01-03-2021, 06:32 | #4006 (permalink) |
No Life Poster Join Date: Dec 2009 Location: PAKISTAN
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | G935F imei Repair Done Printing phone history Patch Certificate 11/9/2020 1:02 PM Repair IMEI 12/19/2019 10:04 AM Patch Certificate 12/19/2019 9:33 AM Get Info 12/19/2019 9:32 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G935F Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Mon Mar 9 17:22:40 KST 2020 PDA Version: G935FXXS8ETC1 [march 2020, rev1] Phone Version: G935FXXS8ETC1 [march 2020, rev1] CSC Version: G935FOXA8ETC1 [march 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: RF8J21FYQTZ Imei: 35362107XXXXXXX Battery Status: 3.80V (24%) Network Type: GSM SIM Status: READY Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-03-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.31.20 12:33:46] WorkID: 120611920 |
The Following User Says Thank You to qasir_amz For This Useful Post: |
01-03-2021, 06:33 | #4007 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | J400F Latest Securiety imei Repair Done Chimera Mobile Phone Utility version: 27.00.1135 @ 2020-12-31 Printing phone history Read Cert 12/31/2020 10:41 AM Read Cert 12/31/2020 10:35 AM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J400F Carrier ID: XSG Sales Code: PAK Country Code: PAKISTAN Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Wed Sep 16 22:31:50 KST 2020 PDA Version: J400FXXS7CTI2 [september 2020, rev2] Phone Version: J400FXXS7CTI2 [september 2020, rev2] CSC Version: J400FOJM7CTI2 [september 2020, rev2] Board Platform: UNIVERSAL7570 Modem Platform: SHANNON305 Serial Number: RZ8K52354WH Imei: 358129090XXXXXX Imei2: 358130090XXXXXX Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-09-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 35812909XXXXXXX Repaired imei: 35709107XXXXXXX Current imei2: 3581300XXXXXXXX Repaired imei2: 3570920XXXXXXXX Successfully finished. Finished at local time: [12.31.20 15:51:24] WorkID: 120630638 |
01-04-2021, 08:41 | #4008 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | A510Y imei Repair Done Chimera Mobile Phone Utility version: 27.00.1135 @ 2021-01-04 Printing phone history Patch Certificate 1/4/2021 7:29 AM Repair IMEI 1/4/2021 7:27 AM Repair IMEI 1/4/2021 7:24 AM Read Cert 1/4/2021 7:20 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A510Y Sales Code: XTC Country Code: PHILIPPINES Timezone: Asia/Karachi Android Version: 6.0.1 [MMB29K] [SDK 23] Build Date: Mon Apr 10 17:19:17 KST 2017 PDA Version: A510YDXU4BQD2 [april 2017, rev2] Phone Version: A510YDXU4BQD1 [april 2017, rev1] CSC Version: A510YOLC4BQD2 [april 2017, rev2] Board Platform: EXYNOS5 Modem Platform: SHANNON310 Serial Number: R58H231XNHN Imei: 3598380810XXXXX Imei2: 3598380860XXXXX Battery Status: 3.74V (35%) Network Type: GSM SIM Status: READY,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-04-01 Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 2.79:SUPERSU Checking boot image. Be patient! Do NOT disconnect the phone! Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [01.04.21 12:32:51] WorkID: 120883511 |
01-04-2021, 12:13 | #4009 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | G973F S10 Successful write Patch Certificate Chimera Mobile Phone Utility version: 27.00.1135 @ 2021-01-04 Printing phone history Patch Certificate 1/4/2021 10:45 AM Repair IMEI 1/4/2021 10:42 AM Repair IMEI 1/4/2021 10:25 AM Repair IMEI 1/4/2021 9:52 AM Repair IMEI 1/4/2021 9:37 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G973F Country Code: UK Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Sep 18 16:40:15 KST 2020 PDA Version: G973FXXS9DTI8 [september 2020, rev8] Phone Version: G973FXXS9DTI8 [september 2020, rev8] CSC Version: G973FCKH9DTI9 [september 2020, rev9] Board Platform: UNIVERSAL9820 Modem Platform: SHANNON5000 Serial Number: RF8MB2ND8HN Imei: 359838081XXXXXX Imei2: 359838086XXXXXX Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-10-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.04.21 15:47:07] WorkID: 120904602 |
