02-12-2014, 00:48 | #1 (permalink) |
Junior Member Join Date: Feb 2014
Member: 2126436 Status: Offline Thanks Meter: 0 | No Service R-SIM Air Verizon 4S 7.0.4 |
02-12-2014, 02:32 | #2 (permalink) |
No Life Poster Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 | Jailbreak with evasi0n.com tool, go to Cydia, manage at the bottom, click Sources, edit, add cydia.neterteam.com Install 4S Neterteam iOS 7 patch. Reboot for service. |
02-12-2014, 04:15 | #3 (permalink) | |
Freak Poster Join Date: Dec 2013
Member: 2094769 Status: Offline Thanks Meter: 76 | Quote:
02-12-2014, 05:38 | #4 (permalink) |
Member: 2126436 Status: Offline Thanks Meter: 0 | I have also verified that it's a good ESN. I have installed Neter as well. Still giving me No Service. Any chance you have a better IMSI SimTester? Just verified the SIM is ready for activation. I had it go to one bar for a second one time but that was it. Just not sure what to try next to get it working. Always get No Service when I'm on a Verizon IMSI or clicking on Verizon CDMA or Mode 3 or 4 and then Verizon. Anything else gives me Invalid SIM. So the R-SIM is working in part but then I am not getting any service. Last edited by corim123; 02-12-2014 at 05:45. |
02-12-2014, 09:45 | #6 (permalink) |
Member: 2126436 Status: Offline Thanks Meter: 0 | That site and others all return a clean ESN and IMEI that's ready for activation. What is the best IMSI to use? I'm wondering if it isn't something stupid as it still keeps showing the vodafone carrier when I presume it should always show TFW in the Phone section of Settings. |
02-12-2014, 16:31 | #9 (permalink) |
Member: 1938435 Status: Offline Thanks Meter: 208 | Try this: put the SIM card in by itself without R-SIM, wait for activation required screen, then insert SIM card with R-SIM. Don't activate until you reach signal or restart if it says SIM Not Valid. |
02-13-2014, 09:00 | #11 (permalink) |
Member: 2126436 Status: Offline Thanks Meter: 0 | I've tried both these things and always get "No Service". Never get invalid SIM anymore. After trying the Activation that SIMTester mentioned, it just disappears when I replace R-SIM. Seller said maybe R-SIM is faulty and is sending me a GPP. Anybody think this will work any better? |
02-13-2014, 21:52 | #13 (permalink) |
Member: 2126436 Status: Offline Thanks Meter: 0 | I highly doubt there is an issue with the phone's hardware. Shouldn't really be a problem if the card is faulty because I'm having a GPP sent as a replacement. But do you have any other ideas while I wait for the new card? |
02-14-2014, 17:53 | #15 (permalink) |
Member: 2094769 Status: Offline Thanks Meter: 76 | If your iphone has no liquid damage or a bad esn then point your finger at either the sim card your trying to use which in this case just try a different sim card since it could be just need a re set for your chip or as mentioned above a faulty chip. |
