Nexus 5 3g issue after imei repair [Solved] Hello again. I want to know if the 3g/4g issue with d820-d821 after imei repair is fixed or not yet? Thanks in advance. |
Hello. Yes, phone will have working 3G/4G after Repair IMEI operation. |
Simply make Reapair IMEI following step-by-step instructions in phone's manual ("Cable & Manual" button in software). |
mine didn't fix after IMEI repair any help please. Still stuck on 2g Thanks. |
Currently no solution how to fix 3G/4G network after Repair IMEI or Unlock operation. |
It works, but not for all devices. We work on full solution, but it is not ready. |
i provided them with a fresh nexus 5 NVM - hopefully a fix can come out soon as i too purchased the octopus LG activation only to use on Nexus 5. now iam stuck with 4 NExus5 devices and LG activation :( |
sg 4g succes Welcome to Octoplus/Octopus Box LG Software version 1.6.0 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM3 Selected model: D821 Reading info...Canceled! -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM59 Selected model: D821 Reading info... Initializing ADB...OK Waiting for phone...OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd59db4e Android version: 4.4.4 Hardware: ARMv7 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM59 Selected model: D821 Reading info... Initializing ADB...OK Waiting for phone... Please, reconnect phone, enable USB debugging, and try again. To enable USB debugging, please perform the following steps: 1. Disconnect cable 2. Install LG Android ADB drivers 3. Go to "Settings" -> "About phone" -> "Software information" 4. Click on Build number 5 times 5. Enable "Settings" -> "Developer options" -> "USB debugging" option 6. Connect the cable and check, whether ADB interface has appeared in PC Device Manager.OK Model ID: Nexus 5 Firmware version: Kernel version: 3.4.0-gd59db4e Android version: 4.4.4 Hardware: ARMv7 Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Unlocking Bootloader... Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ:ÿh°? at port COM63 Reading info...OK Mode: Normal Model ID: AAAAANAZ:ÿh°? Firmware compiled date: Mar 12 2014 Firmware compiled time: 20:00:00 Firmware released date: Jun 4 2014 Firmware released time: 17:04:20 SW Version: M8974A-2.0.50.1.16 IMEI: 3oooo Repairing 3G / 4G...OK Please, reboot the phone manually. |
They needed a nvm with 3g/4g to check the differences and found a solution? Didn't knew that... |
nexus 5 no service solution after imei fix or unlock here is the solution to fix the nexus 5 imei or unlock load the nexus 5 qcn file with the zero imei through qpst software it will say error or mismatch the qcn file but dont worry just hit ok then restart the phone manually once its done then go back to octopus box and hit just repair nvm thats it after 3 to 5 minutes ur phone will be working perfectly fine with out having issues this has been tested by me works like a charm |
did you download a specific QCN file or its from your own backup? (can you share link to the file?) - interested in trying your method to try and fix 3g/4G issue with D820 after imei repair. |
