Read Info... Device Ready... Device Ready...OK! ID check... Level (V) : VCC V18 VCCQ D0 CMD CLK Pullup : 1.20 0.00 2.63 0.00 0.00 0.00 Power ON : 2.62 1.77 3.30 0.84 1.64 0.00 ------------------------------------------------------------------- eMMC ORC: 00FF8080 eMMC CID: 0000000000000000,bad code! >>ID check lost! samsung i9300 how to repair |
if all connections are ok and still same earror then have to replace emmc Regards |
Read Info... Device Ready... Device Ready...OK! ID check... Level (V) : VCC V18 VCCQ D0 CMD CLK Pullup : 0.09 0.00 2.75 0.00 0.00 0.00 Power ON : 2.80 1.77 3.30 1.55 2.07 0.01 ------------------------------------------------------------------- eMMC ORC: EF800000 eMMC CID: 0000000000000000,bad code! >>ID check lost! Today i m buy new Gpgemmc box for repair dead phone. i was try i9300 4 pess , But i can,t connect any one. all time show this problem. i have 5 pess i9300 hang samsung logo and no product name plz help me gpgemmc product team . how to connect it,sssssssssssssssss plz |
Regards |
@c_ahmad79 why everytime you answer you sound like either the user is the problem or the emmc/phone is the problem? why don't you accept that the box itself have a problem that's why the product creator is doing the fix. didn't you read their thread? their thread about the "adaptor" that will fix the connection problem? look at your post above, none out of 4 i9300 is connecting properly, do you think it's because the emmc is dead? i bet those 4 i9300 can be connected properly to other box... next time, before you do an advice, make sure you mention that the box have problems too, not just blaming the user or the emmc... |
i9300 eMMC ORC: 00000000,bad code! ID check lost! Please choose chip. Read Info... Device Ready... Device Ready...OK! ID check... Level (V) : VCC V18 VCCQ D0 CMD CLK Pullup : 0.00 0.00 0.02 1.40 0.00 0.00 Power ON : 2.62 1.81 2.54 0.85 2.53 0.00 ------------------------------------------------------------------- eMMC ORC: 00000000,bad code! >>ID check lost! use external suply voltaje no work ? http://all-spares.com/nfs/product/84...MC-Adapter.jpg friend can explain me more clear where I connect the battery diagram plizz |
Thanks ! |
any ideas on this ? Connecting... SN:00000100495 Get License data... Verify Liecnse data... Version:V3.1 Device Ready...OK! ------------------------------------------------------ PIN3 = SYSRST PIN5 = TDO PIN7 = RTCK PIN9 = TCK PIN11 = TMS PIN13 = TDI PIN15 = TRST Please choose phone. Reading... Device Ready... Device Ready...OK! ID check... Level (V) : VCC V18 VCCQ D0 CMD CLK Pullup : 0.41 0.00 0.44 0.77 0.00 0.00 Power ON : 2.62 1.76 2.51 0.86 2.50 0.00 ------------------------------------------------------------------- eMMC ORC: C0FF8080 eMMC CID: 150100303030303030562011072658 eMMC CSD: 902701320F5903FFF6DBFFEF8A4040 ID check: 00010015 Product name: 000000 User partition size: 400000000 ( 16384M / 16.000G), 17179869184 Bytes Boot partition size: 0x80000 ( 0.5M ) RPMB partition size: 0x20000 ( 0.1M ) ID check...OK! Read chip...User >>Read chip lost! any other method maybe ? am i doing something wrong ? isp will help ? chip is bad? any other ideas? |
resolder cable conexion |
i use an adapter for the chip ,you think it got something to do with the wiring. i need to check the setting or something ,like ic_speec and vcc ? |
What is the problem with this ? With other tool i can write and check Device Ready... Device Ready...OK! ID check... Level (V): VCC V18 VCCQ D0 CMD CLK 1.8 Pullup: 0.62 0.00 3.20 0.10 0.10 0.00 1.8 Low : 0.61 0.00 3.20 0.00 0.00 0.00 1.8 High : 0.59 0.48 3.20 0.88 0.90 0.90 ... 2.5 Pullup: 0.48 0.00 3.20 0.10 0.10 0.00 2.5 Low : 0.47 0.00 3.20 0.00 0.01 0.00 2.5 High : 0.45 0.49 3.20 0.89 0.91 0.91 ... 3.3 Pullup: 0.36 0.00 3.20 0.11 0.11 0.00 3.3 Low : 0.36 0.00 3.20 0.00 0.00 0.00 3.3 High : 0.35 0.50 3.20 0.90 0.92 0.92 ... Power On : 0.74 1.53 3.20 0.75 0.75 0.00 Set Low : 0.75 1.53 3.20 0.01 0.01 0.00 Set High: 0.77 1.69 3.20 2.23 2.25 2.27 ... Work Voltage: 0.76 1.55 3.20 1.36 2.09 0.00 --------------------------------------------------- eMMC ORC: F807FC04 A7 eMMC CID: 0000000000000000,bad code! >>Write chip lost! |
