08-15-2020, 15:26 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: neighborhood
Member: 1097964 Status: Offline Thanks Meter: 157 | Infinix Hot 8 Lite X650C FRP Reset done but little problem After FRP reset phone not turn on i had to disconnect battery and connect again then phone worked |
08-15-2020, 18:40 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Need to wait after opperation finish 5-10 sec and it will start charging. Also if phone not restart you can keep vol- and vol+ and power on till phone restart(10-20 sec). Or....dissasemble, how you like more. I'am just checked on Vivo y91c with same cpu, this phone i'am not have. After exe finish operation(about 15 sec, wait for buttons to become active) phone start ok. Last edited by orbita; 08-15-2020 at 19:01. Reason: added more info |
08-17-2020, 11:27 | #3 (permalink) | |
Member: 1097964 Status: Offline Thanks Meter: 157 | Quote:
had to disassemble to power on, purpose of reporting is , if possible find a work around so we can switch on without disassemble no objection on your work, take it in positive way | |
08-17-2020, 11:50 | #4 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Trick with buttons work all time , sometime help also inserting usb cable till you keep buttons. You can perform reset frp only on this phone, this setting will restart phone. And you can reset userdata after. frp + format power off phone on opperation finish, only frp restart it. |
The Following User Says Thank You to orbita For This Useful Post: |
