01-13-2021, 09:47 | #46 (permalink) |
Freak Poster Join Date: Nov 2013 Location: zimbabwe
Member: 2075865 Status: Offline Thanks Meter: 99 | https://mega.nz/file/DMcShbzB#9rlCBl...UNTMU24UlIn0wI https://mega.nz/file/3JN2GDKT#9MF2Bs...oSM_VTJU14a2yE |
The Following User Says Thank You to kngoya For This Useful Post: |
01-13-2021, 10:08 | #47 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Download this exe and install it. https://drive.google.com/file/d/1RNW...ew?usp=sharing After test zte phone with it, now must read uid correctly. Post exe log also, will help allot us. Nokia still checking, this phone was unlocked with other tool before? Last edited by orbita; 01-13-2021 at 10:17. |
01-13-2021, 11:18 | #49 (permalink) | |
Member: 2075865 Status: Offline Thanks Meter: 99 | Quote:
01-15-2021, 13:45 | #50 (permalink) |
Member: 2075865 Status: Offline Thanks Meter: 99 | Phone Storage: EMMC EXE: NckDongle Spreadtrum Module 1.4 SELECTED: ZTE L130 ACTION: SimUnlock Start Detect phone... Phone must be off with battery inside. Long press "VOL -" key while inserting usb cable. For some phones need to Long press "VOL -"+ "VOL +" key while inserting usb cable. Keep key untill boot complete. Detected: SPRD U2S Diag (COM3) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. New flash metod detected. UID: T2FC80_5_18_33 *************** Manufacturer: ZTE Hardware: sc7731e_1h20_v1.1.0 Hardware version: SC7731e_2_IRD_K_V1.1.0 Build product name: P731K30 Build description: sp7731e_1h20_native-user 9 PPR1.180610.011 196 release-keys Product name: VDC_ZA_P731K30 SW Version: VDC_ZA_P731K30V1.0.0B06 Build Id: PPR1.180610.011 Model: ZTE Blade L130 Android Release: 9 Android Version: VDC_ZA_L130_V1.1 Security patch: 2019-02-05 This phone have frp partition. MatchesMask [w_fixnv1] [w_fixnv1] Size to download: 1024 KB Reading w_fixnv1 IMEI 1: 861486041539510 IMEI 2: 867400020316620 Simlock Type: 4 Simlock Status: SIMLOCK: ACTIVE NETWORK SUBNET: INACTIVE SP LOCK: INACTIVE CORPORATE: INACTIVE USER LOCK: INACTIVE [4]Simlock Type: 0 0 Backup saved to: C:\Users\Etech\Documents\spreadtrum_module\simlock _flashmode_backup_nvram\VDC_ZA_L130_V1.1\VDC_ZA_L1 30_V1.1_nvram_backup_2.tar Unlock is supported for this phone Integrity seems ok, proceed with unlock.... Start write unlock, wait... Wait untill phone restart. Log saved: C:\Users\Etech\Documents\spreadtrum_module\Saved_L ogs\sc7731e_1h20_v1.1.0SC7731e_2_IRD_K_V1.1.0VDC_Z A_L130_V1.1_861486041539510_867400020316620_sim_un lock_phone.txt Total Time: 00:00:22 Done. zte blade l130 successiful unlocked |
The Following 2 Users Say Thank You to kngoya For This Useful Post: |
01-20-2021, 04:31 | #51 (permalink) |
Crazy Poster Join Date: Feb 2014
Member: 2121390 Status: Offline Thanks Meter: 12 | ACTION: Direct Unlock Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 2 Detected: SPRD U2S Diag (COM12) Platform Version: MOCORTM_18A_W19.08.2_P38_Debug Project Version: sharkle_Smart_Phone BASE Version: FM_BASE_18A_W19.08.2_P38 HW Version: sc9832e_modem 04-21-2020 06:37:52 Build number: MVS_MX_P932F50V1.0.0B03 EMMC DDR SIZE :29G+1G AT UID: T1NC14_19_17_18 IMEI 1: 86374804080 IMEI 2: 86740002031 IMEI 3: 86740002031 IMEI 4: 86740002031 BT: 4859A4F2DE4F WIFI: B41C308DFC14 UID: T1NC14_19_17_18 Reading simlock backup, wait.... Saved to: C:\Users\gety\Documents\spreadtrum_module\diag_nvr am_backup\MVS_MX_P932F50V1.0.0B03_86374804080__dia g_simlock_nvram_backup_1.tar Simlock Status: SIMLOCK: ACTIVE NETWORK SUBNET: INACTIVE SP LOCK: INACTIVE CORPORATE: INACTIVE USER LOCK: INACTIVE [4]Simlock Type: 0 0 Unlock is supported for this phone Collecting info from phone.. Checking simlock integrity.... Integrity seems ok, proceed with unlock.... Writing simlock ok Writing simlock sign ok Done. Log saved: C:\Users\gety\Documents\spreadtrum_module\Saved_Lo gs\MVS_MX_P932F50V1.0.0B03_86374804080_diag_simloc k_unlock.txt |
