11-11-2014, 12:38 | #2836 (permalink) |
Freak Poster Join Date: Oct 2011 Location: pakistan faisalabad
Member: 1677616 Status: Offline Sonork: [email protected] Thanks Meter: 6 | http://forum.gsmhosting.com/vbb/f799...-done-1875179/ 1.write Repair_1.qcn 2.write Repair_2.qcn ------------------------------------------------------------------------------ Checking data...OK Platform: LG Qualcomm Selected port: COM7 Selected model: D821 Reading info...OK Mode: Normal Model ID: AAAAANAZ:ÿh°¿ Firmware compiled date: Oct 01 2013 Firmware compiled time: 17:00:00 Firmware released date: Nov 19 2013 Firmware released time: 10:24:33 SW Version: M8974A-1.0.25.0.23 IMEI: 352136-06-XXXXXX SPC: 308508 After perform Repair IMEI operation, 3G/4G network will be unavailable! Fixing IMEI... New IMEI: 358239-05-XXXXXX Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading Roaming List 1...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D821_352136066XXXXX_07-11-2014_22-00-29.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D821_3521360669XXXXX_07-11-2014_22-06-39.SEC" Writing security area...OK Switching to Normal mode... Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Unlocking Bootloader... Select "Yes" on phone screen and press "Power" button. Please perform the following steps: 1. Wait while the phone will turn on 2. Reboot the phone 3. Enable "USB debugging" Mode 4. Connect the cable and check, whether ADB interface has appeared in PC Device Manager 5. Press "Ok" button. Initializing ADB...OK Waiting for phone...OK Switching to Fastboot mode...OK Bootloader is unlocked. Writing Bootloader...OK Please, wait while the phone will turn on and press "Ok" button. Trying to enable Diagnostics ports... Initializing ADB...OK Waiting for phone...OK Checking root access... Phone is already rooted. Diagnostics ports are enbled! Switching to Serial Port... Found model AAAAANAZ*ÿh°Ç at port COM7 Send SPC...OK Writing QCN... Writing Roaming List 0...OK Writing EFS...OK Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing Provisioning Items...OK Writing QCN done! IMEI successfully fixed! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM7 Selected model: D821 Reading info...OK Mode: Normal Model ID: AAAAANAZ:ÿh°¿ Firmware compiled date: Oct 01 2013 Firmware compiled time: 17:00:00 Firmware released date: Nov 19 2013 Firmware released time: 10:24:33 SW Version: M8974A-1.0.25.0.23 IMEI: 358239-05-883XXXXX SPC: 308508 wait 5-7 minutes and check 3G/4G networks. Repair IMEI D821 3G/4G network OK *good job * |
The Following User Says Thank You to sonofone143 For This Useful Post: |
11-13-2014, 11:09 | #2839 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | LG MS769 Direct unlock done Welcome to Octoplus/Octopus Box LG Software version 1.7.4 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: MS769 Initializing device...OK Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*769#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...OK Sending preloader...OK Sending loader...OK Reading info...OK IMEI: 013647-00-482900-1 Bluetooth address: BC:F5:AC:07:0BF Wi-Fi MAC address: BC:F5:AC:B2:94:B5 Locks: Service Provider Lock MCC=310 (USA) MNC=160 Unlocking... Reading EEPROM...OK Backup saved to "MS769_013647004829001_13-11-2014_10-08-08.EEP" Writing EEPROM...OK Phone successfully unlocked! Disconnected. |
The Following User Says Thank You to razib143 For This Useful Post: |
