crack version is available only 2.7, which dose not support any BB phone, not even 7130e. best is use unicdma , winhex, qpst, qxdm and windows calc. if memory is readable all bb are possible this way. not only bb all phone are possible if memory is readable. |
Sir , which version of Os you used For Blackberry 8330 ESN Memory . |
8330mAMEA_PBr4.5.0_rel188_PL3.4.0.25_A4.5.0.131_Sp rint br, |
Sir i m Asking for Blackberry 8330 not 8330m ??? my Set is ESn Based not MEID . |
Hi I am facing a Problam in BB 8330 (MEID Baesd) Phone version v4.5.0.66 this Phone is Issued by TATA Indicom. I have to Changed ESN succusfully. Problam in MIN Writing by Both Method Ist is CDMA Workshop v3.6.0 & 2nd is Manual Edit in Programing by ##SPC. When I Change MIN Manualy Then Show is "Invalid IMSI_S for TATA". & When I Write by CDMA Workshop after succusfull write then Automatic Change Default MIN in the Phone. Sir Please suggest me how can I Solve this Problam asap. Thanks & Regards Rajinder Aggarwal |
various versions but this will do the best br, |
we are working on it solution will be posted soon wipe of set completely and try to download this version if fails then wait for solution http://rs104.rapidshare.com/#!downlo....131.exe|86010 br, |
these are the 8330m version available 8330mAMEA_PBr4.5.0_rel179_PL3.4.0.21_A4.5.0.127 8330mAMEA_PBr4.5.0_rel188_PL3.4.0.25_A4.5.0.131 8330mAMEA_PBr4.5.0_rel205_PL3.4.0.30_A4.5.0.138 8330mAMEA_PBr4.5.0_rel253_PL3.4.0.41_A4.5.0.160 8330mAMEA_PBr4.5.0_rel281_PL3.4.0.51_A4.5.0.169 8330mAMEA_PBr4.5.0_rel293_PL3.4.0.55_A4.5.0.173 8330mAMEA_PBr4.5.0_rel295_PL3.4.0.55_A4.5.0.175 8330mAMEA_PBr4.5.0_rel311_PL3.4.0.59_A4.5.0.186 but need to find .77 v that will do the job http://www.filecrop.com/3246385/index.html lets try ... as the ram is locked in 8330m yet not possible to downgrade First use MFI multiloader Nuke your phone when PIN becomes 00000000 Upload Software br, |
Normal Downgrade Prcedure:
Wiping your phone with JL Commander
thx to .idriss.us br, |
Another great tool you can use with your blackberries is called which can assist you in wiping, upgrading, and downgrading as well. read this first - BlackBerry Master Control Program (MCP) is a power tool for BlackBerry devices designed for basic, moderate and advanced users. You can use BlackBerry Master Control Program (MCP) to (Basic) take screenshots (including auto-capture and auto-save), set the device time, turn the radio/on off, recover memory, gather information, view/clear event logs, display modules, gather module information, create ALX/JAD files, backup and restore third party applications, (Advanced) handheld wipe (all 3 types), factory reset, load, save and erase modules. The Operating System Management page allows you to completely manage and optimize any OS you want to install on your device. The Javaloader CLI page offers a 1:1 GUI for javaloader.exe. MCP allows you to keep an unlimited number of OS's installed on your PC but at the time you actually install an OS to your device MCP only lets RIM's Application Loader "see" the OS you had selected inside MCP. Most OS 101 articles tell you to uninstall all other OS's from your PC before you begin the process. This is time consuming to say the least. MCP allows you to keep multiple BlackBerry OS's installed on your computer and keep them in their current (possibly optimized) state for later use at any time. http://www.4shared.com/file/XF5eD9Dr/BlackBerry_Master_Control_Prog.html br, AKSingh |
how to Transfer Relince Uim In HTC 6850 . where can i get MEID or pESN from Sim for change MEID in HTC or any other MEID Based Phone . Tell Me Something more about MEID or pESn in CDMA .. PLZ Help ME Any body ????????? SRY FOR MY BAD eNGLISH |
http://forum.gsmhosting.com/vbb/f128...4/#post6507203 br, |
Sir where can i get MEID or pESN from Sim ????? |
How to Calculate MEID DEC and P(ESN) [INDENT]For those of you that might be affarid that the calculators will all disapear The MEID is a string of 14 hexadecimal digits and is comprised of a 56 bit word. The first 8 bits are reserved by TIA, the next 24 bits are the manufacturer identification, and the remaining 24 bits are the unit serial number. To obtain the value of the 56 bit word, one needs to take each string of four bits and convert it to its hexadecimal equivalent. As an Example: 1010 000 100 000 000 000 000 000 000 000 010 010 010 100 101 101 111 0010 =A10000009296F2 (hexadecimal). The left of the number must be padded with zeros to create enough decimal places to complete the decimal number. The first part will always be 10 digits, and the last part will always be 8 digits.As an example, for hexadecimal MEID=A10000009296F2: 1. Take the first 8 digits and convert them . . . . 2. A1000000 hex is equal to 2701131776 decimal. 3. Take the last 6 digits and convert them . . . . 4. 9296F2 hex is equal to 09606898 decimal (note the padding of 1 zero to the left). 5. Concatenate the first 10 decimal digits in front of the last 8 decimal digits. 6. 270113177609606898 is the 18-digit decimal MEID. This is how to get you're MEID DEC. Now for (P)ESN Hex You will use a Hash Calc. 1. Take A10000009296F2 and paste into you're SHA-1 hash calculator. 2. Calculate the HASH characters in this example A10000009296F2 = 2d0e6efea8f8082c9703cf6636c4a2195c75b7ed 3. Take the last 6 characters and place 80 in front of them = 8075b7ed 4. This is are (P)Esn Hex 0x8075B7ED So Binary= 1010 000 100 000 000 000 000 000 000 000 010 010 010 100 101 101 111 0010 MEID Hex = A10000009296F2 MEID Dec = 270113177609606898 P(ESN) Hex = 0x8075B7ED P(ESN) Dec = 12807714797 thx @amoamre and this one http://forum.gsmhosting.com/vbb/f513...n-meid-679859/ You cannot convert ESN > MEID, but you can get a pseudoESN (pESN) from an MEID. http://www.tiaonline.org/standards/resources/esn/ An ESN type can be distinguished as a pseudo ESN (pESN) based on the first 8 bits ("manufacturer" code) as derived from the MEID using the SHA-1 algorithm to reduce a 56-bit MEID to a 24-bit ESN. The pESN codes are not unique, but will not match any UIMID or true ESN (tESN) because they have a unique manufacturer code of 0x80 (decimal 128). wbr |
Sir, i hv another blackberry 8330m . i want to use it on TATA Network . i write PRL Sucssefully with CDMA Workshope . bt after PRL writing My Phone Show On standby signal is good but as soon as i make a call *228 the phone signal goes off and says "Call failed " on ending call signal is full again. Is there any Solution for TATA network in it . |
