Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 5 / iPhone 5S / iPhone 5C / iPhone SE
Old 09-23-2013, 08:14   #1 (permalink)
Member: 1418524
Thanks Meter: 186
iphone5 restore 3194 error
hi iPhone5 only iTunes power on.
i try restore 3194 error
delete hosts file same problem?
Old 09-23-2013, 10:42   #2 (permalink)
Member: 1461211
Thanks Meter: 27
delete all hosts file and remove itones restart your pc install last itones
Old 09-24-2013, 18:18   #3 (permalink)
Moderator
loca|host's Avatar
Member: 363451
Sonork: 100.1577895
Thanks Meter: 834
Wich version are you trying to restore ??
Apple is no more signing iOS 6.1.4 , you have to update to iOS 7 .
Old 09-25-2013, 12:36   #4 (permalink)
Member: 1418524
Thanks Meter: 186
iOS 6.1.4 now i try ios7 wait sir
Old 09-25-2013, 12:46   #5 (permalink)
Member: 1038468
Thanks Meter: 52
error 3194 mean u trying this one old firmware, try the latest iOS 7 and you will succeed in your update
Old 09-25-2013, 13:49   #6 (permalink)
Member: 1418524
Thanks Meter: 186
yes now ios7 update Done thank all brother"s
Old 09-25-2013, 14:11   #7 (permalink)
Member: 1418524
Thanks Meter: 186
now ios7 update occurred {1}
Old 09-26-2013, 09:13   #8 (permalink)
Member: 735126
Thanks Meter: 11
so we can not restore from ios6 to for example 6.1.3 or 6.1.4? Only ios7 from last week?
Old 09-26-2013, 12:47   #9 (permalink)
Moderator
loca|host's Avatar
Member: 363451
Sonork: 100.1577895
Thanks Meter: 834
"Normal" downgrade is no more available , since Apple has stopped signing old iOS 6.x
Old 09-26-2013, 12:54   #10 (permalink)
Member: 735126
Thanks Meter: 11
ok i understand but still have a problem with ip5... inside some ios 6.x.x and i try to put 6.1.3 or 6.1.4 (by itunes dfu mode + shift etc...) and its the same error 3194 grrrrr
Old 09-26-2013, 13:00   #11 (permalink)
Moderator
loca|host's Avatar
Member: 363451
Sonork: 100.1577895
Thanks Meter: 834
For now you can't .
Stick to your current version ( jailbreakable ) , or update to iOS 7 .
The Following User Says Thank You to loca|host For This Useful Post:
Old 09-27-2013, 11:11   #12 (permalink)
Member: 735126
Thanks Meter: 11
all time the same error 3194
- reinstall itunes,
- change pc,
- usb,
- edit "hosts" in C:/windows/system32/drivers/etc/
no results
finally with ios 7.0.2 was without error!
Old 10-01-2013, 10:14   #13 (permalink)
Member: 1418524
Thanks Meter: 186
iPhone5,2_7.0.2_11A501_Restore
error occurred 3
Old 10-01-2013, 11:14   #14 (permalink)
Moderator
loca|host's Avatar
Member: 363451
Sonork: 100.1577895
Thanks Meter: 834
error occurred 3
Error 3 is usually reported as faulty baseband .
Post more details about your iPhone intitial state ( recovery , normal ... ) and from / to wich version are you restoring .
Old 10-01-2013, 13:05   #15 (permalink)
Member: 1418524
Thanks Meter: 186
phone recovery mode
try install iPhone5,2_7.0.2_11A501_Restore
Page generated in 0.20924 seconds with 8 queries