Connecting... SN:00000100810 Get License data... Verify Liecnse data... Version:V3.1 Device Ready...OK! ------------------------------------------------------ Erasing... Device Ready... Device Ready...OK! ID check... Level (V): VCC V18 VCCQ D0 CMD CLK 1.8 Pullup: 2.18 0.00 0.05 0.23 0.24 0.05 1.8 Low : 2.14 0.00 0.05 0.00 0.00 0.04 1.8 High : 2.08 0.00 0.05 1.03 1.06 0.27 ... 2.5 Pullup: 1.59 0.01 0.87 0.58 0.56 0.89 2.5 Low : 1.56 0.00 0.05 0.01 0.00 0.56 2.5 High : 1.52 0.00 0.05 1.35 1.38 0.74 ... 3.3 Pullup: 1.11 0.00 0.87 0.75 0.72 1.08 3.3 Low : 1.08 0.00 0.05 0.01 0.00 0.66 3.3 High : 1.06 0.00 0.87 1.64 1.67 0.92 ... Power On : 2.83 1.78 2.53 0.85 0.86 2.53 Set Low : 2.83 1.78 2.53 0.01 0.00 2.52 Set High: 2.83 1.78 2.53 1.98 2.01 2.53 ... Work Voltage: 2.83 1.78 2.53 0.85 0.86 2.52 --------------------------------------------------- eMMC ORC: 00000000 FF eMMC CID: 0000000000000000,bad code! Please check CLK . Erase chip lost! Erasing... Device Ready... Device Ready...OK! ID check... Level (V): VCC V18 VCCQ D0 CMD CLK 1.8 Pullup: 2.18 0.00 0.05 0.23 0.23 0.05 1.8 Low : 2.13 0.00 0.05 0.00 0.00 0.04 1.8 High : 2.08 0.01 0.05 1.03 1.06 0.27 ... 2.5 Pullup: 1.59 0.00 0.87 0.58 0.56 0.89 2.5 Low : 1.55 0.00 0.05 0.01 0.00 0.57 2.5 High : 1.52 0.00 0.05 1.35 1.38 0.75 ... 3.3 Pullup: 1.11 0.00 0.87 0.75 0.72 1.08 3.3 Low : 1.08 0.00 0.05 0.01 0.00 0.67 3.3 High : 1.06 0.00 0.87 1.64 1.67 0.91 ... Power On : 2.83 1.78 2.52 0.85 0.85 2.53 Set Low : 2.83 1.78 2.52 0.01 0.00 2.52 Set High: 2.83 1.78 2.52 1.98 2.00 2.53 ... Work Voltage: 2.83 1.78 2.52 0.85 0.85 2.52 --------------------------------------------------- eMMC ORC: 00000000 FF eMMC CID: 0000000000000000,bad code! Please check CLK . Erase chip lost! Erasing... Device Ready... Device Ready...OK! ID check... Level (V): VCC V18 VCCQ D0 CMD CLK 1.8 Pullup: 2.18 0.00 0.04 0.23 0.23 0.05 1.8 Low : 2.13 0.00 0.04 0.00 0.00 0.04 1.8 High : 2.09 0.00 0.04 1.03 1.06 0.27 ... 2.5 Pullup: 1.60 0.00 0.87 0.61 0.58 0.93 2.5 Low : 1.57 0.00 0.04 0.01 0.00 0.63 2.5 High : 1.54 0.00 0.04 1.35 1.37 0.77 ... 3.3 Pullup: 1.12 0.00 0.87 0.75 0.72 1.07 3.3 Low : 1.10 0.00 0.04 0.01 0.00 0.68 3.3 High : 1.07 0.00 0.87 1.64 1.67 0.92 ... Power On : 2.83 1.78 2.52 0.85 0.85 2.53 Set Low : 2.83 1.78 2.52 0.01 0.00 2.52 Set High: 2.83 1.78 2.52 1.98 2.00 2.53 ... Work Voltage: 2.83 1.78 2.52 0.85 0.85 2.52 --------------------------------------------------- eMMC ORC: 00000000 FF eMMC CID: 0000000000000000,bad code! Please check CLK . >>Erase chip lost! |
eMMC ORC: C0FF8080 FF eMMC CID: 15010056545530304DF1FC2435D26F eMMC CSD: FF409C04C83D640FFFDB6FFFFE3901 ID check: 00010015 Product name: VTU00M User partition size: 75F17E3E00 ( 483095M / 471.772G), 506562756096 Bytes Boot partition size: 0x1EC0000 ( 30.7M ) RPMB partition size: 0x1960000 ( 25.3M ) ID check...OK! >>Chip information acquisition in error, please modify the VCCQ value and then try again. cant modify any of the values since they are all fixed. what can i do please??? |
Hi, tried your suggestion but it didn't work for me. i have read it worked for others. i guess i may have to get the new adaptor from my supplier. thanks for your help nonetheless. |
need help p3100 isp flashing Read Info... Device Ready... Device Ready...OK! ID check... Level (V): VCC V18 VCCQ D0 CMD CLK 3.3 Pullup: 0.00 2.01 0.00 1.79 1.45 2.19 Power On : 2.88 1.76 2.48 1.34 0.00 1.61 Set Low : 2.88 1.76 2.48 0.03 0.04 1.17 Set High: 2.88 2.95 2.48 3.15 3.16 1.40 ... Work Voltage: 2.84 1.58 0.00 2.14 2.87 2.02 --------------------------------------------------- eMMC ORC: FFF2003F AF eMMC CID: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF eMMC CSD: FFE1F3FFFFFFFFFFFFF413FFFFFFFF ID check: FFFF00FF Product name: ______ User partition size: 17DED2DFA00 ( 1564370M / 1527.705G), 1640361753088 Bytes Boot partition size: 0x1980000 ( 25.5M ) RPMB partition size: 0xA40000 ( 10.2M ) ID check...OK! >>Chip information acquisition in error, please modify the VCCQ value and then try again. what can i do.... |
