05-04-2021, 13:19 | #4081 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Printing phone history Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520F Sales Code: TTT Country Code: TRINIDAD AND TOBAGO Timezone: America/Argentina/Buenos_Aires Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Thu Nov 19 00:23:48 KST 2020 PDA Version: A520FXXSGCTK4 [november 2020, rev4] Phone Version: A520FXXSGCTK4 [november 2020, rev4] CSC Version: A520FUUBGCTK1 [november 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R28J60A0TFF Imei: 356921080307520 Battery Status: 3.99V (75%) Network Type: GSM SIM Status: READY Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2020-12-01 Em Did: 04747524E2F8 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 356921080307520 Repaired imei: 356921086307524 Successfully finished. Finished at local time: [05.03.21 12:24:47] WorkID: 133134230 Chimera Mobile Phone Utility version: 28.32.1330 @ 2021-05-03 Printing phone history Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520F Sales Code: TTT Country Code: TRINIDAD AND TOBAGO Timezone: America/Argentina/Buenos_Aires Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Thu Nov 19 00:23:48 KST 2020 PDA Version: A520FXXSGCTK4 [november 2020, rev4] Phone Version: A520FXXSGCTK4 [november 2020, rev4] CSC Version: A520FUUBGCTK1 [november 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R28J60A0TFF Imei: 356921086307524 Battery Status: 3.94V (76%) Network Type: GSM SIM Status: READY Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2020-12-01 Em Did: 04747524E2F8 Preparing... Checking root access. The phone is rooted by: 19.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.03.21 12:26:21] WorkID: 133134381 |
The Following User Says Thank You to gcceleghg For This Useful Post: |
05-07-2021, 15:40 | #4082 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,766 | reply Thank you for the feedback! If you have more works to share, please do it! Even if the method failed. WE will try to solve it. Best regards Sab Chimera Team Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
05-13-2021, 21:19 | #4083 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Chimera Mobile Phone Utility version: 28.41.1220 @ 2021-05-13 Printing phone history Rmm Remove 13/5/2021 7:35 p. m. Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520F Sales Code: XSG Country Code: UAE Timezone: America/Argentina/Buenos_Aires Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Sat Nov 7 19:59:15 KST 2020 PDA Version: A520FXXSGCTK1 [november 2020, rev1] Phone Version: A520FXXSGCTK1 [november 2020, rev1] CSC Version: A520FOJVGCTK1 [november 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R28J4354CFX Imei: 356921080218610 Battery Status: 3.89V (28%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2020-11-01 Em Did: 06B66FB471B8 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 356921080218610 Repaired imei: 356921085318613 Successfully finished. Finished at local time: [05.13.21 17:11:25] WorkID: 134154886 Chimera Mobile Phone Utility version: 28.41.1220 @ 2021-05-13 Printing phone history Repair IMEI 13/5/2021 8:10 p. m. Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520F Sales Code: XSG Country Code: UAE Timezone: America/Argentina/Buenos_Aires Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Sat Nov 7 19:59:15 KST 2020 PDA Version: A520FXXSGCTK1 [november 2020, rev1] Phone Version: A520FXXSGCTK1 [november 2020, rev1] CSC Version: A520FOJVGCTK1 [november 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R28J4354CFX Imei: 356921085318613 Battery Status: 3.89V (28%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2020-11-01 Em Did: 06B66FB471B8 Preparing... Checking root access. The phone is rooted by: 19.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.13.21 17:14:04] WorkID: 134155128 |
05-13-2021, 21:19 | #4084 (permalink) |
05-14-2021, 09:24 | #4085 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,766 | reply Thank you for the feedback! Good job! Quote:
05-31-2021, 00:51 | #4086 (permalink) | |
