Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 5 / iPhone 5S / iPhone 5C / iPhone SE
Old 07-02-2014, 19:17   #16 (permalink)
Member: 727850
Sonork: 100.1625445
Thanks Meter: 3
just change pc and usb cable driect plugged in board download Ipsw again and flash it twice
Old 07-05-2014, 18:46   #17 (permalink)
Member: 727850
Sonork: 100.1625445
Thanks Meter: 3
simply run ipsw again with mac book
Old 07-05-2014, 18:47   #18 (permalink)
Member: 727850
Sonork: 100.1625445
Thanks Meter: 3
simply ipsw install again with mac book
Old 07-05-2014, 18:50   #19 (permalink)
Member: 727850
Sonork: 100.1625445
Thanks Meter: 3
simply reinstall ipsw with mac book
Old 01-26-2015, 09:20   #20 (permalink)
ameerali19's Avatar
Member: 884639
Sonork: 100.1597105
Thanks Meter: 266
Iphone 5s stuck in recovery mode even after software complete
Hi friends,
i have an IPhone 5s , which stuck in recovery mode .
*: software is completing
*: tried by changing battery and and system connector (lightening)flex,
*: tried in different PC
*: tried by removing screen and camera
*: tried Recboot / tiny umberlla and redsn0w to exit, same
still same , the mode is not changing after complete software ...
any solution ??
Regards
Old 01-26-2015, 16:44   #21 (permalink)
Member: 1918158
Thanks Meter: 177
Originally Posted by ameerali19 View Post
Hi friends,
any solution ??
Regards
Don't worry! All you need is ReiBoot. It is a free iPhone reboot software program which allows you to enter and exit from Recovery Mode instantly, easier than learning 3-4 steps manually with iTunes to do so.
REIBOOT Step 1: connnect your iphone 5s to PC/Mac. Step 2: Click Exit Recovery Mode Button
then you can easily get out the ios 8 update cause stuck in red itunes logo recovery mode.
Old 02-18-2015, 09:22   #22 (permalink)
Member: 1097251
Sonork: monk
Thanks Meter: 13
Originally Posted by mihut View Post
Congratulations Your problem i solved.
Mod sir, kindly close this thread the problem of that person solved.
Never lose hope
i changed battery on iphone 6plus,serviced connector and restored without full lcd cables...still stuck on error 4013...any other solution? before closing the thread
Old 02-18-2015, 09:39   #23 (permalink)
rogerboogie's Avatar
Member: 103024
Thanks Meter: 616
error 4013 and blue screen is related to:
1.- battery
2.- open Lines under the base of the screw on second layer of the board
3.- u2 ic
4.- some other shorted parts generating low voltage
5.- u16
sometimes on restore , low usb power , better use 3.0 usb if is avalible and never use usb hubs , always connect direct usb port
The Following User Says Thank You to rogerboogie For This Useful Post:
Old 04-15-2015, 07:16   #24 (permalink)
Member: 1033148
Sonork: 100.1622890
Thanks Meter: 8
just restore without front camera cable
Old 04-28-2015, 07:51   #25 (permalink)
Member: 2032057
Thanks Meter: 2
Sir., my i phone 5s i am change my display and center body then my finger lock is not working............
any solution please help........
home button is working but finger lock only not working ..........
please help...........
thanks in advance................pls..........
Old 04-28-2015, 09:15   #26 (permalink)
Member: 8133
Thanks Meter: 72
I have a strange issue.
Flashed a iphone 5 with screen off and camera off, via DFU mode. Al went through no problem.
BUT now when i try to set up phone, and i select country phone screen goes into "connect to itunes" screen!
Is it fixable?
Old 05-01-2015, 19:43   #27 (permalink)
Member: 5925
Sonork: 1656703
Thanks Meter: 3
Re hort pow ic 100%%%%%%%%%%%%%%%%
Old 05-02-2015, 13:58   #28 (permalink)
Member: 2362382
Sonork: 9897654
remove antenas cables and rehot ic that is near
Old 06-05-2015, 02:27   #29 (permalink)
Member: 2398349
Thanks Meter: 62
sometimes it happens wen u use a after market part on the phone. open the phone and check what had been changed. change it back with the original part, u'll be just fine. the most common part for this error is the screen or sensor. so restore the phone without screen or sensor to see if its working or not and let me know!!
Old 08-24-2016, 13:39   #30 (permalink)
Member: 364824
Thanks Meter: 2
try to use original cable and try restore online
The Following User Says Thank You to minirogy For This Useful Post:
Page generated in 0.21495 seconds with 8 queries
