Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 09-01-2005, 00:07   #1 (permalink)
    Joselord's Avatar
    Member: 73798
    Exclamation T237 to T290 update failure
    I tried flashing my t237 with t290a firmware. I forgot to unlock before I flashed and I ended up with a phone that works only in 900Mhz. It used to work in 850 and 1900Mhz. I heard that know I have to flash GDFS in AVR format but I don;t have the files for either one (T237 or T290). Any chance anyone here could help me? I used UFS to backup but when I try to reflash with backup it says :"file corrupted or patched". Any suggestions? Thanks
    Old 09-01-2005, 14:32   #2 (permalink)
    japunlock's Avatar
    Member: 87396
    Thanks Meter: 64
    1st can you post the file u used to update the phone??
    2nd is it a flash file for t290i or t290a
    3rd if it was a flash file for t290a make rebuild sp area using otp imei and it shall work on 850 and100 as it used to
    Old 09-01-2005, 23:29   #3 (permalink)
    Joselord's Avatar
    Member: 73798
    Well I need a T290a file... I flash with wrong file (T290i)... basically i need it to work with 850 and 1900 bands...
    Thanks
    Old 09-09-2005, 23:23   #4 (permalink)
    Joselord's Avatar
    Member: 73798
    So, I kept flashing my phone and I finally killed it. Could somebody plz tell me what other firmware I can use to bring it back?
    T237 to T230 or T290 conversion???? midou01 Sony Ericsson 22 12-02-2010 12:21
    What should I do in case of update failure? Gsmserver Smart-Clip 341 03-06-2007 08:59
    T290a to T290 bowei Sony Ericsson Hardware Repair 0 10-26-2006 14:31
    T230 to T290 converting problem. DeDaMrAz Cruiser Suite 8 07-26-2005 06:43
    My Griffin Clip LG 8110/20/30 update failure, Help! hunk4004 Griffin 2 10-08-2004 23:19
    Page generated in 0.13995 seconds with 9 queries