01-04-2021, 12:14 | #4010 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | G925F Network Unlock Chimera Mobile Phone Utility version: 27.00.1135 @ 2021-01-04 Network Factory Reset started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G925F Sales Code: FTM Country Code: France Timezone: Asia/Karachi Android Version: 7.0 [NRD90M] [SDK 24] Build Date: Wed Jun 20 16:33:32 KST 2018 PDA Version: G925FXXU6ERF5 [june 2018, rev5] Phone Version: G925FXXU6ERF8 [june 2018, rev8] CSC Version: G925FFTM6ERF1 [june 2018, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: R58H11AV2HY Imei: 3543040834XXXX Battery Status: 3.97V (51%) Network Type: GSM SIM Status: NETWORK_LOCKED Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-06-01 Doing Network Factory Reset Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Calculating. Be patient! Do NOT disconnect the phone! Patched modem detected. Writing secure image. Network configuration was set to factory default. Successfully finished. Finished at local time: [01.04.21 15:52:33] WorkID: 120905275 |
01-04-2021, 19:10 | #4011 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | Ldn-l21 frp unlock done Chimera Mobile Phone Utility version: 27.00.1135 @ 2021-01-04 Removing factory reset protection... Collecting information about the device... Removing factory reset protection lock... It did not work. Removing factory reset protection lock... It did not work. Checking if factory challenge needed... Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... It did not work. Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... It did not work. Reading factory challenge... Calculating response for the challenge... This may take a while. Be patient! Do NOT disconnect the phone! Sending response to the device... Checking if the factory challenge-response succeed... Wiping device... Finished at local time: [01.04.21 18:08:05] WorkID: 120969262 |
The Following User Says Thank You to jseyedanas For This Useful Post: |
01-06-2021, 07:02 | #4012 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | G975f S10 Plus successful patchcertificate Chimera Mobile Phone Utility version: 27.00.1135 @ 2021-01-06 Printing phone history Patch Certificate 1/6/2021 5:56 AM Repair IMEI 1/6/2021 5:50 AM Repair IMEI 1/4/2021 12:01 PM Repair IMEI 1/4/2021 11:06 AM Reboot 1/4/2021 5:47 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G975F Carrier ID: XEH Sales Code: PAK Country Code: PAKISTAN Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Aug 28 16:43:53 KST 2020 PDA Version: G975FXXU8DTH7 [august 2020, rev7] Phone Version: G975FXXU8DTH7 [august 2020, rev7] CSC Version: G975FOXM8DTH7 [august 2020, rev7] Board Platform: UNIVERSAL9820 Modem Platform: SHANNON5000 Serial Number: R58M836KSKW Imei: 359544059XXXXX Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-09-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.06.21 10:58:59] WorkID: 121138307 |
01-06-2021, 12:04 | #4013 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | G935F U8 Repair imei Chimera Mobile Phone Utility version: 27.00.1135 @ 2021-01-06 Printing phone history Repair IMEI 1/6/2021 10:34 AM Read Cert 1/6/2021 10:32 AM Read Cert 1/6/2021 10:26 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G935F Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Mon Mar 9 17:22:40 KST 2020 PDA Version: G935FXXS8ETC1 [march 2020, rev1] Phone Version: G935FXXS8ETC1 [march 2020, rev1] CSC Version: G935FOXA8ETC1 [march 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: RF8H52E94LX Imei: 3568300XXXXXXXX Battery Status: 4.05V (82%) Network Type: GSM SIM Status: READY Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2020-03-01 Preparing... Checking root access. The phone is rooted by: 20.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.06.21 15:36:52] WorkID: 121160161 |
01-11-2021, 05:48 | #4014 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | A520F U17 Successful Repair imei Chimera Mobile Phone Utility version: 27.00.1135 @ 2021-01-09 Printing phone history Patch Certificate 1/9/2021 10:01 AM Repair IMEI 1/9/2021 9:59 AM Read Cert 1/9/2021 9:58 AM Read Cert 1/9/2021 9:57 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520F Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Mon Sep 28 13:05:52 KST 2020 PDA Version: A520FXXUGCTI9 [september 2020, rev9] Phone Version: A520FXXUGCTI9 [september 2020, rev9] CSC Version: A520FOXAGCTJ1 [october 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R58K32Y1D2N Imei: 35574609XXXXXXX Battery Status: 3.78V (15%) Network Type: GSM SIM Status: READY Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-09-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.09.21 15:03:15] WorkID: 121492249 |
