05-26-2019, 11:37 | #3601 (permalink) |
Insane Poster Join Date: Apr 2013
Member: 1927285 Status: Offline Sonork: Abdu Thanks Meter: 21 | Sm-g965f patch cert done Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G965F Sales Code: SER Country Code: Russia Timezone: Asia/Tashkent Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Thu Dec 20 07:52:17 KST 2018 PDA Version: G965FPUU2CRLI [december 2018, revI] Phone Version: G965FXXS3CSD2 [april 2019, rev2] CSC Version: G965FSER2CRLI [december 2018, revI] Product Code: SER HIDSw Version: G965FPUU2CRLI/G965FSER2CRLI/G965FXXS2CSD2/G965FPUU2CRLI Board Platform: EXYNOS5 Modem Platform: SHANNON360 Serial Number: R58K75B9FCE Imei: 35************* Unique Number: CE031823633B1025057E Connections: AT,MTP Battery Status: 3.94V (59%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-12-01 Data Encryption State: unsupported Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 19.2:MAGISKSU Checking boot image. Be patient! Do NOT disconnect the phone! The knox is still valid. Because of the boot patch the warranty will void. Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. Do not check the status of the imei! It is important that the SIM card is on the phone at startup and the PIN authentication is turned OFF. The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [05.26.19 15:07:03] |
The Following User Says Thank You to Mr-snek For This Useful Post: |
05-26-2019, 12:34 | #3602 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,709 | S9 plus patch cert done Code: Chimera Mobile Phone Utility version: 21.22.1406 @ 2019-05-25 Printing phone history Patch Certificate 5/25/2019 4:15:45 PM Knoxguard Unlock 5/25/2019 3:52:49 PM Knoxguard Unlock 5/25/2019 2:19:35 PM Repair IMEI 5/25/2019 1:12:49 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G965F Sales Code: TUR Country Code: TURKEY Timezone: Europe/Istanbul Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Apr 1 08:48:42 KST 2019 PDA Version: G965FXXS3CSD1 [april 2019, rev1] Phone Version: G965FXXS3CSD2 [april 2019, rev2] CSC Version: G965FOXM3CSD1 [april 2019, rev1] Product Code: TUR HIDSw Version: G965FXXS3CSD1/G965FOXM3CSD1/G965FXXS3CSD2/G965FXXS3CSD1 Board Platform: EXYNOS5 Modem Platform: SHANNON360 Serial Number: RF********* Imei: 86************* Unique Number: CE1*********** Connections: AT,MTP Battery Status: 3.86V (50%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-04-01 Data Encryption State: unsupported Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 18.1:MAGISKSU (topjohnwu) Checking boot image. Be patient! Do NOT disconnect the phone! The knox is still valid. Because of the boot patch the warranty will void. Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. Do not check the status of the imei! It is important that the SIM card is on the phone at startup and the PIN authentication is turned OFF. The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [05.25.19 19:19:10] WorkID: 60722041 |
05-28-2019, 00:13 | #3603 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | [world 1st] samsung g900a reactivation lock reset done Chimera Mobile Phone Utility version: 21.25.1302 @ 2019-05-27 Printing phone history Reboot 5/27/2019 10:53:46 PM Reset Reactivation Lock 5/27/2019 7:06:19 PM Reset Reactivation Lock 5/27/2019 6:57:05 PM Reset reactivation lock started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G900A Sales Code: ATT Country Code: USA Timezone: Africa/Lagos Android Version: 6.0.1 [MMB29M] [SDK 23] Build Date: Wed Aug 3 20:17:03 KST 2016 PDA Version: G900AUCU4DPH2 [august 2016, rev2] Phone Version: G900AUCU4DPH2 [august 2016, rev2] CSC Version: G900AATT4DPH2 [august 2016, rev2] Product Code: SM-G900AZKAATT HIDSw Version: G900AUCU4DPH2/G900AATT4DPH2/G900AUCU4DPH2/G900AUCU4DPH2 Board Platform: MSM8974 Modem Platform: MSM8974PRO Serial Number: R38F60CXXXT Imei: 353411068891748 Unique Number: CMA006D499A2651 Connections: AT,MTP Battery Status: 3.71V (10%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Security Patch: 2016-08-01 Data Encryption State: unencrypted Rooting by generic root method 3... Rooting in progress. Be patient! Do NOT disconnect the phone! Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Not rooted. Root method failed. Checking custom root image... Present. Rooting by custom image-based root method... Switching to download mode. Waiting for download mode. Connecting. Reading PIT from phone. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Resetting reactivation lock... The operation is in progress. Succeeded. Successfully finished. Finished at local time: [05.28.19 00:05:03] WorkID: 60935889 |
