Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #46 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2016
Member: 2575858 Status: Offline Thanks Meter: 20 | "New solution for 6s/6sp/se/7/7pput chip and mobile sim into iphone ----it go activaion---- press HOME , emergency call -------enter *5005*7672*0# ,pls dia it once you see the left corner show signal point or no service ,---menu jump out ----select correct carrier ------select 6S/6SP/SE mode,--- activate it , next wait 4g signal come out ." @Luistmw Sent from my SM-G955U using Tapatalk |
![]() | #51 (permalink) | |
Member: 2575858 Status: Offline Thanks Meter: 20 | Quote:
Or have there been some with success??? Sent from my SM-G955U using Tapatalk | |
![]() | #52 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2012 Location: *#0011# NG
Member: 1736804 Status: Offline Sonork: @kanokh / @imeione Thanks Meter: 442 ![]() | Not work Quote:
Not work iOS 11 ![]() ![]() ![]() | |
![]() | #55 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2003 Location: Enugu - Nigeria Age: 57
Member: 38751 Status: Offline Sonork: 100.75985 Thanks Meter: 2,573 | Return to TMSI unlock mode. Mobile Operation Flow Method①Ignore WiFi, open cellular data, data roaming, close 4G. First adjust the card patch operator, insert the card + mobile card, input *5005 * 7672 * 11 # mobile phone will automatically find the mobile 2G signal, then open 4G on the OK method②good card paste. Close 4G, insert the card separately, and automatically jump to the upper-left corner of the activation screen to display 3G or E. Emergency dialing 112 to remain on and back out. Plug in the card and the phone card. Wait for 2G signal to appear, open 4G then. (Switch flight mode if a hollow signal appears during operation) Methodology③ Switch on the card, insert the mobile card separately, and the phone automatically jumps to the WiFi activation interface. Five signal points and 4G appear in the upper left corner. Turn off the phone immediately (be sure to turn it off thoroughly). Then pull out the card and install the card and the mobile card. Turn it on and wait for the signal. Method④There are many methods to move 4G, but I wont go through them here. Unicom 4G operation method Method①Put the card in place, insert the 4G card separately, appear 5 points plus 4G, emergency dialing 112, hold 112 for 5-8 seconds, switch to 5 points plus 3G, pull out the card directly, plug in the card sticker and the card, automatically send out the signal. Telecom 4G Operation Method Method①Adjust the card, dial the *5005*7672*11# code, and then prompt a message to restart the machine. Methodology② Switch on the card, plug in the card separately, and the phone automatically jumps to the WiFi activation interface. Five signal points and 4G appear in the upper left corner. Turn off the phone immediately (be sure to turn it off completely). Then pull out the card and install the card and the card. Turn it on and wait for the signal. Operator Boot Directive *5005*7672*00# Search signal instruction*5005*7672*11# |
![]() | #56 (permalink) |
Member: 2575858 Status: Offline Thanks Meter: 20 | Here are my results when it is on searching I can make it to home screen when I have 3-g service I get stuck at SIM card not supported I do try *5005*7672*0* And I get settings succeeded service center address no address... ![]() ![]() ![]() ![]() ![]() Sent from my SM-G955U using Tapatalk |
The Following User Says Thank You to diazdetail626 For This Useful Post: |
![]() | #57 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2013 Location: Los Angeles
Member: 1938435 Status: Offline Thanks Meter: 208 ![]() | Yes this is the whole point of this topic. You got to wait for someone to discover a new bug and buy a new chip or be lucky enough to have an upgradable chip and an update dongle. |
![]() | #58 (permalink) | |
![]() | #59 (permalink) |
Junior Member Join Date: Oct 2017
Member: 2765523 Status: Offline Thanks Meter: 6 | Here are my best results of 2 day researching our problem guys ![]() 3G connection works Outgoing calls work(can`t hear outgoing voice, no problem with incoming voice) No incoming call Sms service also doesn`t work. Sorry I`m new here and it doesn`t allow me to post links... Took a few pics wanted to share... |
The Following User Says Thank You to bmu777 For This Useful Post: |
![]() | #60 (permalink) | |
