Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
09-27-2008, 00:25 | #348 (permalink) |
Junior Member Join Date: Sep 2008
Member: 871521 Status: Offline Thanks Meter: 0 | Tried to do this with a UK Vodafone V630i. All was going well until the last part of the setool2lt bit when it told me "Processing script... can't open script file". It just stops here. my phone screen has turned white but I am still able to turn it on and access my menu. The phone remains locked though. What am I doing wrong? I'm pretty certain I've followed the instructions word for word. Thanks in advance. |
11-03-2008, 07:55 | #351 (permalink) | |
Freak Poster Join Date: Oct 2007 Location: sri lanka
Member: 619828 Status: Offline Thanks Meter: 11 | Quote:
urgent need help. thanks in advance. | |
11-03-2008, 15:45 | #352 (permalink) |
Junior Member Join Date: Nov 2008
Member: 891900 Status: Offline Thanks Meter: 0 | Please help..my phone is bricked Hi.. I am a newbie in SE (a HTC user), but I am trying to help a nephew to have his K610i unlocked and with Portuguese language.. I spent the last 3 days reading a lot about SE.. SETool and other stuff, to do that. But Unfortunatelly after flashing according to instructions to unlock, the phone is now bricked (does not turn on nor connect to SETOOL2Lite).. can anybody help ? This is the log generated by the last update: Welcome to SEtool2 ( LITE edition ) v 1.11 supported DB2010/DB2012 CID49/50/51/52, DB2020 CID49/51/52 Loaded 51 flash descriptors if you like LITE edition - please visit www.setool.net and buy FULL. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:################ CERT:RED FLASH CID:52 COLOR:RED Model:K610i Brand:Sony Ericsson MAPP CXC article: R1ED001 prgCXC1250589_TELEFONICA_TH MAPP CXC version: R1ED001 Language Package:TELEFONICA CDA article: CDA102568/107 CDA version: R8A Default article: cxc1250376 Default version: R1ED001 Network LOCKED Operator: 208-01 Elapsed:4 secs. ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:################## CERT:RED FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok CID52 BYPASS PROCEDURE STARTED Processing part1... CSloader version: 070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009 Processing part2... Processing part3.... OTP LOCKED:1 CID:51 PAF:1 IMEI:################## CERT:RED FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" HOLD "C" BUTTON AND ATTACH PHONE CID52 BYPASS PROCEDURE FINISHED ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 Trying to launch embedded bootloader... INT LDRB2020_PRELOADER_FOR_SETOOL2 LDRB2020 LOADER FOR SETOOL2 Flash ID check:897E Flash props sent ok Going to execute VKP script.... Starting to process VKP patch script: C:\DB2020_Free_unlocking\SIMLockPatchGen\vkp\Remov e_SIM_lock_K610_R1ED001.vkp VKP script loaded OK. Lines: 6 Patch structure created OK. Determining blocks to read... New block #0000 added: $44700000 Blocks selected OK. Reading blocks: 1 Blocks readed to memory OK. Checking contents... Blocks patched OK. Start writing... Block 0 written VKP script executed OK Elapsed:450 secs. |
11-30-2008, 13:51 | #359 (permalink) |
Freak Poster Join Date: Oct 2007 Location: indus
Member: 602248 Status: Offline Sonork: [email protected] Thanks Meter: 69 | thanks ................. plz can u ost all se reset files thans |
12-03-2008, 06:19 | #360 (permalink) |
Junior Member Join Date: Apr 2005
Member: 132690 Status: Offline Thanks Meter: 0 | I try this procedure and at the end get this error message witn my w850, what am I doing wrong can anyone help me.. thanks ChipID:9900,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:49 PAF:1 IMEI:35240101645220 CERT:RED FLASH CID:52 COLOR:RED LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok writing F:\BAJADAS\downs\LGKF510\W850\Firmware\W850_R1KG00 1_MAIN_GENERIC_CY_RED52.mbn CURRENT FLASH FILE CID:52 SSW uses complete hash, hash len is:9200 Will flash 460 blocks... SSW loading returns:0 Going to execute VKP script.... Enable alternative security bypass !!! Starting to process VKP patch script: F:\BAJADAS\downs\LGKF510\W850\s\Remove_SIM_lock_W8 50_R1KG001.vkp VKP script loaded OK. Lines: 6 Patch structure created OK. Determining blocks to read... New block #0000 added: $44740000 Blocks selected OK. Reading blocks: 1 Block @ $44740000 read error. Have only: 00000000 bytes Elapsed:287 secs. |
Free DB2020 Unlocking.K800,w880,S500,T650, and all the other BY=AN.SANJI | an.sanji | Sony Ericsson | 3 | 02-21-2010 12:07 |
Need help with v3x, no camera and messages full (YES I READ ALL THE OTHER THREADS) | J-B00GIE | Motorola P2k | 1 | 07-11-2007 07:40 |
-=DB2020 unlock in China and all of others=- | .::Gsmdenis::. | Main Sales Section | 0 | 12-18-2006 02:02 |
Nokia unlocking sim card and all our other software/hardware for trade | SP UNLOCKER 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-23-1999 13:19 |
