Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
12-01-2004, 11:33 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: EGYPT
Member: 57430 Status: Offline Thanks Meter: 6 | need help to convert t226 to t230 regard's |
12-01-2004, 19:57 | #3 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Boston
Member: 21920 Status: Offline Thanks Meter: 10 | You will need to rebuild the bandlock but it still might not work as there are hardware differences. I have heard of people taking parts from other phones to modify it and make it work though... |
12-02-2004, 12:40 | #5 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | the 226 is 850/1900 mhz and the 230 900/1800mhz, the hardware is different too not just the software, the higher or lower frequency is disabled to pass with special filters, capacitors, resistors etc, they must have exact and correct values, so only one specific section of the frequency can pass. you need to do some special modification on the board, to get this conversion done correctly. And even if u get the modification done it wont work as good as the original. usually these mod boards have very bad reception and transmition, and only work close to the tower where the signal is very strong. |
12-02-2004, 22:42 | #6 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Cochabamba Age: 38
Member: 87396 Status: Offline Thanks Meter: 64 | it cant be done as mrfixit said this two phones work in different frequencies but if you flash a t226 with t230 gdfs it will say t230in each part of the phone |
12-02-2004, 23:28 | #7 (permalink) |
Member: 21920 Status: Offline Thanks Meter: 10 | You can change the phone type descriptor with Fighter and get it to say T985 if you want... I believe his point was to make it work on T230's frequencies, and we have established that software alone can not do this. |
need help to convert 6030 to 6030b | sartaj | Nokia Hardware & Hardware Repair | 1 | 08-15-2007 12:31 |
Need gdfs file to convert T610 to T630 and T630 to T610 | mayer | Twisterflasher | 4 | 10-12-2005 13:40 |
pls i need to convert 3590 to 3510 | ragyfon2010 | Nokia Hardware & Hardware Repair | 8 | 04-08-2005 15:29 |
Convert T226 to Dual Band? | gsmcaptain | Sony Ericsson | 1 | 02-24-2004 01:49 |
