Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 08-17-2014, 06:52   #1 (permalink)
Member: 2183164
Thanks Meter: 27
**FIX for Activation Loop in 5c and 5s unlocked using Air 2 or Mini 2
http://www.youtube.com/watch?v=8eJa2rfsYbQ
http://www.youtube.com/watch?v=FRuETbANRZI
Say goodbye to activation loops!
This video is a proof that we don't get stuck at activation loop for Sprint 5c and 5s when unlock with Rsim Mini 2.
Requires Jailbreak and Patch A from repo R-SIM???
If you need any help in configuring your device feel free to contact me and we can setup a Skype session and get it configured.
Thanks and Regards.
The Following 2 Users Say Thank You to rok.palash For This Useful Post:
Old 08-17-2014, 07:06   #2 (permalink)
Member: 243915
Where did u get rsim mini 2. Any genuine resellers in Mumbai
Old 08-17-2014, 07:06   #3 (permalink)
Member: 1695601
Sonork: tuma jay
Thanks Meter: 63
I thought you wanted to show is the step by step video of how to get network and fix activation loop. This is just the result
Sent from my iPhone using Tapatalk
Old 08-17-2014, 07:16   #4 (permalink)
Member: 2183164
Thanks Meter: 27
You just have to install Patch A from isamteam repo once you get stable signals.
The Following User Says Thank You to rok.palash For This Useful Post:
Old 08-17-2014, 07:18   #5 (permalink)
Member: 1695601
Sonork: tuma jay
Thanks Meter: 63
Thats d problem. Never got any signal. Always activation required and sim not valid. I am 100% sure of d carrier.
Old 08-17-2014, 07:19   #6 (permalink)
Member: 2183164
Thanks Meter: 27
If you have problems finding Mini 2 then go for Air 2 v9 as they are one and the same. Internal workings are same just two different products.
Old 08-17-2014, 07:21   #7 (permalink)
Member: 2183164
Thanks Meter: 27
To make this work, you should atleast get stable signals before installing the patch. Are you using 128K card? If so try 64K. In india only Vodafone, Airtel works and there are only 64K cards available here.
Hope this helps.
Old 08-17-2014, 07:51   #8 (permalink)
Member: 2089201
Thanks Meter: 7
Call quality
Hi, do you have good call quality after installing the patch... or has it been fixed...
Old 08-17-2014, 09:06   #9 (permalink)
007vivek007's Avatar
Member: 2146521
Sonork: 100.1654013
Thanks Meter: 36
Arrow
Thanks and Regards.
Have you tried travelling in a roaming zone? Give it a try when you move to a roaming zone. You will definitely face activation loops.
The best way to get rid activation loops to set network mode "Manually". That's it! No need of any patch. It will perform the same thing that your patch does. You will not face activation loops in a home circle at least even you will get "No Service".
The best scenario is when you don't get the activation loops even while entering to a roaming zone.
Old 08-17-2014, 09:36   #10 (permalink)
Member: 2183164
Thanks Meter: 27
Yes I have tested it with traveling and before this patch was released, you would lose signal when your carrier is in process of changing the base station. Even if you set network to "Manual" mode you would still face activation loops when changing the base station. But with the patch installed "correctly", the issue of loops has completely gone and is 100% stable no doubt in that.
Do try and you would notice great improvements in stablity.
Hope this helps.
Thanks.
Old 08-17-2014, 11:06   #11 (permalink)
Member: 2183164
Thanks Meter: 27
Yes, no issues with calls after installing the patch brother.
Old 08-17-2014, 15:18   #12 (permalink)
Member: 2103546
Thanks Meter: 7
Hi. Will it work with Rsim air2 v1.0 for iphone 5c sprint...???
Old 08-17-2014, 15:21   #13 (permalink)
Member: 2183164
Thanks Meter: 27
It should. Give it a try. If not then it works 100% with new versions. Have tested v8.9 and v9 and both works perfect.
Hope this helps
Old 08-17-2014, 15:25   #14 (permalink)
Member: 2146521
Sonork: 100.1654013
Thanks Meter: 36
Hope this helps.
Thanks.
I'm not asking about only travelling. I'm asking about traveling in a roaming zone. That really matters. In home circle, I never faced any activation loops while on Manual mode. I only faced activation loops while entering in roam zone.
Old 08-17-2014, 15:28   #15 (permalink)
Member: 2183164
Thanks Meter: 27
Yes, while traveling in a roaming zone too: Shift from Mumbai zone to Maharashtra zone to be more precise and no issue with activation loops.
Page generated in 0.20737 seconds with 8 queries
