Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
06-10-2008, 09:34 | #306 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Patch unlock = non pro
Member: 323137 Status: Offline Thanks Meter: 235 | it's not free becuse you will need to buy a setool dongle. so go to your setool section and write about your love to setool. no one will buy it to unlock there own phones that cost to mucth for them. but you setool people seems to be to stupid to understand that. it's strange that you can use setool when you are not able to understand simple things like that. |
06-23-2008, 20:04 | #307 (permalink) |
Junior Member Join Date: Oct 2005 Age: 43
Member: 186241 Status: Offline Thanks Meter: 0 | Hi guys, I am trying to unlock a SE K800 From the Three network, I have managed to unlock another K800 and a K770 from different networks, but when i try to unlock this one from Three, everytime i go to flash it it tells me bad file cannot flash |
06-25-2008, 16:28 | #310 (permalink) |
Banned Join Date: Jun 2008 Location: http://gsmpower.exofire.net
Member: 785885 Status: Offline Thanks Meter: 89 | Here is a free Setoolite only solution http://www./showthread.php?t=554563 |
07-03-2008, 11:56 | #311 (permalink) |
Freak Poster Join Date: Jan 2005 Location: SBZ-TUNISIA Age: 54
Member: 104036 Status: Offline Thanks Meter: 44 | W580i done ok w580i locked to bouygue Fr Code: ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401755523 CERT:RED FLASH CID:52 COLOR:RED Model:W580i MAPP CXC article: R6BC002 prgCXC1123362_GENERIC_LA MAPP CXC version: R6BC002 Language Package:FRANCE CDA article: CDA102774/125 CDA version: R3A Default article: cxc1123364 Default version: R6BC002 Network LOCKED Operator: MULTIPLE Elapsed:12 secs. Will backup GDFS now. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401755523 CERT:RED FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok CSloader version: 070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009 loader startup: executed loader GDFS startup: executed stated number of vars:1368 Found:1097 variables Found:271 variables GDFS read all done, GDFS_35683401755523.BIN written Phone detached Elapsed:58 secs. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401755523 CERT:RED FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok CSloader version: 070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009 loader startup: executed loader GDFS startup: executed USERCODE reset to 0000 Elapsed:29 secs. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401755523 CERT:RED FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok only FLASH operation supported in that mode Elapsed:7 secs. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401755523 CERT:RED FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok CID52 BYPASS PROCEDURE STARTED Processing part1... CSloader version: 070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009 Processing part2... Processing part3.... OTP LOCKED:1 CID:51 PAF:1 IMEI:35683401755523 CERT:RED FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" HOLD "C" BUTTON AND ATTACH PHONE CID52 BYPASS PROCEDURE FINISHED ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Trying to launch embedded bootloader... INT LDR:DB2020_PRELOADER_FOR_SETOOL2 LDR:DB2020 LOADER FOR SETOOL2 Flash ID check:897E Flash props sent ok writing E:\GSM\FLASHES\SONY-ERICSSON\W580\W580_R6BC002_MAIN_GENERIC_LA_RED52.mbn CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 Going to execute VKP script.... Starting to process VKP patch script: E:\GSM\FLASHES\SONY-ERICSSON\W580\Remove_SIM_lock_W580_R6BC002.vkp VKP script loaded OK. Lines: 6 Patch structure created OK. Determining blocks to read... New block #0000 added: $44600000 Blocks selected OK. Reading blocks: 1 Blocks readed to memory OK. Checking contents... Blocks patched OK. Start writing... Block 0 written VKP script executed OK Elapsed:574 secs. |
Free DB2020 Unlocking.K800,w880,S500,T650, and all the other BY=AN.SANJI | an.sanji | Sony Ericsson | 3 | 02-21-2010 12:07 |
Need help with v3x, no camera and messages full (YES I READ ALL THE OTHER THREADS) | J-B00GIE | Motorola P2k | 1 | 07-11-2007 07:40 |
-=DB2020 unlock in China and all of others=- | .::Gsmdenis::. | Main Sales Section | 0 | 12-18-2006 02:02 |
Nokia unlocking sim card and all our other software/hardware for trade | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-23-1999 13:19 |
