07-17-2018, 18:06 | #3601 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Dominican Republic Age: 40
Member: 605730 Status: Online Sonork: 100.1605690 Thanks Meter: 70 | Using 1.25 Checking GCPro Card Details... Card OsVer 0003 GCPro SN:= GCE7C2 GCPRO Activation := CARD IS ACTIVE Checking server connection... GCPro SN GCE7C29163 Card OsVer 0003 GCPRO Activation := CARD IS ACTIVE CARD UUID:= 065436951FD86A1A7936874037E1C5C82955F6B0 Card crypto verify ok.. Server Reply Error := ERR_CARD_Already_Updated. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...17-07-2018-13-06-03 Using 1.25 |
07-17-2018, 18:35 | #3602 (permalink) |
Junior Member Join Date: May 2015 Location: Guatemala City
Member: 2402036 Status: Offline Thanks Meter: 0 | Card Locked Please!!!!! Using 1.25 Checking server connection... Server access ok.. Making sure card is locked or not.. session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Reading Details.. Card Lock Reason := FcLHDQAwCASwmejwBI79V4oiW0ZUS7YNSUHHxMmAwn3KLoYbvd 8gYbWlSxmukvcA This GCPro is not Allowed to UPDATE or Register, Contact reseller.. GCPro SN := GC90C299EF Fail at unlock card please contact support... Job finish |
07-17-2018, 20:31 | #3603 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1436211 Status: Offline Thanks Meter: 0 | Using 1.25 Checking GCPro Card Details... session fail Card Locked.. session fail Card Locked.. Fail to start session with card... Checking server connection... GCPro SN GCCF57E9D6 Card OsVer 0003 Fail getactivation Card Locked.. Card Lock Reason := FcLBEYBACAPAljQcCTwBpf+SHGd3VrwSARx624tWgm6Dx2z9jk rP8wtnV25pxlAs6QM= CARD UUID:= 0684299557D5F4E8BB7AF63A57F1517BE0249AC1 Card crypto verify ok.. Server Reply Error := ERR_CARD_Already_Updated. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...17-07-2018-14-02-20 Using 1.25 |
07-18-2018, 02:57 | #3604 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1281274 Status: Offline Sonork: hola Thanks Meter: 0 | Card Locked Please Using 1.25 GCPro found... session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...17-07-2018-21-53-17 Using 1.25 Using 1.25 Checking server connection... Server access ok.. Making sure card is locked or not.. session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Reading Details.. Card Lock Reason := FcLBDcAwCAPAlWiogT5B2PuPFFV3jnQJi+VhnMZkz8s1f0THF5 ZK/kLgeCWtaytKcQE= This GCPro is not Allowed to UPDATE or Register, Contact reseller.. GCPro SN := GC2202494A Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...17-07-2018-21-56-29 Using 1.25 |
07-18-2018, 09:47 | #3605 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @k9v9y0 @landeta Hello Card is already 0003 its not need update,what your issue ? @lesterfree @simple-mortal @jose1500ac Hello Please select update gcpro in update tool and issue will be solved. |
07-18-2018, 11:05 | #3606 (permalink) |
Junior Member Join Date: Jan 2014 Location: jhguijhffdevbgjhnfjh
Member: 2099697 Status: Offline Thanks Meter: 1 | card blocked Using 1.25 Checking server connection... Server access ok.. Making sure card is locked or not.. session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Reading Details.. Card Lock Reason := FcLBDQAxCAOwlQgUGp6tjuw/UnWyXZ5zYo2aMvdVzcCn25pMTWnbxq+Mg5TxhuIQxAM= This GCPro is not Allowed to UPDATE or Register, Contact reseller.. GCPro SN := GC00000000 Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...14-07-2018-13-08-41 Using 1.25this message apear after update gcprokey66 |
07-18-2018, 15:37 | #3607 (permalink) |
Freak Poster Join Date: May 2007 Location: ETHIOPIA
Member: 518577 Status: Offline Thanks Meter: 5 | card not found resseller SIM SIM Using 1.25 GCPro found... Card verify ok... Card OsVer 0002 GCPro SN:= GCB616B66D GCPRO Activation := CARD IS ACTIVE Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...18-07-2018-07-22-14 Using 1.25 |
07-18-2018, 17:23 | #3608 (permalink) |
Member: 1281274 Status: Offline Sonork: hola Thanks Meter: 0 | card not active Using 1.25 Checking GCPro Card Details... Card OsVer 0000 GCPro SN:= GC2202494A GCPRO Activation := NOT ACTIVE Checking server connection... GCPro SN GC2202494A Card OsVer 0000 GCPRO Activation := NOT ACTIVE CARD UUID:= 06599995C8A3CC785E97F163BCD81EEAD9F58027 CARD UUID:= 06599995C8A3CC785E97F163BCD81EEAD9F58027 Card crypto verify ok.. This GCPro is not Allowed to UPDATE or Register, Contact reseller.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...18-07-2018-12-20-12 Using 1.25 |