The Following User Says Thank You to ribebe For This Useful Post: |
01-20-2021, 15:03 | #52 (permalink) |
Freak Poster Join Date: May 2014 Location: Boriziny,Madagascar Age: 32
Member: 2178386 Status: Offline Thanks Meter: 10 | Thanks for this update nck team.. I had a strange issue with Telma F1max 4G sc9832e android 10. phone can't enter diag mode. when I enter diag mode com disappear and appear only 1 second and disconnect and exe says no device connected. I am confused if it is not driver problem or this phone's new security. Can you please suggest me a good unisoc android driver please |
01-20-2021, 15:15 | #53 (permalink) | |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
This can happen on new cpu(sc9863A, sc9832e e.t.c.), and exe prompt you about. | |
01-20-2021, 15:22 | #54 (permalink) |
Member: 2178386 Status: Offline Thanks Meter: 10 | Thanks for quick reply. Do you mean that when exe says no device detected I shoud wait for 20 sec and it connect itself or I must do something. I am very confused |
01-20-2021, 17:16 | #55 (permalink) | |
No, if exe say no device detected, you have problem with drivers and you must check windows device manager. And verify if drivers is installed ok. Drivers come together with installer and it's located in same directory with exe. In folder named Unsioc_Drivers. To put phone in diag mode not need to press any key, just insert usb cable when exe ask. If all will be ok, exe will detect phone and will restart it. Some phones(old phones will restart quick in diag mode) New cpu like sc9863a can take 10...20 sec till phone will restart in diag mode. Must come back com port if all ok. | |
The Following User Says Thank You to orbita For This Useful Post: |
01-26-2021, 11:58 | #56 (permalink) |
Member: 2075865 Status: Offline Thanks Meter: 99 | Nokia C1 unlocked successifully with .exe test you posted, here are the logs below: ACTION: Direct Unlock Detecting phone, wait... Phone must be off. Connect usb cable without pressing any key. Using connection mode 2 Detected: SPRD U2S Diag (COM10) Platform Version: MOCORTM_17C_W18.41.3_P26.03_Debug Project Version: pike2_pub BASE Version: FM_BASE_17C_W18.41.3_P26.03 HW Version: sc7731e_modem 11-19-2019 14:05:07 Build number: k150-user 9 PPR1.180610.011 00WW_1_090 release-keys EMMC DDR SIZE :15G+1G AT UID: T44B96_24_24_18 IMEI 1: 353185111751394 IMEI 2: 353185111927390 IMEI 3: 867400020316638 IMEI 4: 867400020316646 BT: 748A28336C55 WIFI: 748A28332795 UID: T44B96_24_24_18 Reading simlock backup, wait.... Saved to: C:\Users\Etech\Documents\spreadtrum_module\diag_nv ram_backup\k150-user 9 PPR1.180610.011 00WW_1_090 release-keys_353185111751394__diag_simlock_nvram_backup_1. tar Simlock Status: SIMLOCK: ACTIVE NETWORK SUBNET: INACTIVE SP LOCK: INACTIVE CORPORATE: INACTIVE USER LOCK: INACTIVE [4]Simlock Type: 0 0 Unlock is supported for this phone Collecting info from phone.. Checking simlock integrity.... Integrity seems ok, proceed with unlock.... Writing simlock ok Writing simlock sign ok Done. Log saved: C:\Users\Etech\Documents\spreadtrum_module\Saved_L ogs\k150-user9PPR1.180610.01100WW_1_090release-keys_353185111751394_diag_simlock_unlock.txt |