05-28-2019, 23:04 | #3606 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 376826 Status: Offline Thanks Meter: 9 | Sm-A750G full - Knox Guard Unlock - Repair started - Patch certificate Knox Guard Unlock started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A750G Sales Code: TPA Country Code: PANAMA Timezone: America/Bogota Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Thu Mar 21 23:27:17 KST 2019 PDA Version: A750GUBU2BSC7 [march 2019, rev7] Phone Version: A750GNUBU2BSC7 [march 2019, rev7] CSC Version: A750GOWO2BSC7 [march 2019, rev7] Product Code: TPA HIDSw Version: A750GUBU2BSC7/A750GOWO2BSC7/A750GNUBU2BSC7/A750GUBU2BSC7 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R28KA1KY7VP Imei: 35999709446xxxx Unique Number: CDU00ACB053B2A5 Connections: AT,MTP Battery Status: 4.16V (91%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-03-01 Data Encryption State: unencrypted Unlocking KnoxGuard... The operation is in progress. Be patient! Do NOT disconnect the phone! Current state: Prenormal New state: Completed Succeeded! Successfully finished. Finished at local time: [05.28.19 16:11:02] WorkID: xxxxxxx Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A750G Sales Code: TPA Country Code: PANAMA Timezone: America/Bogota Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Thu Mar 21 23:27:17 KST 2019 PDA Version: A750GUBU2BSC7 [march 2019, rev7] Phone Version: A750GNUBU2BSC7 [march 2019, rev7] CSC Version: A750GOWO2BSC7 [march 2019, rev7] Product Code: TPA HIDSw Version: A750GUBU2BSC7/A750GOWO2BSC7/A750GNUBU2BSC7/A750GUBU2BSC7 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R28KA1KY7VP Imei: 35999709446xxxx Unique Number: CDU00ACB053B2A5 Connections: AT,MTP Battery Status: 4.17V (90%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-03-01 Data Encryption State: unencrypted Repair imei... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Repaired IMEI: 35999709446xxxx If necessary, use the patch cert procedure. Succeeded. Successfully finished. Finished at local time: [05.28.19 16:17:28] WorkID: xxxxxx Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A750G Sales Code: TPA Country Code: PANAMA Timezone: America/Bogota Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Thu Mar 21 23:27:17 KST 2019 PDA Version: A750GUBU2BSC7 [march 2019, rev7] Phone Version: A750GNUBU2BSC7 [march 2019, rev7] CSC Version: A750GOWO2BSC7 [march 2019, rev7] Product Code: TPA HIDSw Version: A750GUBU2BSC7/A750GOWO2BSC7/A750GNUBU2BSC7/A750GUBU2BSC7 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R28KA1KY7VP Imei: 35999709446xxxx Unique Number: CDU00ACB053B2A5 Connections: AT,MTP Battery Status: 4.12V (90%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-03-01 Data Encryption State: unencrypted Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 19.1:MAGISKSU Checking boot image. Be patient! Do NOT disconnect the phone! The knox is still valid. Because of the boot patch the warranty will void. Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [05.28.19 16:23:03] WorkID: xxxxxx |
05-31-2019, 16:02 | #3608 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Lg g4 [h815] imei repair done Chimera Mobile Phone Utility version: 21.25.1302 @ 2019-05-31 Printing phone history Repair IMEI 5/31/2019 2:24:28 PM Repair IMEI 5/31/2019 11:39:59 AM Repair IMEI 5/31/2019 11:08:23 AM Network Backup / Restore 5/31/2019 11:05:31 AM Repair IMEI 5/31/2019 11:02:40 AM Repair IMEI For IMEI repair, a DIAG mode serial must be present. Searching for ports Waiting for diag serial port to appear... Please make sure Port Check Test is enabled on the phone! DIAG mode serial found. Reading modem calibration Creating backup... Be patient! Do NOT disconnect the phone! Saving Qualcomm files. 448 files saved. Saving special file. 716 files saved. Saving nv items. 699 nv items saved. 1 SIM1 nv items saved. 0 SIM2 nv items saved. Starting IMEI Repair... Trying to boot the phone into download mode... Waiting for download mode serial port to appear... Phone detected Creating EFS backup... Creating EFS backup... Reading EFS partitions. Do not disconnect the phone! EFS data saved successfully! EFS clear successful! Rebooting into normal mode to restore calibration! Rebooting phone... Restoring modem calibrations Waiting for diag serial port to appear... Please make sure Port Check Test is enabled on the phone! DIAG mode serial found. Restore the config files. Be patient! Do NOT disconnect the phone! Restoring Qualcomm files. 448 files restored. Restoring special file. 708 files restored. Restoring nv items. New IMEI (3579160724XXXXX) written! Rebooting phone... IMEI repair finished! Successfully finished. Finished at local time: [05.31.19 15:42:34] WorkID: 61323893 |
