04-21-2010, 10:03 | #1 (permalink) |
Junior Member Join Date: Aug 2006
Member: 338366 Status: Offline Thanks Meter: 1 | IPHONE 3GS Consume Battery |
04-21-2010, 16:34 | #4 (permalink) | |
Registered User Join Date: Sep 2002 Location: unknown Age: 42
Member: 15353 Status: Offline Thanks Meter: 15 | Quote:
04-21-2010, 18:19 | #5 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1284512 Status: Offline Thanks Meter: 0 | For those affected by a short battery lifespan either on the iPhone 3G or the iPhone 3GS, in order to conserve some energy, Push Notifications can be turned off from the Setting menu. Turning off Bluetooh (Settings>General) and Wi-Fi can also help with that. As a last resort, 3G connectivity can be turned off from Settings>General>Network. But is crippling your phone's connectivity really the best way to longer battery life? win a free ipod |
04-21-2010, 18:22 | #6 (permalink) |
Freak Poster Join Date: Oct 2008 Location: in your Hart
Member: 882699 Status: Offline Thanks Meter: 8 | The simplest ways to get improved iPhone 3GS battery life are: * Keep your iPhone 3GS near room temperature and out of the sun * Avoid heavy use of applications that use location services such as Maps - disable location services by going to Settings > General > Location Services. * Fetch new data less frequently * Turn off push email and auto-check fewer email accounts * Turn off Wi-Fi. However, if you use your iPhone to access the internet for long periods of time, choosing Wi-Fi over 3G may use less battery power. * Turn off Bluetooth when not in use. * Adjust screen brightness: either dim the screen or turn on Auto Brightness to allow the screen to adjust its brightness based on current lighting conditions. * Turn off EQ in iPod settings. * Turn off 3G. You will still be able to make and receive calls and access cellular data networks via Edge or GPRS where available. |
04-23-2010, 03:44 | #8 (permalink) |
Member: 338366 Status: Offline Thanks Meter: 1 | iphone 3gs consume battery thanks to all those who replies. all the way u all teaching here i have used it. battery changed before . set have been open n checked that are no liquid immersed . close all wifi or 3 g while not using it . but the problem still there . answer call battery FLAT. once battery flat . u cant even recharge it . u need to unplug the battery to the other iphone to charge till around 20 or 30 % then u transfer back then it can be charged normally . |
The Following User Says Thank You to bc4896 For This Useful Post: |
05-03-2010, 07:47 | #9 (permalink) |
Freak Poster Join Date: Mar 2007 Location: Heidelberg
Member: 458909 Status: Offline Thanks Meter: 33 | What replacement battery did you use? There is a difference between 3g and 3gs battery. 3g batt will turn iphone 3gs on, but wont indicate battery level properly. Will show full, but switch off during call. |
5110 hardware prblem ( battery drain fast) | Fai555 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-09-2001 03:06 |
Ultra Slim Vibra Battery? | ZF | Nokia Hardware & Hardware Repair | 2 | 11-10-2000 15:12 |
GSM Cables, Dual SIM Covers/Batteries | jat | Main Sales Section | 1 | 10-04-2000 17:52 |
looking schematic for nokia5161 battery with vibra | dofie | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-13-2000 22:48 |
Li-ion batteries for your cellular phones | hankong | Main Sales Section | 0 | 10-02-1999 05:38 |
