01-10-2021, 09:57 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,267 | NCK Dongle / Pro Dongle SPRD Module v1.4 Update Released - [10/01/2021] Added: Lava Atom 2X - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). LE9920 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). LH9810 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). LH9910 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). LN9820 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). LN9821 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). X11 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). X41 Plus - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). Z40 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). Z51 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). Alcatel OT-3080 (beta) - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). OT-3088 (beta) - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta). Supported/Added for direct selection in exe next cpu
If generic loader not work (this can happen in new phones if loader sign key differ), user must use custom loader generated from pac firmware. - Added phrasing for DHTB header on new CPU, this will allow to display more detailed info about cpu. - Added fastboot functions in exe. - Added unlock bootloader in fastboot mode new generation cpu. This method is based on leaked rsa key and support many phones. But will not work for all phones, if phone firmware have different sign key, metod will not work. 1. Read info(token id) 2. Generate signature file using leaked rsa4096_vbmeta.pem key(need_files directory) On this step user will select private key, and exe will prompt to default one. Can be selected other private key if user have it and it's supported by phone 3. Sending generated signature in phone. On some models this function will work, on some not(key differ) If your phone not accept generated by exe signature, user can request this file officially and send in phone using exe. Exe allow to select key file, if user have private key from firmware source, he can use own key. Tested on alcatel ot-5024, Xiaomi Qin 2, posible will work in other phones. -- Locked Bootloader. --- Erase FRP in fastboot mode(need unlocked bootloader) - Added support for new pac format (old exe gived exception on this) Exe will autodetect pac format and will use new or old layout auto. - Added simunlock in flash mode for supported phones. Many phones after unlock in diag mode relock after factory reset, so this will help to solve problem. - Added simunlock support for phones with new security, so called type 4 This is beta version, if some not work, will need to provide nvram backup maked by this exe version. Backups maked by old exe versions is not compatible with this. Unlock is supported in diag mode and flash mode. Unlock will work only on phones with not damaged security. Phones with erased or rewrited from other phone nvram will not work. Website: www.nckdongle.com Download From Support Area OR MediaFire ****************************/file/w5hbs...r_1_4.rar/file Google Drive https://drive.google.com/file/d/1vTZ...ew?usp=sharing |
The Following 35 Users Say Thank You to Fast Unlocking For This Useful Post: |
01-10-2021, 11:53 | #4 (permalink) | |
No Life Poster Join Date: Apr 2010 Location: Rawalpindi Age: 32
Member: 1285139 Status: Offline Thanks Meter: 181 | Quote:
The Following 2 Users Say Thank You to Adeel Galaxy For This Useful Post: |
01-10-2021, 15:12 | #14 (permalink) |
Junior Member Join Date: May 2015 Location: Kwekwe Zimbabwe
Member: 2401507 Status: Offline Thanks Meter: 1 | Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 2 Detected: SPRD U2S Diag (COM40) Platform Version MOCORTM_17C_W18.41.3_P26.03_DebugProject Version pike2_pubBASE Version FM_BASE_17C_W18.41.3_P26.03HW Version sc7731e_modem11-19-2019 140507 Build number: k150-user 9 PPR1.180610.011 00WW_1_090 release-keys IMEI 1: 46 BT: 748A283463B4 WIFI: 748A2833CA94 UID: T44C_4_41_31 Reading simlock backup, wait.... Saved to: C:\Users\Vanteeagain Tech\Documents\spreadtrum_module\simlock_diag_nvra m_backup\353185112154069__diag_simlock_nvram_backu p_2.tar Simlock Status: SIMLOCK: ACTIVE NETWORK SUBNET: INACTIVE SP LOCK: INACTIVE CORPORATE: INACTIVE USER LOCK: INACTIVE [4]Simlock Type: 0 0 UID: T44C_4_41_31 Collecting info from phone.. [1]Some wrong with data integrity, aborting This error will come if phone is factory unlocked also. Done. |
01-10-2021, 15:17 | #15 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Bulawayo zimbabwe
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | This unlock does it require credit like other tools or its free |
The Following 2 Users Say Thank You to onz For This Useful Post: |