11-17-2014, 15:43 | #2842 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | LG GS290 unlock code read done -------------------------------------------------------------------------------- Platform: LG Infineon Selected port: COM3 Selected baudrate: 115200 Selected model: GS290 Please reconnect battery, press and hold power button... Phone found. Release power button. Sending loader...OK Reading info. Please wait... IMEI: 359289-03-382849-8 Bluetooth address: 6C6:8A:93:4A:72 Reading codes. Please wait... Backup saved to "GS290-359289033828498_17-11-2014_14-34-08.eep" -------------------------------------------------------------------------------- NCK : 1461 4614 4897 2645 NSCK : 6909 4203 3963 2239 SPCK : 7212 0593 8878 6673 CCK : 2720 0170 6744 6177 SIM : 8451 7177 9807 1115 MCC: 234 (United Kingdom) MNC: 15 (Vodafone United Kingdom) To finish the operation, please perform the following steps: 1. Insert the original SIM card and type 2945#*290# 2. Go to menu>Settings>Security>SIMLOCK and enter the code. |
11-17-2014, 19:58 | #2843 (permalink) |
Insane Poster Join Date: Jun 2012 Age: 27
Member: 1768772 Status: Offline Thanks Meter: 13 | Repair imei e410f -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM14 Selected model: E410f Reading info...OK Mode: Emergency Model ID: BS/LGE410f/7D Fixing IMEI... New IMEI: 358797-******* Searching security area...OK Reading security area...OK Backup saved to "E410f_Bad_17-11-2014_15-55-01.SEC" Analyzing security...OK IMEI: 357534-******* Writing security area...OK Switching to Normal mode... Found model LGE410f at port COM18 Finalizing...OK Rebooting phone...OK IMEI successfully fixed! Rebooting phone... |
The Following User Says Thank You to paulo henryck For This Useful Post: |
11-18-2014, 09:56 | #2844 (permalink) |
No Life Poster Join Date: Feb 2005 Location: (United States Of GINGOOG CITY Age: 47
Member: 120328 Status: Offline Thanks Meter: 243 | Welcome to Octoplus/Octopus Box LG Software version 1.7.5 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM603 Selected model: D620 Reading info...OK Mode: Normal Model ID: DAAAANAZ: ÿjÁ Firmware compiled date: Mar 02 2014 Firmware compiled time: 22:00:00 Firmware released date: Mar 22 2014 Firmware released time: 02:54:37 SW Version: MPSS.DI.2.0.1.c8-00005-M8926DAAAANAZM-1 IMEI: 352930-06-00 -------------------------------------------------------------------------------- Checking data...OK Platform: LG Qualcomm Selected port: COM603 Selected model: D620 Reading info...OK Mode: Normal Model ID: DAAAANAZ: ÿjÁ Firmware compiled date: Mar 02 2014 Firmware compiled time: 22:00:00 Firmware released date: Mar 22 2014 Firmware released time: 02:54:37 SW Version: MPSS.DI.2.0.1.c8-00005-M8926DAAAANAZM-1 IMEI: 352930-06- SPC: 000000 Unlocking... Reading QCN... Send SPC...OK Reading Mobile Property...OK Reading Feature Mask...OK Reading Roaming List 0...OK Reading NV_Numbered Items...OK Reading NV_Numbered SIM1 Items...OK Reading NV_Numbered SIM2 Items...OK Reading NV Items...OK Reading EFS...OK Reading Provisioning Items...OK Reading QCN done! Backup saved to "D620_352930062_8-11-2014_16-22-52.qcn" Switching to Download mode...OK Initializing flash...OK Reading partition...OK Reading security area...OK Backup saved to "D620_352930060010172_18-11-2014_16-36-26.SEC" Writing security area...OK Switching to Normal mode... Found model DAAAANAZ* ÿj¹ at port COM603 Send SPC...OK Writing QCN... Writing NV_Numbered Items...OK Writing NV_Numbered SIM1 Items...OK Writing NV_Numbered SIM2 Items...OK Writing QCN done! Phone successfully unlocked! To complete the operation, please make Factory Reset (Go to "Settings" -> "General" -> "Backup & reset" -> "Factory data reset", press "Reset phone" and "Erase everything" buttons). d620 unlock done. |