05-31-2019, 17:15 | #3609 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Samsung g900a unlocked done [just 5secs] Chimera Mobile Phone Utility version: 21.25.1302 @ 2019-05-31 Unlock phone started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G900A Sales Code: ATT Country Code: USA Timezone: Africa/Lagos Android Version: 5.1.1 [LMY47X] [SDK 22] Build Date: Thu May 26 18:27:33 KST 2016 PDA Version: G900AUCS4CPA4 [january 2016, rev4] Phone Version: G900AUCS4CPA4 [january 2016, rev4] CSC Version: G900AATT4CPA4 [january 2016, rev4] Product Code: SM-G900AZWAATT HIDSw Version: G900AUCS4CPA4/G900AATT4CPA4/G900AUCS4CPA4/G900AUCS4CPA4 Board Platform: MSM8974 Modem Platform: MSM8974PRO Serial Number: R38F41A4PDM Imei: 353411065691497 Unique Number: CMA00D2C8BA6C41 Connections: AT,MTP Battery Status: 3.83V (45%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Security Patch: 2016-06-01 Data Encryption State: unencrypted Checking root state... Not rooted. There is no backup, because there is no root access. Unlocking... Trying on SAMSUNG Mobile USB Serial Port (COM168) Unlocked. Successfully finished. Finished at local time: [05.31.19 16:59:52] WorkID: 61339428 |
06-01-2019, 06:46 | #3610 (permalink) |
No Life Poster Join Date: Aug 2014
Member: 2233266 Status: Offline Thanks Meter: 252 | Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! The phone will restart in upload mode, this is normal operation, do not worry! Switching to upload mode. Be patient! Do NOT disconnect the phone! Waiting for upload interface... Waiting for upload interface. Be patient! Do NOT disconnect the phone! Upload interface: SAMSUNG Mobile USB Modem (COM11) Reading data... Reading data is in progress. Be patient! Do NOT disconnect the phone! Freeze Code: 42064148 Network Lock: 97539281 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 Successfully finished. Finished at local time: [06.01.19 11:21:23] WorkID: 61432712 |
06-01-2019, 16:05 | #3612 (permalink) |
Member: 869809 Status: Offline Thanks Meter: 1,709 | A520F U9 patch cert done Code: Chimera Mobile Phone Utility version: 21.25.1302 @ 2019-06-01 Printing phone history Root/Unroot 6/1/2019 2:31:26 PM Repair IMEI 6/1/2019 2:25:28 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520F Sales Code: ITV Country Code: ITALY Timezone: Europe/Istanbul Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Fri Apr 5 13:59:12 KST 2019 PDA Version: A520FXXU9CSD2 [april 2019, rev2] Phone Version: A520FXXU9CSD2 [april 2019, rev2] CSC Version: A520FOXA9CSD2 [april 2019, rev2] Product Code: ITV HIDSw Version: A520FXXU9CSD2/A520FOXA9CSD2/A520FXXU9CSD2/A520FXXU9CSD2 Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R5********* Imei: 86************* Unique Number: CBJ000F85EE0D74 Connections: AT,MTP Battery Status: 3.98V (73%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-04-01 Data Encryption State: unencrypted Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 19.2:MAGISKSU Checking boot image. Be patient! Do NOT disconnect the phone! The knox is still valid. Because of the boot patch the warranty will void. Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [06.01.19 17:46:22] WorkID: 61472928 |
06-01-2019, 17:52 | #3613 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | [world 1st] lg sp200 dead recovery done with x210 unlocked firmware Chimera Mobile Phone Utility version: 21.25.1302 @ 2019-06-01 Printing phone history Development support 5/31/2019 4:49:34 PM Firmware Update started Preparing firmware files... Warning! The following model name mismatch(es) detected: This phones model name is LG-H631, while this firmware is for model LG-X210ULMA according to the DZ file (X210ULMA11a_00.dz). Flashing a firmware on the phone that is not made for this model can cause brick! Do you want to continue? Changing to download mode ... Flashing firmware... USB Connection Established Flashing: laf Flashing: boot Flashing: recovery Flashing: rct Flashing: factory Flashing: system Rebooting... [40 sec] Rebooting... [40 sec] Finalizing Successfully finished. Finished at local time: [06.01.19 17:42:39] WorkID: 61490740 |
06-04-2019, 00:07 | #3614 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Lg aristo [m210] unlocked done Chimera Mobile Phone Utility version: 21.32.1251 @ 2019-06-04 Printing phone history Unlock Online 5/20/2019 11:41:52 PM Unlock online Gathering information IMEI: 353661082614449 Preparing... Restarting phone... Waiting for the phone to restart... Rebooting phone to normal mode ADB interface detected. Processing Reading data This may take a while, please be patient! Unlocking phone Restarting phone... Successfully finished. Finished at local time: [06.04.19 00:06:36] WorkID: 61756747 |
