03-29-2014, 13:41 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | 3g can't jailbrealk after restore 4.1 I restore with itune 4.1 When jailbreaking with redsn0w_win_0.9.6b6, redsnow exe doesnt goes further after detecting dfu device, Need help |
04-02-2014, 07:46 | #5 (permalink) |
Member: 1086393 Status: Offline Thanks Meter: 771 | I try with different pc also, Other phone works on my pc, but this phone always stuck on "waiting for reboot" I successfully restore 4.1 without any problem , but can't jailbreak, I have tried with redsn0w version. Need solution |
04-02-2014, 10:31 | #7 (permalink) |
Freak Poster Join Date: Apr 2011 Location: punjab
Member: 1562820 Status: Offline Sonork: [email protected] Thanks Meter: 32 | Use ccleaner pc software clean all temp file then jailbreak again 100% work |
04-08-2014, 13:25 | #12 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Create a folder on your desktop called Pwnage Download RedSn0w from here and place it in the Pwnage folder. Likewise, download the latest 4.1 firmware from below and place it in the same folder. http://cdn.nspwn.com/redsn0w_win_0.9.6b4.zip 4.1 (3G): iPhone1,2_4.1_8B117_Restore.ipsw http://appldnld.apple.com/iPhone4/06...7_Restore.ipsw Extract the redsn0w executable from the RedSn0w zip file into the same folder. Connect your iPhone to the computer and launch iTunes. Select your iPhone from the list of devices on the left. Now hold down Shift and click the Restore button. Restore is preferred as it won't create any wasted space on your iPhone. Navigate to the Pwnage folder on your desktop and select the 4.1 firmware ipsw. Click the Choose button to continue. Once iTunes has finished updating your iPhone to the desired firmware open the Pwnage folder on your desktop and launch the redsn0w application from the redsn0w folder we extracted earlier. Once RedSn0w opens click the Browse button Select the 4.1 firmware ipsw we placed in the Pwnage folder on our desktop then click Open. Once the firmware has been verified click the Next button to continue. RedSn0w will now prepare the jailbreak data From this window you can select the jailbreak options you would like. Verbose boot displays detailed information on boot of your device and is generally only needed by developers and advanced users. Make sure Cydia is selected. For this tutorial we will also select Custom boot logo and Custom recovery logo. When you click to select each custom logo option a dialog window will appear asking you to select the image. Locate the image you would like to use then press the Open button. RedSn0w has options to Enable multitasking, Enable homescreen wallpaper, and Enable battery percentage. If you do not need multitasking we would recommend deselecting it as it makes your iPhone 3G run very slow. Click the Next button to continue RedSn0w will now guide you through the steps to get into DFU mode. You can find more help with DFU mode Your iPhone will now reboot Once this is complete you will be notified that RedSn0w is done. Click the Finish button. When your iPhone finishes rebooting (5 minutes or so) it will be jailbroken with Cydia on the SpringBoard. |
