03-02-2023, 13:43 | #9 (permalink) |
Junior Member Join Date: Feb 2023 Location: Boston, USA Age: 32
Member: 3033154 Status: Offline Thanks Meter: 0 | WhatsApp no longer supports the iPhone 4, as it requires iOS 10 or later to run, and the iPhone 4 can only run up to iOS 7.1.2. This means that you won't be able to sign in to WhatsApp on your iPhone 4. If you need to use WhatsApp, you will need to upgrade to a newer iPhone model that supports iOS 10 or later. Some older iPhone models that support iOS 10 include the iPhone 5, iPhone 5s, and iPhone SE. Alternatively, you can use WhatsApp Web on your computer's web browser to access your WhatsApp account and send messages to your contacts. To do this, simply go to WhatsApp and scan the QR code with your iPhone's camera. Then, follow the prompts to sign in to your account and start using WhatsApp on your computer. |
06-12-2023, 02:23 | #10 (permalink) |
Junior Member Join Date: Jan 2022 Location: Philippines Age: 45
Member: 3005567 Status: Offline Sonork: awindeyer1226 Thanks Meter: 0 | I'd be happy to help you with signing in to WhatsApp on your iPhone 4. However, please note that WhatsApp officially ended support for iPhone 4 and older devices starting from February 1, 2020. Anyway, have you tried updating your software? If not, I think that should fix your problem. |
09-08-2023, 02:48 | #13 (permalink) |
Member: 3005567 Status: Offline Sonork: awindeyer1226 Thanks Meter: 0 | As long as you follow the process, I don’t see any part of you struggling. I do think that QR Code functionality is not supported there yet but it’s good. |
