12-22-2021, 17:21 | #1 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Pakistan lahore
Member: 2482838 Status: Offline Sonork: 100.1676271 Thanks Meter: 442 | Q510N IMEI repair process done [Solved] but imei old and credit lost please check and reply here is logs Code: Welcome to Octoplus/Octopus Box LG Software version 3.1.6 Card S/N : 0101017976 -------------------------------------------------------------------------------- Selected USB connection type Work ID: 000000000202578F Checking data...OK Platform: LG MTK Selected port: COM104 Selected baudrate: 921600 Selected model: Q510N Connecting to phone... Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM131 Mode: Emergency Initializing flash...OK Model ID: LM-Q510N Platform: mt6765 Code name: mdh30lm Android version: 10 SW version: LMQ510NAT-00-V20j-LGU-KR-SEP-06-2021+0 LAF Version: 1.1 Product ID: WI17S200424002286 IMEI: 353819-11-290769-2 Target operator: LAO Hardware: rev_10 Battery level: 33% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 353819-11-290769-2 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: khizarGSM Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM131 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM7 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting phone... Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Target config: 00E0 Prepairing loader... Sending loader... Executing loader... Synchronizing with loader... Device status: SYNC Device status: brom Initializing flash... Initializing flash... Sending loader... Device status: SYNC Reading info... EMMC rpmb size: 16 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 29820 Mb eMMC flash chip: .90014A68.42386150.3E032BA9.B53F272B eMMC flash chip: Unknown: hB8aP> Internal RAM size: 224 Kb External RAM size: 3072 Mb Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading partitions... Reading security area... Reading 1/3... Reading 2/3... Reading 3/3... Backup saved to "Q510N_353819112907692_22-12-2021_18-51- 08.SEC" Erasing part 1... Erasing part 2... Erasing part 3... Erasing part 4... To complete the operation, Please perform the following steps: 1. Disconnect USB cable. 2. Power ON phone. 3. Connect USB cable and select "File transfer" connection mode. 4. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 5. Press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! New IMEI A: 865798-05-027431-8 Finalizing... Performed by 3.1.6 Software version. https://drive.google.com/file/d/1NAr...ew?usp=sharing |
12-23-2021, 08:39 | #2 (permalink) | |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,142 | Hello. We added your one more attempt. Please, download and install latest test Software v. 3.1.6.01 from Support Area (Path:/SOFTWARE/Octoplus LG/TEST SOFTWARE/install_octoplus_octopus_LG_3.1.6.01.exe) Then repeat operation once again and post here results. We will check it. Note: Read attentive Software instructions. Quote:
12-23-2021, 11:31 | #3 (permalink) | |
Member: 2482838 Status: Offline Sonork: 100.1676271 Thanks Meter: 442 | Quote:
12-23-2021, 11:49 | #4 (permalink) |
Member: 2482838 Status: Offline Sonork: 100.1676271 Thanks Meter: 442 | same sir credit again lost problem same please check custarmar no give me more time here is logs Code: Welcome to Octoplus/Octopus Box LG Software version 3.1.6.01 Card S/N : 0101017976 -------------------------------------------------------------------------------- Selected USB connection type Work ID: 00000000020378AE Checking data...OK Platform: LG MTK Selected port: COM104 Selected baudrate: 921600 Selected model: Q510N Connecting to phone... Power OFF phone, press and hold "Vol+" for 10 seconds and connect USB cable. Phone found at port COM60 Mode: Emergency Initializing flash...OK Model ID: LM-Q510N Platform: mt6765 Code name: mdh30lm Android version: 10 SW version: LMQ510NAT-00-V20j-LGU-KR-SEP-06-2021+0 LAF Version: 1.1 Product ID: WI17S200424002286 IMEI: 353819-11-290769-2 Target operator: LAO Hardware: rev_10 Battery level: 27% Reading partitions...OK LAF Error: 80000119. Checking security...OK -------------------------------------------------------------------------------- IMEI: 353819-11-290769-2 Bluetooth address: Unknown Wi-Fi MAC address: Unknown -------------------------------------------------------------------------------- Checking operation... Trying second method... Checking Resource File... Step 1... Step 2... Please, disconnect cable, then press "Ok" button Connecting to server 0...OK Octopus smart card is present. Checking smart card...OK Username: khizarGSM Authorizing...OK Checking balance...OK Checking operation...OK Sending device information...OK Get credits, needed for current operation...OK Your balance: 100 credits. To perform "Repair IMEI" operation you need to have 100 credits. Please, connect powered OFF phone with USB cable. Found port COM60 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 0005 Brom Version: FF BootLoader Version: 03 Sending auth... Prepairing loader... Sending loader... Found port COM6 Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Connecting... Target config: 00E5 Brom Version: 05 BootLoader Version: FE Disabling protection... Reconnecting phone... Detecting Chip Version... Platform: MT6765: 0766.0000 HW version: 8A00.CA00.0000.0000 Target config: 00E0 Prepairing loader... Sending loader... Executing loader... Synchronizing with loader... Device status: SYNC Device status: brom Initializing flash... Initializing flash... Sending loader... Device status: SYNC Reading info... EMMC rpmb size: 16 Mb EMMC boot1 size: 4 Mb EMMC boot2 size: 4 Mb EMMC gp1 size: 0 Mb EMMC gp2 size: 0 Mb EMMC gp3 size: 0 Mb EMMC gp4 size: 0 Mb EMMC user area size: 29820 Mb eMMC flash chip: .90014A68.42386150.3E032BA9.B53F272B eMMC flash chip: Unknown: hB8aP> Internal RAM size: 224 Kb External RAM size: 3072 Mb Write security backup function doesn't work for this device with latest firmware versions. If you'll encounter any problem during Repair IMEI operation - you won't be able to restore the phone to it's initial state, so proceed at your own risk. Continue? Reading partitions... Reading security area... Reading 1/3... Reading 2/3... Reading 3/3... Backup saved to "Q510N_353819112907692_23-12-2021_15-34- 50.SEC" Erasing part 1... Erasing part 2... Erasing part 3... Erasing part 4... To complete the operation, Please perform the following steps: 1. Disconnect USB cable. 2. Power ON phone. 3. Connect USB cable and select "File transfer" connection mode. 4. Check, whether LGE Mobile USB Modem has appeared in modems section on PC Device Manager. 5. Press "Ok" button. Note: If "Ok" button isn't active, then You should reconnect device! Performed by 3.1.6.01 Software version. https://imgur.com/a/CLbYO0h |
12-23-2021, 12:05 | #5 (permalink) |
Member: 2891705 Status: Offline Thanks Meter: 2,142 | We added your one more attempt. Please, read attentive these instructions:
12-23-2021, 12:35 | #6 (permalink) | |
but i now again try just 5 mint | |
