Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Huawei > Huawei Android based phones
Huawei Android based phones General Huawei Android phones discussion, firmwares, solution, root, help
Old 01-31-2017, 11:41   #1 (permalink)
.....::::GsmAdeel:::::.....'s Avatar
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
Honor H30-U10 Imei NULL
How to fix
imei write nv file write bur same IMEI NULL
any best tool write for imei
Old 01-31-2017, 13:53   #2 (permalink)
faruk_patwary's Avatar
Member: 1194197
Sonork: 100.1671026
Thanks Meter: 185
Flash with another firmware
Chimera tool can help you
Old 01-31-2017, 14:17   #3 (permalink)
sheraziking110's Avatar
Member: 2486822
Sonork: 100.1659206
Thanks Meter: 77
USE
Frist root and try with this apk
Chamelephon 1.0 APK Download - Android Personalization Apps
The Following User Says Thank You to sheraziking110 For This Useful Post:
Old 01-31-2017, 15:36   #4 (permalink)
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
problem solve thx for relpy
Old 03-19-2017, 06:35   #5 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 169
how yuo solve problum i hane set in hand imei null
Old 03-19-2017, 07:25   #6 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,052
Please read the the thread from beginning, you can get your expect solution.
Send from my SM-G928F using Tapatalk
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
Old 08-21-2017, 09:20   #7 (permalink)
Member: 2486822
Sonork: 100.1659206
Thanks Meter: 77
How to fix
USE
Old 08-23-2017, 07:09   #8 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,086
this solution doesn't work for me..any other solution ?
Old 08-24-2017, 05:35   #9 (permalink)
Cheater -Don't Deal with him-
Member: 1819112
Sonork: 100.1792895
Thanks Meter: 23
Try This Method
https://forum.xda-developers.com/and...i-fix-t3288020
Old 04-04-2018, 13:31   #10 (permalink)
Member: 2562243
Thanks Meter: 7
USE
this solution is not work
Old 06-06-2018, 13:15   #11 (permalink)
Member: 1839879
Thanks Meter: 194
sheraziking110 bhai very very thanks ilove u ALLAH ap ka bla kary Ameen
Old 08-09-2018, 12:06   #12 (permalink)
Member: 2823499
Thanks Meter: 2
friends plz go in recvry mood wipe fctry nd cheh/ now reboot phone ur problam is slov tested by me
Old 12-22-2018, 13:05   #13 (permalink)
Love_InsPeXtor's Avatar
Member: 2683134
Thanks Meter: 57
New Working Solution is here
read compleate article here Huawei Honor 3C H30-U10 IMEI Repair Solution 100% Tested Without Box
Only Thanks Button
Old 02-21-2019, 19:05   #14 (permalink)
Member: 2601431
Thanks Meter: 34
Sometimes when the we read the phone and the imei is there but in the screen *#06# appears NULL, we need to format all the partitions (Except bootloader) and re-flash de phone again.
The steps are:
Write memory with spflashtools v3 to unlock the bootloader with the secro scatter loaded.
Flash secro.
Then format all partitions except bootloader. (Very important)
Flash de firmware (In my case B108 worked).
Now you can write the imei via adb (You will need root first, you can use KingoRoot) or you can flash with tools like Nck via SpMeta connecting the phone powered off.
The imei should appear now.
The Following User Says Thank You to henrucci For This Useful Post:
Old 08-20-2019, 22:31   #15 (permalink)
Member: 1397302
solved my customer phone. tnx alot
Page generated in 0.19176 seconds with 8 queries
