01-05-2014, 04:50 | #257 (permalink) |
Crazy Poster Join Date: Dec 2013
Member: 2093421 Status: Offline Thanks Meter: 20 | I just change single file in application/setup.app/ info.plist to info1.plist and every thing work (receive call+sms). info.plist relate to setup @ the same folder. Please we all try did in the application/setup.app/setup file you can use hex editor to open it. It is the key of the unlock. If somebody have the unlock phone 5s/5c sprint please upload application/setup.app/setup in. |
01-05-2014, 05:18 | #258 (permalink) |
Insane Poster Join Date: Mar 2008
Member: 731106 Status: Offline Sonork: 100.1590865 Thanks Meter: 3 | sprint use UICC-sim Quote: sprint use UICC-sim, is different form gsm-sim/usim. is there are some one can solve this problem?? |
01-05-2014, 06:50 | #259 (permalink) | |
No Life Poster Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 | Quote:
I see a few factory unlocked 5S/5C from AT&T and Verizon though. Is that the same file you need? | |
01-05-2014, 06:59 | #260 (permalink) | |
Member: 2093421 Status: Offline Thanks Meter: 20 | Quote:
My ip also can try at 10 this month. I have 5 days more can anybody help? | |
01-05-2014, 07:57 | #261 (permalink) |
Insane Poster Join Date: Dec 2013 Location: US
Member: 2091625 Status: Offline Thanks Meter: 50 | I really doubt, if the calls will work even after replacing all the carrier bundles from a never locked iPhone. The baseband is locked until the phone is activated. My activation log file shows phone is not activated. So, effective what we are trying is to get the phone a "software unlock" like ultrasn0w. But there was not a single software unlock for A5+ devices. Though really hope replacing carrier bundles works, but I'm not optimistic about it. Because, if it was this easy to unlock phones after jailbreak(just by replacing carrier bundles) the unlock would have got released world wide in cydia repositories itself. |
The Following 3 Users Say Thank You to shy_mkm For This Useful Post: |
01-05-2014, 12:22 | #263 (permalink) |
Junior Member Join Date: Jan 2014 Location: Ukraine, Kiev Age: 43
Member: 2098386 Status: Offline Thanks Meter: 16 | Yes, please upload iphone folders with all carrirer bundle. we should try this way. any unlocked iphone 5c bundles. @shy_mkm, but we alredy trick baseband - look, we can receive call and make calls (112). its mean we need to trick it correctly again, using original apple bundle. hope is still alive )) |
01-05-2014, 13:51 | #264 (permalink) |
Member: 2098386 Status: Offline Thanks Meter: 16 | my ipnone was already activated by previous owner, in sprint network. so, technically it pass one time activation procedure. now it has Bad ESN, but still shown like activated, on the check sites, like http://****************/?imei=358538050400263 itunes say it not activated and cannot be activated, when I connect iphone with my carrier sim. some times, itunes show me message about invalid sim card. And I can't enter to iphone after that. Without sim or in airplane mode everything work well. When I connect him without any sim card, couple of times it say, that iphone is already activated on CDMA US network. I just want to say, i think, we still can unlock sim blocking with these files. Last edited by Stalk_ua; 01-05-2014 at 14:00. |
01-05-2014, 14:12 | #265 (permalink) |
Member: 2098386 Status: Offline Thanks Meter: 16 | when I connect iphone with my carrier sim. some times, itunes show me message about invalid sim card. And I can't enter to iphone profile after that. Without sim or in airplane mode everything work well. but after airplane mode iphone cant find my carrier network. Or just take out sim card, connect to itunes, and them insert sim card back. about activation status Last edited by Stalk_ua; 01-05-2014 at 14:19. |
01-05-2014, 15:03 | #266 (permalink) |
Member: 2091625 Status: Offline Thanks Meter: 50 | @Stalk_ua, activation is not a one time activity. It is a one time activity for one sim and phone combination. Once a SIM is activated for a phone, the activation ticket is stored in /var/root/Library/Lockdown/activation_records/. If another SIM which was not previously activated on that phone is inserted then activation is done online, the iPhone sends encrypted data of the IMEI, ICCID, IMSI, GID1, GID2 and so on to Apple's activation server and if the information is valid, an encrypted activation ticket is sent and stored in the phone. You could also read this log file to see if your phone is actually activated or not. /var/logs/lockdownd.log Clear this log file, and Put valid Sprint SIM and see what gets written to the log. And clear the log again, and put unsupported SIM and see what gets written to the log. Also, some more informatoin about activation tickets. Activation Token - The iPhone Wiki If you need detailed explaination of how activation works, you would also read through the Apple's activation Patent US 2009/0061934 A1 Service Provider Activation with Subscriber Identity Module Policy But given that we are able to receive calls, with what we are trying we may be able to temporarily by-pass and make calls(and need to do it everytime after reboot). But it won't be like "fully unlocked" like earlier ultrasn0w or sim interposers. But that would also be a good break, given our current situation of no outgoing calls. I encourage you to try it with factory unlocked carrier bundles and let us know. But my main reason to post this was to not get carried away that we will be able to "fully unlock" for the time being. |
The Following User Says Thank You to shy_mkm For This Useful Post: |
01-05-2014, 16:40 | #267 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1525225 Status: Offline Sonork: bmx666 Thanks Meter: 1 | hi maybe we can use ussd code to bypass... maybe. i think it's better that each of us work on 1 of these idea. someone on bypass, someone on decode, and someone on difference locked working iphone and this unlock, and .... |
