06-16-2009, 22:40 | #1 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 240946 Status: Offline Thanks Meter: 10 | Iphone 3g not recognised by itunes - not going into DFU mode Currently on 2.2.1 and 5.08 bootloader, used fuzzy to downgrade then unlocked via 'yellowsn0w' Everything was fine, but someone installed an app adn the iphone crashed, nothing on the screen but alarm was still going off and phone was ringing (but nothing came on the screen at all), using the search function, it said that my best option was to restore... itunes recognised the phone, i pressed shift/restore and used the 2.2.1 which i have... i had an error (cant remember which one) and now the phone has the cable on the screen and iTunes... when i connect to the pc it says 'itunes must check the software update server to identify the device. to enable automatic updates.... blah blah blah' The only options are 'check' and 'cancel' when i cancel, the phone's no longer seen by itunes.... can anyone help me out? What do i do? Last edited by Cals; 06-16-2009 at 22:40. Reason: wrong location for picture |
02-05-2015, 10:07 | #3 (permalink) |
Junior Member Join Date: Feb 2015
Member: 2341196 Status: Offline Thanks Meter: 0 | If you try to restore your iPhone while in DFU mode, you will get an error from iTunes along with an error code, which you will have to search for on Apple’s website to get a complete description. This error usually appears if you are trying to restore a jailbroken iPhone. And next you need to turn for FonePaw iPhone Data Recovery for help, which can save the lost data from your unrecognised iPhone directly, and ever support you to restore backup files from iTunes or iCloud. |
@@..iPhone How to Put an iPhone Into DFU Mode by mobi_soft..@@ | mobi_soft | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 12-09-2009 13:26 |
iphone won't go in DFU mode | kushstha | iPhone 2 / iPhone 3G / iPhone 3GS | 9 | 10-13-2008 04:59 |
N93 will not go into test mode | Mobile2001 | Federal One | 1 | 10-17-2006 11:25 |
D500 not going into TAT mode | dagger_meerkat | SWIFT Platform | 6 | 05-12-2005 07:33 |
X70 not going into test mode | tical | Griffin | 1 | 10-21-2004 21:01 |
