Are they using CPU to calc codes??? I was thinking they are using GPU, like Genie Team. |
so what ? All our computers will be much much powerful than that ... |
shure is per GPU, you cant get same calculation power with the fastest CPU´s... and per cluster they have minimum 2 grafikcards build it... some mainboards can old 4 (!!!) cards for paralell calculation... so forget about your "normal" webservers... |
Why can't we do that ? 1 milion computers are faster than 2000 GPU's ... |
this is a good one at least with time things are gona balance for good. keep it up |
and you will get this 1 million computers to work for your unlocking codes? :D the are more important calculations, like for cancer or aids and ppl give there computer for this thinks, but not that you can calc your unlock code. you know what i mean? another question: will you be able to write special loader to execute custom code for getting the important value? (because you need to decrypt it, and you cant calculate just by bruteforce, you need more thinks then just bforce...) will you be able to write a bionic software, witch should calculate for you? i think, ppl think its so easy to make sl3 bforce... to make this, you need more softwares then just a unlocking tool... |
I don't say it's easy to make SL3 bruteforce . What cancer and aids people have to do with this ??? Let's just die , all of us , because we are a plague for earth ... Why do we need a bionic software ? Sorry to say but you are on a field full of poppies ... |
so better to not expect that ..bec after that sl3 market will be killed again by copy paster and price will be droped to 1 or evern half euro..:D |
if solution is based on code calculation it can be protected by making a based server application, but if solution is based on patching, it will be copied in the first hours after be released :-) |
i think you dont got my point! how you will get 1 million computers working for your code bruteforcing? how you will get this ppl to use theres computers to bforce instead of other usefull thinks? with bionic software i mean, you need to programm same softwares as all others how use this system for researches. and at least you need to find 1 million ppl how will give there calculation power for your unlock codes bruteforcing... i bet, you will not find 1000 ppl how will do this. got my point now? |
I said one million but I didn't mean one million . Maybe 2000 - 3000 are enough ... Untill we try we can't know how much do we have to have ... |
B.R. Alkapone |
It is not. Just one of the 4U cases on the picture of the GT cluster have 3200 cores to crunch in parallel. And each single core in this case works faster as the code could be optimized to use the GPU cash memory that is few nm away from each core. Also i did check those distributed clients, they are very slow and buggy. To make something workable for GSM you need to write your own client and maybe ask users to upgrade to latest i7 workhorse CPU with good watercooling and overclock. But again to have real impact you will need hundreds of thousands of guys that keep their PCs connected 24/7. Just my 2 cents. BR, Alex |
