Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei
Huawei General Huawei phones and tablets help
Old 05-20-2013, 05:12   #1 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
[Guide] All Huawei Mobile phones Hard Reset Procedures
Huawei Um840 Hard Reset
Volume UP+Send+Power For Enter To Recovery Mode
Select Wipe Data/Factory Reset Delete Alll User Data
Waiting And Select Reboot Phone
The Following 6 Users Say Thank You to Braycel For This Useful Post:
Old 05-20-2013, 05:18   #2 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Huawei U9508 Honor2 Hard Reset
Volume up+Power 5 Seconds
Select Wipe Data/Factory Reset Deleted All User Data
The Following User Says Thank You to Braycel For This Useful Post:
Old 05-20-2013, 05:29   #3 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Huawei U8220 Hard Reset
Menu+End+Volume Up+Power 2 Seconds For Enter To Recovery Menu
Old 05-24-2013, 02:37   #4 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Huawei Ascend G300 Hard Reset
Step 1
Hold down the Volume Up and Power buttons simultaneously.
When you see the Huawei logo appear, release the power button but continue to hold the Volume Up button until your see the Android logo, then release.
This will access the blue unlock/reset menu.
Step 2
Once you've reached the unlock/reset menu, scroll down, using the volume buttons, and select ‘wipe data/factory reset’ by pushing the power button.
Step 3
When prompted, scroll down and select ‘Yes -- delete all user data’. This may take a few moments
Step 4
When prompted select ‘reboot system now’.
The Following 2 Users Say Thank You to Braycel For This Useful Post:
Old 05-24-2013, 02:52   #5 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Hard Reset Huawei Ideos S7 Slim
Turn off the Huawei Ideos S7 Slim
Hold together button : Power + Volume Down for several second until the Ideos logo appear in the LCD. After that than suddenly release both button. The Ideos S7 Slim will running it self and without any asking or without notice the tablet will be reset to factory default.
Old 05-24-2013, 02:58   #6 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
How to Hard Reset Huawei U8300
1.Turn off phone
2.Press Volume UP Call Button then press Power
To Reset from Menu
1.Press menu Key
2.Select Privacy
3.Select Factory Date Reset
4.Select Reset Phone
5.Select Erase eVERYTHING
Old 05-24-2013, 03:06   #7 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Hard Reset Huawei u8500 Ideos X2
press the "volume button" , the "call button" and the "power button" at the same time, then wait until you get in the screen where you can select the "reset factory" when you select the factory reset wait for the message "complete" then after that choose the "reboot".
Old 05-24-2013, 03:12   #8 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Huawei ideos X3/Blaze U8510 hard reset
Turn off phone.Hold down volume up and power button
Boot menu will appear.Use volume down to navigate and power button as okay.
select wipe data/factory reset.
Old 05-24-2013, 05:14   #9 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Huawei Ascend Y201 Pro Hard Reset
Here Is Procedure....
Hold Volume Up & Home Button Lower Center Touch Pad & After That Press Power Button....
When Ur Handset Vibrate Release Power Button But Keep Holding Volume Up & Home Button...
After 3 To 5 Second Handset Show Recovery Mode....
After That Press Volume Down Button To Wipe Data/Factory Reset...
After That Press Power Button To Make Reset...
After That Wipe Cache Partition...
After That Ur Handset Are In Factory State...
Old 05-28-2013, 02:49   #10 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Huawei Ascend D1
1) From the home screen, press Menu - Backup and reset - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
If the phone is totally unresponsive, even after a reboot, then try the following methods.
2) While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select.
3) While the phone is turned off, press and hold the Volume Down button. Then, while holding, press and release the Power button. A menu should appear. Use the Volume down key to go to Clear Storage. Use the Power button to select the option. Then when asked to confirm, press Volume Up for Yes.
4) While the phone is off, press and hold down Volume Up + Home + Power buttons at the same time. Then release the buttons when you see the Logo. Use the Volume Down button to go down and the Home or Power key to select. Choose the Wipe data/Factory reset option. Then Select Yes to delete all user data. Then choose to reboot the phone.
Old 05-28-2013, 03:55   #11 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Huawei U8800 Hard reset
Hold Volume up, call button, and power button until phone vibrates , Choose wipe data/factory reset when prompted.
Or
1. From the Home screen, press the Menu Key and touch Settings.
2 Touch the Privacy
4 Touch Factory data reset.
5 Touch Reset phone.
6 Touch Erase everythin
Old 05-29-2013, 05:03   #12 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Hard Reset Huawei U8860
Start with your Huawei U8860 in powered off state. If you cannot power it off, because it has just freezed up on you, then please take off it’s battery wait a couple of seconds and reinsert it.
Press and Hold “Volume UP” and the power buttons
Wait unto a boot recovery screen appears
Depress the “Volume UP” and power key.
Choose the Hard reset / Factory default procedure using the Volume up and down buttons
Old 05-30-2013, 03:12   #13 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Huawei U8100 Hard Reset
Press answer button + volume up button and start the phone. The phone will boot into recovery. Choose factory restore.
Old 05-30-2013, 15:02   #14 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Huawei U9200 Ascend P1 Hard Reset
First Power Off Your Phone
Press And Hold Both The Volume Up And Volume Down Keys And The Press The Power Key
clockworkmod recovery
Volume UP + Send + Power on Huawei Ascend From The Recovery Menu Select Wipe Data/Factory Reset
All Data Will Be Lost
Old 05-30-2013, 22:21   #15 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Huawei U8850 Vision hard reset
Press and hold the Power key and Volume up key for 10 seconds.
or
Press and hold the Power key and Volume down key for 10 seconds.
Page generated in 0.24191 seconds with 8 queries
