Go Back   GSM-Forum > Product Support Sections > SIM Solution Products > R-SIM & GEVEY SIM
Old 07-24-2014, 11:46   #16 (permalink)
Member: 1746786
Where i can buy code for update dongle?
Old 07-24-2014, 12:24   #17 (permalink)
Member: 243915
Where can u get one for a 5c sprint 7.1.2
Old 07-24-2014, 12:39   #18 (permalink)
miliky's Avatar
Member: 38751
Sonork: 100.75985
Thanks Meter: 2,573
contact
Skype : r-simshop ; we chat: 634306189
Email:[email protected] TEl/whatsapp/viber +86 15920070159
Old 07-24-2014, 12:45   #19 (permalink)
miliky's Avatar
Member: 38751
Sonork: 100.75985
Thanks Meter: 2,573
try different reader type
Old 07-24-2014, 13:43   #20 (permalink)
Member: 1746786
Originally Posted by miliky View Post
contact
Skype : r-simshop ;
no response on skype
Old 07-24-2014, 14:35   #21 (permalink)
Member: 2160880
Thanks Meter: 17
Originally Posted by lbkrawczyk View Post
Incoming calls still not work when 3G is turned on, also loop with 128k sim cards…
i can confirm this with version 10.1, when 3G enabled no incoming calls
Old 07-24-2014, 14:39   #22 (permalink)
Member: 2160880
Thanks Meter: 17
Originally Posted by Saharatw View Post
It's jail-broken full functional.
Call In/Out OK
SMS In/Out OK
Internet Edge/3G OK
The secret button was 3G XXXXXX (chiness text) can not read. After press will goto re-activate and __WoW__ the data network coming up.
But the stability and wider SIM card supported would be the next firmware. At least its work fine. 55.55
good luck,
when 3G enabled are you able to receive incoming calls?
Old 07-24-2014, 14:41   #23 (permalink)
Member: 2160880
Thanks Meter: 17
we would be completely happy if only the following points are accomplished:
1.- ACTIVATION LOOPS WHILE TRAVELLING OR IN A LOW SIGNAL AREA
2.- 3G/2G TOGGLE BUTTON WORKING WITHOUT REBOOT
3.- INCOMING CALLS AND SMS WORKS ON 3G NETWORK
Old 07-24-2014, 17:27   #24 (permalink)
Member: 2047874
Tested with differents carrier with new 4g-LTE USIM, but everytime activation screen and finished "Could Not Activate iPhone"
i choose "use 5s/5c 3g iOS7.1.x"
Now i dont understand - what is the NEW v10.1???
Old 07-24-2014, 18:19   #25 (permalink)
Member: 1938435
Thanks Meter: 208
New firmware update supports more SIM cards than before but not all 128K/256K SIMs yet. Interesting to note here is 9.8 supports 128K only on AT&T network but not TMobile network here in the USA.
Old 07-24-2014, 18:44   #26 (permalink)
R0D
Member: 428561
can i update any Rsim to 10.1 versión with the dongle with Rsim ?
Which Rsim should i use to unlock iPhone 5s, 5c for 4G LTE signal + internet?
Old 07-24-2014, 20:07   #27 (permalink)
Member: 2228492
Not working with 128k sim card.
Old 07-25-2014, 03:03   #28 (permalink)
Member: 2228492
I know it works with 64k sim cards you just need to update your rsim, but with 128k sim cards there is still an issue.
Old 07-25-2014, 06:04   #29 (permalink)
Member: 1915500
Thanks Meter: 37
There is a same issue like before with low signal area , no incoming calls on 3g and etc. with all types of sim 64 , 128 , 256 with v10.1
Old 07-25-2014, 10:48   #30 (permalink)
Member: 2180962
Thanks Meter: 21
the R-SIM mini2 and the delisting R-SIM mini+ can be updated with dongle.
Page generated in 0.23998 seconds with 8 queries