07-18-2018, 19:41 | #3609 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2529435 Status: Offline Thanks Meter: 0 | Help gcpro box locked My computer is damaged. Place the hard drive on another pc while fixing the other. But do not use the box. And when I put the disk back into my computer again it did not want to open. I leave the log. I hope it can be solved. Thank you very much! Using 1.25 Checking GCPro Card Details... session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Checking server connection... GCPro SN GCB90B15B5 Card OsVer 0003 Fail getactivation Card Locked.. Card Lock Reason := FcLJEQAhCATAlGAcxH3KlX9I1la3cEgQx1dnt/XHgOHWieQ09ri4/rboDaRZbQdXUR8= CARD UUID:= 095512954A43DE9F4BA36FFB8FE27F3826DED81D Card crypto verify ok.. Server Reply Error := ERR_CARD_Already_Updated. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...18-07-2018-12-32-12 Using 1.25 Using 1.25 Checking server connection... Server access ok.. Making sure card is locked or not.. session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Reading Details.. Card Lock Reason := FcqxFcAwCAPRlVBkSFRCDPuPFOdd84vbfrkoevRguPgoZ02ZYq vJ6kTaX0EOe89vHvcRPg== This GCPro is not Allowed to UPDATE or Register, Contact reseller.. GCPro SN := GCB90B15B5 Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to f |
07-18-2018, 19:55 | #3610 (permalink) |
Junior Member Join Date: May 2016
Member: 2571208 Status: Offline Thanks Meter: 0 | help please Using 1.25 Checking GCPro Card Details... session fail Card Locked.. session fail Card Locked.. Fail to start session with card... Checking server connection... GCPro SN GC5747AEC9 Card OsVer 0003 Fail getactivation Card Locked.. Card Lock Reason := FcLBDQAxCAOwlUpJVHi2EPYf6XSy5Sq99FndqDVjV0QRpo2h4i WSv8CJfTmnS5A59wc= CARD UUID:= 09851695A7E6A02C90A33CD115C4B72D270887C5 Card crypto verify ok.. Server Reply Error := ERR_CARD_Already_Updated. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...18-07-2018-13-52-34 Using 1.25 |
07-18-2018, 19:55 | #3611 (permalink) |
07-18-2018, 20:24 | #3612 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1175355 Status: Offline Thanks Meter: 0 | Using 1.25 Checking GCPro Card Details... fail to verify card... Checking server connection... GCPro SN GCAE77BFF0 Card OsVer 0002 Checking security of card... GCPRO Activation := CARD IS ACTIVE CARD UUID:= 074594951415D54E58CE42CEB92689717BFE1FF6 Card error fail to start security session....6982 Fail to start security session,This CARD CAN NOT be updated,DO NOT TRY MORE.. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...18-07-2018-14-14-29 Using 1.25 |
07-19-2018, 01:02 | #3613 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2800501 Status: Offline Thanks Meter: 0 | Please help me gpgindustries order 7919 Log: Using 1.25 Card OsVer 0003 GCPro SN:= GC4DA925FC GCPRO Activation := NOT ACTIVE Checking server connection... Enter registration details for GCPro... Checking card.. This GCPro is not Allowed to UPDATE or Register, Contact reseller.. Fail at activation please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...18-07-2018-19-58-16 Using 1.25 |
07-19-2018, 09:00 | #3614 (permalink) |
Member: 2099697 Status: Offline Thanks Meter: 1 | Using 1.25 Checking server connection... Server access ok.. Making sure card is locked or not.. session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Reading Details.. Card Lock Reason := FcLBEcAwCAOwlYBQmj4xsfcfKdeT5MJK9vKsoObbWZR5vWEbYf Bm6wfy0WkvBWZwUhc= This GCPro is not Allowed to UPDATE or Register, Contact reseller.. GCPro SN := GC939CC828 Fail at unlock card please contact support... Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...19-07-2018-09-59-12 Using 1.25 |
07-19-2018, 09:02 | #3615 (permalink) |
Member: 2099697 Status: Offline Thanks Meter: 1 | Using 1.25 Checking GCPro Card Details... session fail Card Locked.. Fail cardos Card Locked.. Fail to get card os read details... Checking server connection... GCPro SN GC939CC828 Card OsVer 0003 Fail getactivation Card Locked.. Card Lock Reason := FcLJEQAhCATAlNgBOZ7oSP4hWVvdIOKm+mX1AGJWrUruPWfFHG cg9OfIahmhT1quj3w= CARD UUID:= 08557595F5973DFCEFB9C3A022DB7BF8F2A99AD9 Card crypto verify ok.. Server Reply Error := ERR_CARD_Already_Updated. Job finish Do not lost delete old logs they may help some time to fix your issue fast..Show log to support team in case of error...19-07-2018-10-02-09 Using 1.25 |
