GSM / HSDPA Modems and Routers GSM , HSDPA , WCDMA, LTE Modems and Routers Unlock And Firmwares |
12-26-2018, 19:01 | #484 (permalink) |
Junior Member Join Date: Dec 2018
Member: 2885495 Status: Offline Thanks Meter: 0 | Hi, I'm trying to use this flasher to upgrade an E367u-2 to a fw version that supports voice. My device might have a Telenor-customized fw : Found modem : E367 Model : Huawei E367 IMEI : 353613045518662 Serial NR. : P8K5TA1142904442 Firmware : 11.810.09.10.00 Compile date / time : Jan 22 2011 14:51:01 Hardware ver. : CP1E367UM Dashboard version : MobiltBredband_2.3.1.343_Mac2.3.1.343 Chipset : Qualcomm MSM8200A Voice feature : not supported in current firmware SIM Lock status : Unlocked Wrong codes entered : 0 (unlock attempts left : 10) ( It was locked, i successfully unlocked). I first tried by just running the fw exe, and i get Error code 16: update failed. Then i tried fr3nsis universal flasher in resurrect mode, and i get Connection OK, Download mode FAIL. Same w 3 different fws: 11.838.01.00.1131.B726 11.838.01.00.158.B726 11.810.15.00.134.B726 What can i do? |
07-31-2019, 07:06 | #485 (permalink) |
Junior Member Join Date: Jun 2019 Location: Pakistan
Member: 2915691 Status: Offline Thanks Meter: 0 | E5573-322 Dead Boot After Flashing 21.333 File ini found ------------------------------------------------------------------------------ NORMAL PORT= DOWNLOAD PORT= ------------------------------------------------------------------------------ Start Resurrect Mode Checking connection...OK Checking Download Mode...FAIL |
01-12-2021, 07:55 | #487 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1338113 Status: Offline Thanks Meter: 0 | Hello, I am trying to use Huawei Modem Flasher v1.6 to flash E5832S. It was half-bricked when I flashed it with the firmware for E5832. Now it only enters download mode if I connect it to the PC while holding 'Connect' button. I was unable to find the bootloader bin or the recovery pin (pin1) for this model. This is the error I am getting: Writing 01 bin FAIL (Ack 0x03) Can someone please help? |
02-01-2021, 08:01 | #488 (permalink) | |
Member: 1338113 Status: Offline Thanks Meter: 0 | Quote:
04-22-2021, 14:40 | #489 (permalink) |
Freak Poster Join Date: Dec 2014 Location: amateur team
Member: 2303526 Status: Offline Thanks Meter: 24 | Hello everyone, i'm so sorry if i post this in wrong section because i don't know where i need to post it. Ok, my problem is that i want to create one exe file "auto flash for huawei modem" using balong_flash.exe - i already convert go.cmd to exe using bat convertor but error on calling balong_flash and firmware.bin - my idea is th oave similar for these pictures (from youtube users), they use enigma protector to add hwid and to have only executable file, but my idea is to pack all need files in one exe only. (when Enigma protect can protect .bat file.) - go.cmd - firmware.bin bin\ -balong_flash.exe thank you very much youtube pictures: and |
NU2000a - All Nokia Flasher & Unlocker! | VictorGSM | Main Sales Section | 0 | 12-14-2000 19:58 |
6150 + NCDS3.0 + Win2000 + IBM600X + Xyrcom GSM modem (realport)? | bibi2k | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-21-2000 17:33 |
Universal SP Unlocker 4.0 - home page !!! | bp.bonus | GSM Mobile Links | 0 | 01-22-2000 22:31 |
