ZTE General ZTE phones discussion, firmwares, solution, help |
09-15-2017, 19:55 | #16 (permalink) | |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Quote:
So in mine case not work Any Way thanks for share | |
The Following 3 Users Say Thank You to Formingus For This Useful Post: |
09-27-2017, 15:57 | #17 (permalink) |
Registered User Join Date: Sep 2006 Location: egypt
Member: 350835 Status: Offline Thanks Meter: 1 | need help in Zte Obsidian Z820 Please somebody have the firmware zte z820, after update via OTA, the phone bootloop and I can't fix, after hard reset the same problem. |
10-04-2017, 19:22 | #18 (permalink) | |
Only if someone has set with unlocked bootloader to read and upload | |
10-05-2017, 11:18 | #20 (permalink) | |
If they provide you can unlock via fastboot. or Root it via KingRoot and read with flash read apk. But after root do not update , it will bricked as 1st one Regards | |
10-05-2017, 21:28 | #21 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | You can't read/write that phone, even after unlocking bootloader. It's secure boot + auth file needed. Quote:
"Use it and trow to trash" b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
10-23-2017, 17:03 | #23 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Ukraine Age: 44
Member: 75408 Status: Offline Thanks Meter: 1,190 | I not talked with zte support because not exist talkable zte support in Ukraine and especially for t-mobile usa models. Here is I found open-source lollipop kernel for TMO Z820 but not sure that it can help: open-source-notice |
The Following User Says Thank You to Dr_Wolodya For This Useful Post: |
11-01-2017, 19:58 | #25 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
a box that you have ... They will probably ask board pictures, or if you have PIN-Finder for that box, to get them and test by cpu type ... b.r. Alex
The Following User Says Thank You to Brka For This Useful Post: |
11-02-2017, 22:27 | #26 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | I talked to ZTE, and I got this response from there. Can someone in the Statres call this number and call?? Code: Thanks for contacting ZTE. We would like to inform you that, the stores may not have had a news about the agreement that we had with Metropcs and that is the reason they did not provide you the warranty. Just you let you know that, recently we had an agreement with Metropcs, that all the repair and after sales issues would be handled by them, and not us. So that is the reason the stores may not be aware of this, however we would kindly request you to get in touch with metropcs on 888-863-8768. We are sure that they would be able to help you warranty for the device. Should you require any further assistance, please do not hesitate to contact us. Best Regards! |
01-24-2018, 18:53 | #29 (permalink) |
Junior Member Join Date: Sep 2014 Location: Dominican Republic
Member: 2258921 Status: Offline Sonork: NA Thanks Meter: 3 | This thread does not work, it's breaker my phone, I've searched a lot to find a solution, I'd downloaded the sources code to compile, but i don't have a clue how to do that, if someone can help it could be paradise on earth ....... |
01-24-2018, 23:50 | #30 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | Z820 flashing / unlock / repair is officially supported via Commercial BOX/Software. Use search on forum to find what box is about. Thread closed. b.r. Alex
The Following 3 Users Say Thank You to Brka For This Useful Post: |