The Following User Says Thank You to dky_tel For This Useful Post: |
11-18-2014, 15:42 | #2845 (permalink) |
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | LG MS769 Metro PCS unlock done Welcome to Octoplus/Octopus Box LG Software version 1.7.4 -------------------------------------------------------------------------------- Platform: LG Infineon Connection mode: Modem Selected model: MS769 Initializing device...OK Please, power phone ON, connect P990 cable (with 56k resistor), type 3845#*769#, go to "Port Setting", select "CP Reset" (or "CP Image download") and click "OK"...OK Sending preloader...OK Sending loader...OK Reading info...OK IMEI: 013647-00-586196-1 Bluetooth address: BC:F5:AC:61:A9:70 Wi-Fi MAC address: 8C:3A:E3:18:E5:8E Locks: Service Provider Lock MCC=310 (USA) MNC=160 Unlocking... Reading EEPROM...OK Backup saved to "MS769_013647005861961_18-11-2014_14-38-45.EEP" Writing EEPROM...OK Phone successfully unlocked! Disconnected. |
11-18-2014, 22:50 | #2846 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Bulgaria Age: 53
Member: 1559599 Status: Offline Thanks Meter: 222 | Platform: LG Infineon Connection mode: OMAP Selected model: P970 Opening "LGP970AT-00-V30b-EUR-XXX-NOV-29-2012+0_AP.oct"... Please, disconnect battery and connect P999 cable (with 910k resistor).18.11.2014 г/ 22:45:00 > OK Initializing device...18.11.2014 г/ 22:45:01 > OK Writing Firmware... Connecting to modem CPU...18.11.2014 г/ 22:45:01 > OK Sending preloader...18.11.2014 г/ 22:45:06 > OK Sending loader...18.11.2014 г/ 22:45:23 > OK Initializing flash...18.11.2014 г/ 22:45:24 > OK Writing psi.fls...18.11.2014 г/ 22:45:24 > OK Writing slb.fls...18.11.2014 г/ 22:45:25 > OK Writing AENEAS_FW.fls...18.11.2014 г/ 22:45:28 > OK Writing R375_SIC.fls...18.11.2014 г/ 22:46:28 > OK Connecting to application CPU...18.11.2014 г/ 22:46:28 > OK Writing Partition #0...18.11.2014 г/ 22:46:28 > OK Writing Partition #1...18.11.2014 г/ 22:46:28 > OK Writing Partition #2...18.11.2014 г/ 22:46:28 > OK Writing Partition #3...18.11.2014 г/ 22:46:32 > OK Writing Partition #4...18.11.2014 г/ 22:46:34 > OK Writing Partition #5...18.11.2014 г/ 22:46:34 > OK Writing Partition #6...18.11.2014 г/ 22:46:35 > OK Writing Partition #7...18.11.2014 г/ 22:46:39 > OK Writing Partition #8...18.11.2014 г/ 22:49:18 > OK Writing Partition #9...18.11.2014 г/ 22:49:18 > OK Writing Partition #10...18.11.2014 г/ 22:49:35 > OK Writing Partition #11...18.11.2014 г/ 22:49:35 > OK Writing Partition #12...18.11.2014 г/ 22:49:35 > OK Writing Partition #13...18.11.2014 г/ 22:49:35 > OK Writing firmware done! Rebooting phone... Disconnected. Please, reboot the phone manually. |
The Following User Says Thank You to svetoslakis For This Useful Post: |
Post here successfully unlocked a2 phones | 3lsheikh | SETool2 | 10 | 03-04-2011 02:48 |
Successfully Unlock Z240 Phone Freeze | jhepoy_org | UST Pro II | 13 | 12-02-2009 06:03 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 0 | 11-29-2008 14:13 |
Successfully unlock BB5 phones with bb5king | Mjabbar | BB5KING | 2 | 11-26-2008 11:54 |
PB2 - Successfully unlocked LG phones CU/KU ... | DOUHAL | PolarBox 3 | 72 | 11-05-2008 18:21 |
