i will try thanks |
How about N7100 ? i see it need 1.8v so no need external adapter? pls tel me ,thanks |
is it work, external supply for this gpg emmc box, if its work no need to create external board i think, please once test and give report, if its work i will buy this, http://www.icables.in/images/detaile...c-3in1-gpg.png BR, Srinivas Reddy. |
SAMSUNG N7100 Read Info... Device Ready... Device Ready...OK! ID check... Level (V) : VCC V18 VCCQ D0 CMD CLK Pullup : 0.78 0.03 0.64 0.35 0.00 0.00 Power ON : 2.63 1.75 2.54 1.02 1.65 0.01 ------------------------------------------------------------------- eMMC ORC: C0000000 eMMC CID: 0000000000000000,bad code! >>ID check lost! bro i have 2 set note n7100 but same error can you help me?? |
how to connet wair 3.3v and VCC |
bro read again & again if u cant understand & use u r mind .......... |
bro i9000 bad code error on isp there r 2 pic of that 1 is new 1 is old in old there is posted 3.3 volts on 2 points plz tell wich is the corrct point i have the same board l;ike old |
dear sir, i have problem... please guide me sir... this is my problem sir... i9300 repair no product name Read Info... Device Ready... Device Ready...OK! ID check... Level (V) : VCC V18 VCCQ D0 CMD CLK Pullup : 0.09 0.00 2.75 0.00 0.00 0.00 Power ON : 2.80 1.77 3.30 1.55 2.07 0.01 ------------------------------------------------------------------- eMMC ORC: 00000000 eMMC CID: 0000000000000000,bad code! >>ID check lost! tqvm, sir |
phone condition ? what s problem in this phone ? |
Hi, I given image below for how to sold wire with external power supply from gpg emmc jig and i9300 emmc connection. http://dc591.4shared.com/img/i6IAuXS...connection.jpg BR, Srinivas Reddy. |
simply explain why two points of 3,3V ? it's an error on picture? or how to connect this points? these two points need to connect together at 3,3V ? |
Sir i have tried all those solutions for over the past 72 hrs and nothing works i have tested it on 5 * N7100 3 * I9300 2 * I9100 (dosen't work either isp or jtag) 1 * direct emmc (movinand samsung b503 fo S III ) 1 * I9500 i supplied external current checked soldering over 10 times and every time i get these great message eMMC ORC: 00000000, bad code ! >> Id check lost or another CID error and when trying jtag release power key >> phone dosent respond bro it even cant jtag and isp seems to be a dead everytime |
another remark when checking pin info at emmc section if you connected extra power supply you get all the pins green(good contact) remove extra supply and pins returns to normal i tried it on the 10+ phones and didn't return any positive responds just get lost every time id check lost, write size lost, erase lost & finally Box get lost !! sir i have spent 199 Grand for this great invention i only ask for some support to how to make use of this device i tried to change vcc 2.4, 2.6, 2.8 i tried putting external voltage source, i tried to write boot size, i changed writing speeds nothing work every time you get lost |
(no need vcc from gps isp) |