01-13-2021, 13:13 | #4015 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | after hard work G975f u9 Reapir imei done Chimera Mobile Phone Utility version: 27.20.0814 @ 2021-01-13 Printing phone history Patch Certificate 1/13/2021 12:09 PM Repair IMEI 1/13/2021 12:06 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G975F Carrier ID: EVR Sales Code: XEF Country Code: France Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Sep 18 16:39:22 KST 2020 PDA Version: G975FXXS9DTI8 [september 2020, rev8] Phone Version: G975FXXS9DTI8 [september 2020, rev8] CSC Version: G975FOXM9DTIC [september 2020, revC] Board Platform: UNIVERSAL9820 Modem Platform: SHANNON5000 Serial Number: R58M439A4SV Imei: 35574709XXXXXX Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-10-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.13.21 17:10:42] WorkID: 121893972 |
01-13-2021, 16:54 | #4016 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,928 | reply Hello! Thank you for the feedback! Quote:
01-15-2021, 15:41 | #4017 (permalink) |
Freak Poster Join Date: Jun 2016 Location: MOROCCO Age: 34
Member: 2586350 Status: Offline Thanks Meter: 81 | 👉 Unlock Network SamsunG G570F Code: Chimera Mobile Phone Utility version: 27.23.1432 @ 2021-01-14 Printing phone history Network Factory Reset 14/01/2021 17:05 Network Factory Reset 14/01/2021 17:04 Network Factory Reset 14/01/2021 16:55 Network Factory Reset started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G570F Sales Code: CAC Country Code: Central Asia Timezone: Africa Android Version: 7.0 [NRD90M] [SDK 24] Build Date: Thu Dec 14 14:05:51 KST 2017 PDA Version: G570FXXU1BQL2 [december 2017, rev2] Phone Version: G570FXXU1BQI9 [september 2017, rev9] CSC Version: G570FOXE1BQL1 [december 2017, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: R5XXXXXXXX Imei: 3560000000000000 Imei2: 3560000000000000 Battery Status: 4.16V (82%) Network Type: GSM SIM Status: NETWORK_LOCKED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-12-01 Doing Network Factory Reset Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Writing secure image. Network configuration was set to factory default. Successfully finished. Finished at local time: [01.14.21 18:17:29] WorkID: 122 |
The Following User Says Thank You to perata For This Useful Post: |
01-17-2021, 07:19 | #4018 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | A105F Successful Repair imei Chimera Mobile Phone Utility version: 27.23.1432 @ 2021-01-17 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105FN Carrier ID: BTU Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Jul 2 20:40:37 KST 2019 PDA Version: A105FNXXU2ASG1 [july 2019, rev1] Phone Version: A105FNXXU2ASG1 [july 2019, rev1] CSC Version: A105FNOXM2ASG1 [july 2019, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RZ8N21MQQ2P Imei: 353337115473018 Imei2: 353338115473016 Battery Status: 3.96V (58%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-07-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 353337115XXXXX Repaired imei: 35212311XXXXXX Current imei2: 353338115XXXXX Repaired imei2: 35212411XXXXXX Successfully finished. Finished at local time: [01.17.21 11:00:50] WorkID: 122285706 |
01-17-2021, 11:52 | #4019 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | Note8 N950N Successful Repair Network Chimera Mobile Phone Utility version: 27.23.1432 @ 2021-01-17 Printing phone history Get Info 1/17/2021 10:47 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N950N Carrier ID: KTC Sales Code: SKC Country Code: KOREA Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri Sep 27 15:07:42 KST 2019 PDA Version: N950NKSU5DSI4 [september 2019, rev4] Phone Version: N950NKOU5DSH1 [august 2019, rev1] CSC Version: N950NOKR5DSI4 [september 2019, rev4] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: R39J901MG8 Imei: 357543082XXXXXX Battery Status: 4.16V (80%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-08-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.17.21 15:48:55] WorkID: 122297445 |
01-17-2021, 13:07 | #4020 (permalink) |
Member: 1185918 Status: Offline Sonork: 100.1617322 Thanks Meter: 430 | G973F NETWORK repair don Chimera Mobile Phone Utility version: 27.23.1432 @ 2021-01-17 Printing phone history Patch Certificate 1/17/2021 12:00 PM Repair IMEI 1/17/2021 11:57 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G973F Carrier ID: XEU Country Code: UK Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Sep 18 16:40:15 KST 2020 PDA Version: G973FXXS9DTI8 [september 2020, rev8] Phone Version: G973FXXS9DTI8 [september 2020, rev8] CSC Version: G973FCKH9DTI9 [september 2020, rev9] Board Platform: UNIVERSAL9820 Modem Platform: SHANNON5000 Serial Number: RF8MB0WR8AT Imei: 359838082XXXXXX Imei2: 359838087XXXXXX Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-10-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.17.21 17:02:19] WorkID: 122301537 |
