12-12-2013, 17:58 | #121 (permalink) | |
Freak Poster Join Date: Apr 2010
Member: 1288185 Status: Offline Thanks Meter: 74 | Quote:
I am not visiting your forum anymore. BTW I always try to help your customers on the forum which you never do.. Thanks for your humble responses....huh....!!! | |
The Following User Says Thank You to ashish_beri For This Useful Post: |
12-21-2013, 11:16 | #131 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2089201 Status: Offline Thanks Meter: 7 | Hi, I have an iphone 5c sprint bad ESN, I'm unable to get imsi from sprint sim, when I insert it with r-sim 9 pro. It does not show the menu. But when I insert any other sim along with R-sim 9 pro I'm able to get the menu. Please help |
12-25-2013, 06:38 | #135 (permalink) |
Insane Poster Join Date: Dec 2013 Location: US
Member: 2091625 Status: Offline Thanks Meter: 50 | SupportedSIMs in the Carrier Bundle Hello All.. I jailbroke my Sprint Locked Bad ESN iPhone 5c.. After looking at the file carrier dot plist in the Sprint carrier bundles, I see the format of the ISMI of the supported SIM cards should be like below.. <key>SupportedSIMs</key> <array> <string>310120_ID-89011201</string> <string>310120_GID2-01</string> <string>310120_GID2-02</string> <string>310120_GID2-03</string> <string>310120_GID2-A1</string> <string>310120_GID2-A2</string> </array> So, for Sprint, it is a combination of GID2 but RSIM takes only 7 digits.. So if someone can find out the GID2 and try it with AIO SIM by providing full string, it should work. Also when I open AT&T Carrier bundles carrier dot plist , the supported SIM format is just 6 digit checks as below, which explains why the RSIM's are working for AT&T and others and not Sprint. <key>SupportedSIMs</key> <array> <string>310170</string> <string>310380</string> <string>310410</string> <string>311180</string> <string>310560</string> </array> I may be wrong, any other thoughts are welcome. We can discuss this and find a solution. This same solution should be applicable for Sprint iPhone 5s as well. |
The Following 5 Users Say Thank You to shy_mkm For This Useful Post: |
