![]() | #1666 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 ![]() | Quote:
![]() | #1667 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2016 Location: Zimbabwe
Member: 2524486 Status: Offline Thanks Meter: 112 ![]() | Samsung J3 2016 Hang On Logo Fixed By Ufst Quote:
The Following User Says Thank You to julius84 For This Useful Post: |
![]() | #1668 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2005 Location: America
Member: 138781 Status: Offline Thanks Meter: 873 | redmi 5 Rosy - frp full test Quote:
The Following User Says Thank You to cellcarcol For This Useful Post: |
![]() | #1669 (permalink) |
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 ![]() | Samsung SM-J120G Flashing done Samsung SM-J120G (J1 (2016) LTE) at Auto Select Flash Port [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00.175 PIT Backup Saved as: SM-J120G_Read.pit File: J120GDXU2ARB1_J120GOLB2ARB1_J120GDXU2ARA2_HOME.tar .md5 Partition: BOOTLOADER, Image: sboot.bin, Size: 0x00158910 (1.35 MB) Partition: BOOT, Image: boot.img, Size: 0x00744920 (7.27 MB) Partition: RECOVERY, Image: recovery.img, Size: 0x0081C920 (8.11 MB) Partition: SYSTEM, Image: system.img, Size: 0x8545AA60 (2.08 GB) Partition: CACHE, Image: cache.img, Size: 0x0421E120 (66.12 MB) Partition: HIDDEN, Image: hidden.img, Size: 0x008F0120 (8.94 MB) Partition: RADIO, Image: modem.bin, Size: 0x01F1A9D0 (31.1 MB) Flash Write Done: 02:05.976 Restart Done |
The Following User Says Thank You to 4G Telecom For This Useful Post: |
![]() | #1670 (permalink) | |
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 ![]() | LYF-F50Y Flashing Done Quote:
![]() | #1671 (permalink) | |
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 ![]() | XIAOMI-Redmi 5 Rosy Format Done................. Quote:
![]() | #1672 (permalink) | |
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 ![]() | XIAOMI-Redmi 5A Riva User data format Done........... Quote:
![]() | #1673 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Karachi
Member: 388703 Status: Offline Sonork: sheerazi Thanks Meter: 187 | VGOTEL Ocean6 Pattern & FRP Remove Done SPRD SC7731 (eMMC) at AutoSelect Port [CAL] {Factory Info} Insert Cable to Switched OFF Device CAL_MODE: FE8E CAL_DEVT: SP09 CA_CPVER: Platform Version: MOCORTM_W17.14.5_DebugProject Version: sc7731C_CP0_modemBASE Version: TM_BASE_W17.14.5HW Version: sc7731C_CP0_modem04-07-2017 14:07:41 CA_APVER: VGOTEL_OCEAN_6_V06_26122017 CA_SERN1: S5001K2731803006169 CA_CALST: PASS CA_IMEI1: 356549-08-125118-9 CA_BTID : 24:0D:65:B6:77:25 CA_WIFI : 24:0D:65:B6:B2:E9 SPRD SC7731 (eMMC) at AutoSelect Port [CAL] {Factory Def.} Insert Cable to Switched OFF Device CAL_MODE: D500 CAL_DEVT: SP09 Factory Default Done: OK SPRD SC7731C (eMMC) at USB Auto Select [SPRD] {Reset FRP} BOOT: FDL1 and FDL2 from Default [Fdl] SC7731C_1_fdl Hold Vol+, Vol- and Insert Cable to Switched OFF Device FDLA: 50000000, 9F000000 FDLI: SA2F034C355EE94BE5 FDLI: SAF272EF29F9E18706 SROM: SPRD3 FDL1: FDL2: Ok, 96 Reset FRP Done in: 00:00.190 Restart Done, Disconnect Cable All Done in: 00:38.942 |
![]() | #1674 (permalink) | |
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 ![]() | Samsung SM-J810G Flashing Done Quote:
![]() | #1675 (permalink) |
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 ![]() | Var ITEL-A40 (A40 LTE DS U269) at USB Auto Select [SPRD] {Format Flash} BOOT: FDL1 and FDL2 from Default [Fdl] SC9832A_3_fdl Hold Vol+, Vol- and Insert Cable to Switched OFF Device FDLA: 50000000, 9F000000 FDLI: SA3D94E49454599E6A FDLI: SA764B8A18B67F6721 SROM: SPRD3 FDL1: FDL2: Ok, 96 Erase userdata Partition, Done in: 00:26.135 Restart Done, Disconnect Cable All Done in: 01:18.505 |
![]() | #1676 (permalink) | |
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 ![]() | Samsung SM-G600FY flashing Quote:
![]() | #1677 (permalink) | |
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 ![]() | LAVA-Z10 3GB Format Done Quote:
![]() | #1679 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 781 ![]() | -=Motorola XT2025-2 (Moto E6 Plus LTE DS Pokerp)=- {Write Flash} Quote:
BR, -=MR_GSM=- | |
![]() | #1680 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2008 Location: GSM,Pakistan
Member: 811049 Status: Offline Thanks Meter: 106 | qmobile q smart 4g logo hang done by UFST. SPRD SC9820E (eMMC) at AutoSelect Port [CAL] {Factory Def.} Insert Cable to Switched OFF Device CAL_MODE: FE8E CAL_DEVT: SP09 Factory Default Done: OK |
The Following User Says Thank You to Mian Jahangir I For This Useful Post: |
