 26/02/2022 04:38:21 م > SW version: 26/02/2022 04:38:21 م > LMG810EAWAT-00-V30b-EEA-XX-JAN-14-2022+0 26/02/2022 04:38:21 م > Android version: 11 26/02/2022 04:38:21 م > LAF Version: 1.1 26/02/2022 04:38:21 م > Product ID: CB44S200519000739 26/02/2022 04:38:21 م > IMEI: 356070-10-609979-2 26/02/2022 04:38:21 م > Target operator: LAO 26/02/2022 04:38:21 م > Hardware: rev_10 26/02/2022 04:38:21 م > Reading partitions...26/02/2022 04:38:28 م > OK 26/02/2022 04:38:28 م > Reading security area...26/02/2022 04:38:29 م > Failed! 26/02/2022 04:38:29 م > LAF Error: 80000119. 26/02/2022 04:38:29 م > Writing security area... 26/02/2022 04:38:31 م > Execute : 0x00A9 26/02/2022 04:38:31 م > Writing cmd... 26/02/2022 04:38:32 م > reading cmd... 26/02/2022 04:38:32 م > Read: EXEC... 26/02/2022 04:38:34 م > Execute : 0x00A9 26/02/2022 04:38:34 م > Writing cmd... 26/02/2022 04:38:34 م > reading cmd... 26/02/2022 04:38:34 م > Read: EXEC... 26/02/2022 04:38:34 م > Please, put the phone in EDL Mode (Qualcomm 9008): 1. Press and hold "Vol-" and "Power" buttons. 2. As soon as the screen turns off, keep holding the "Vol-" and "Power" buttons and simultaneously press "Vol+" few times quickly. 3. Check PC Device Manager, a new device should appear "Qualcomm HS-USB QDLoader 9008". 26/02/2022 04:40:28 م > Found port COM12 26/02/2022 04:40:29 م > Connecting...26/02/2022 04:40:29 م > OK 26/02/2022 04:40:29 م > Sending loader...26/02/2022 04:41:06 م > OK 26/02/2022 04:41:06 م > Reconnecting phone...26/02/2022 04:41:06 م > OK 26/02/2022 04:41:08 م > Checking request... 26/02/2022 04:41:08 م > Request has been successfully sent! 26/02/2022 04:41:08 م > Obtaining response...26/02/2022 04:41:09 م > OK 26/02/2022 04:41:10 م > Reading partitions...26/02/2022 04:41:12 م > OK 26/02/2022 04:41:12 م > Resetting secutiy area...26/02/2022 04:41:15 م > OK 26/02/2022 04:41:15 م > Backup saved to "G810EA_356070106099792_26-02-2022_16-41-12.SEC" 26/02/2022 04:41:15 م > Rebooting phone...26/02/2022 04:41:16 م > OK 26/02/2022 04:41:16 م > Switching to Normal mode... 26/02/2022 04:42:24 م > Found model LMG810EA* ? at port COM89 26/02/2022 04:42:24 م > Send SPC...26/02/2022 04:42:30 م > OK 26/02/2022 04:42:30 م > Writing QCN... 26/02/2022 04:42:32 م > Could not read phone ESN! 26/02/2022 04:42:32 م > Writing NV_Numbered Items...26/02/2022 04:42:33 م > Failed! 26/02/2022 04:42:33 م > Error code: ZXLCALSZXD 26/02/2022 04:42:33 م > Performed by 3.1.7 Software version. 26/02/2022 04:42:33 م > Elapsed Time: 12:15:10 ص Last edited by Octopus support; 02-28-2022 at 11:22. |
02-28-2022, 11:26 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello. We added your one more attempt. Please, repeat operation once again and send us results. Also, don't use any USB hubs. Use directly motherboard connection type only. |
The Following User Says Thank You to Octopus support For This Useful Post: |
03-01-2022, 13:15 | #3 (permalink) |
Member: 495542 Status: Offline Sonork: 100.1650191 Thanks Meter: 45 | i do software first and try repair imei again its okkkkkkkkkkkkkkk thx alote octoppus team Code: Welcome to Octoplus/Octopus Box LG Software version 3.1.7 Card S/N : 0000009045 -------------------------------------------------------------------------------- Work ID: 0000000001727285 Checking data...OK Platform: LG Qualcomm Selected port: Selected model: G810EA Reading info... Could not detect mode! Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Work ID: 000000000172728D Checking data...OK Platform: LG Qualcomm Selected port: COM89 Selected model: G810EA Reading info... Could not detect mode! Performed by 3.1.7 Software version. -------------------------------------------------------------------------------- Work ID: 0000000001727339 Checking data...OK Platform: LG Qualcomm Selected port: COM89 Selected model: G810EA Reading info... Model ID: LM-G810EAW IMEI: 000000-00-000000-0 Android version: 11 Battery level: 55% Trying to enable Diagnostics ports... Found model LMG810EA* ÿ at port COM89 Reading info... Model ID: LM-G810EAW IMEI: 000000-00-000000-0 Android version: 11 Battery level: 55% Mode: Normal Firmware compiled date: Nov 11 2021 Firmware compiled time: 21:00:00 Firmware released date: Jan 14 2022 Firmware released time: 13:48:56 SW Version: MPSS.HE.1.0.c4-00116-SM8150_GEN_PACK- 1.445324.3.449605.7 SPC: 000000 Fixing IMEI... New IMEI A: 352118-06-169422-4 Finalizing... Initializing ADB...OK Waiting for phone...OK Model ID: LM-G810EAW Phone firmware version: LMG810AT-00-V30b-LAO-COM-JAN-14- 2022+0 Kernel version: 4.14.190-perf+ (jenkins@si-ch1-bld118) (clang version 10.0.7 for Android NDK, GNU ld (binutils-2.27-bd24d23f) 2.27.0.20170315) #1 SMP PREEMPT Fri Jan 14 14:58:26 IST 202 Android version: 11 Hardware: Qualcomm Technologies, Inc SM8150 AArch64 Processor rev 14 (aarch64) Target operator: OPEN Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: uaeunlock Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Sending loader... Prepairing for change protect status...OKOK IMEI successfully fixed! Rebooting phone... Performed by 3.1.7 Software version. |
The Following User Says Thank You to tahernike For This Useful Post: |