Freak Poster Join Date: Aug 2004 Location: WORLDWIDE
Member: 78516 Status: Offline Thanks Meter: 62 | Matepad pro testpoint location Quote:
please can you help me to locate the testpoint of Huawei MRX-W09 ? Thanks Best regards | |
05-31-2021, 10:09 | #4087 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,766 | reply Dear tooko, You can check the TEST POINT solutions here: https://forum.gsmhosting.com/vbb/f89...point-2355264/ Also i would like to recommend to check the Halabtech and the Easy-Firmware websites for more solutions. Best regards Sab Chimera Team |
05-31-2021, 15:59 | #4088 (permalink) |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 33
Member: 869809 Status: Offline Thanks Meter: 1,706 | G950F U11 network patch done Code: Chimera Mobile Phone Utility version: 28.56.1213 @ 2021-05-31 Printing phone history Repair IMEI 5/31/2021 2:50 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G950F Carrier ID: CAC Sales Code: CAC Country Code: Central Asia Timezone: Europe/** Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Thu Jan 7 15:33:05 KST 2021 PDA Version: G950FXXSBDUA3 [january 2021, rev3] Phone Version: G950FXXSBDTJ1 [october 2020, rev1] CSC Version: G950FOXMBDTJ1 [october 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: RF8******* Imei: 3552*********** Imei2: 3552********** Battery Status: 3.76V (33%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-01-01 Em Did: 03344C5D2C52 Preparing... Checking root access. The phone is rooted by: 23.0:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.31.21 17:53:26] |
The Following User Says Thank You to bk.gsm For This Useful Post: |
05-31-2021, 16:21 | #4089 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,766 | reply Dear bk.gsm, Thank you for the report, good job from you! Best regards Sab Chimera Team Quote:
06-06-2021, 18:47 | #4090 (permalink) |
Junior Member Join Date: Jan 2015 Location: Budapest
Member: 2330012 Status: Offline Thanks Meter: 4 | S20 FE frp reset: Chimera Mobile Phone Utility version: 28.64.1432 2021-06-06 Printing phone history SW Change 2021. 06. 05. 14:12 Device Info 2021. 06. 05. 14:09 Reset FRP lock started Resetting FRP... Operation in progress. Be patient! Do NOT disconnect the phone! Detected model: SM-G781B Connecting to *****'s server... Be patient! Do NOT disconnect the phone! Successfully finished. Finished at local time: 06.06.21 19:09:08 WorkID: 137188106 |
The Following User Says Thank You to Hardtex For This Useful Post: |
06-07-2021, 10:13 | #4091 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,766 | reply Dear Hardtex, Thank you for the positive feedback! Good work! Best regards Sab Chimera Team Quote:
06-21-2021, 14:29 | #4092 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | motorola XT2053-1 frp removed ok motorola XT2053-1 frp removed ok by chimera |
The Following User Says Thank You to Unlocker AL For This Useful Post: |
06-25-2021, 13:24 | #4094 (permalink) |
Freak Poster Join Date: Jun 2003 Location: zimbab Age: 46
Member: 32705 Status: Offline Thanks Meter: 66 | Chimera Mobile Phone Utility version: 28.83.0906 @ 2021-06-25 Printing phone history Device Info 25/6/2021 11:47 AM Reset FRP Lock 25/6/2021 11:44 AM Reset FRP/Reactivation Lock 25/6/2021 11:42 AM Reset FRP/Reactivation lock started Checking firmware image... Present. Flashing firmware image... Downloading firmware image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Flashing firmware image. Waiting for download mode. Connecting. SBL Info: Model: SM-G389F, Region: EUR, Provider: OPEN, PDA: G389FXXU1ARF1 Reading PIT from phone. Flashing image. Restarting phone. To complete FRP/Reactivation Reset go to Backup and Reset and select Factory Data Reset. Succeeded. Successfully finished. Finished at local time: [06.25.21 13:54:22] WorkID: 139645216 |
The Following User Says Thank You to neville For This Useful Post: |
06-28-2021, 09:54 | #4095 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,766 | reply Dear neville, Thank you for the shared FRP reset method. Good work from you! Best regards Sab Chimera Team Quote:
