How to repair imei null Qualcomm phones by huabox? First in the world "repair imei null" is currently not supported for huawei phones -Download and Write qcn with any tools -Open huabox -goto Qualcomm tab -Goto unlock/imei -select diag port -enter imei -enable skip reset sec -press repair -use factory reset -done |
HOW TO DIRECT UNLOCK HUAWEI OLD SEC PHONES ? -NEED ROOT AND USB DEBUGGING -CHECK LIST MODEL BEFORE USE http://forum.gsmhosting.com/vbb/f930...dated-2023678/ http://uupload.ir/files/dnis_16.png |
HOW TO DIRECT UNLOCK MOTOROLA PHONES ? -NO NEED ROOT -NEED DOWNGRADE MODEM IF NOT SUPPORTED -METHOD IS GENERIC AND MOST PHONES SUPPORTED -SELECT DIAG PORT IN PORT SETTING BEFORE UNLOCK(FASTBOOT MODE/PB TOOL) http://uupload.ir/files/fdvi_17.png |
HOW TO REPAIR IMEI MOTOROLA QUALCOMM PHONES? -NO NEED ROOT -NEED DOWNGRADE MODEM IF NOT SUPPORTED -METHOD IS GENERIC AND MOST PHONES SUPPORTED -SELECT DIAG PORT IN PORT SETTING BEFORE UNLOCK(FASTBOOT MODE/PB TOOL) http://uupload.ir/files/2laf_18.png |
HOW TO REPAIR IMEI HUAWEI HEXAGON METHOD? -NO NEED ROOT -NEED ENABLE DIAG PORT(SELECT PC MODE AFTER CONNECT USB) -NEED SELECT DIAG PORT IN SETTING http://uupload.ir/files/nkis_19.png http://forum.gsmhosting.com/vbb/f930...eeeee-2135103/ |
HOW TO REPAIR IMEI QUALCOMM PHONES BY GENERIC METHOD? -NO NEED ROOT -NEED ENABLE DIAG PORT -NEED SELECT DIAG PORT IN SETTING http://uupload.ir/files/0ggp_20.png |
HOW TO REPAIR IMEI QUALCOMM PHONES BY FACTORY METHOD? -NO NEED ROOT -NEED ENABLE DIAG PORT -NEED SELECT DIAG PORT IN SETTING http://uupload.ir/files/1edd_21.png |
HOW TO DIRECT UNLOCK QUALCOMM PHONES BY GENERIC METHOD? -DONT FORGET BACKUP QCN BY QPST FREE TOOL BEFORE USE -NO NEED ROOT -NEED ENABLE DIAG PORT -NEED SELECT DIAG PORT IN SETTING -NEED REPAIR IMEI AFTER UNLOCK(IF IMEI IS 00000000000) http://uupload.ir/files/fxf1_22.png |
HOW TO DIRECT UNLOCK QUALCOMM PHONES BY GENERIC PATCH METHOD? -DONT FORGET BACKUP QCN BEFORE USE -NEED ROOT -NEED REPAIR IMEI AFTER UNLOCK(IF IMEI IS 00000000000) http://uupload.ir/files/6cce_23.png |
HOW TO ENABLE ALL LANGUAGE? -NEED ROOT AND BUSYBOX -NEED FACTORY RESET AFTER HUAWEI AND HTC METHOD http://uupload.ir/files/yzhl_2018-06-16_23-27-49.jpg |
HOW TO RESET SCREEN LOCKS PIN/PASS/PATTERN BY TWRP METHOD? -NEED ENTER TO TWRP MODE -NEED CHECK DATA AND SYSTEM MOUNT IF HAVE PROBLEM http://uupload.ir/files/otyz_25.png |
HOW TO RESET SCREEN LOCKS PIN/PASS/PATTERN/FINGER AND OTHER LOCKS BY TWRP METHOD? -NEED ENTER TO TWRP MODE -NEED CHECK DATA AND SYSTEM MOUNT IF HAVE PROBLEM http://uupload.ir/files/i5od_26.png |
HOW TO UNLOCK BOOTLOADER BY HUA? -GENERIC METHOD - DONT HAVE LIST MODEL -NEED CONNECT PHONE TO FASTBOOT http://uupload.ir/files/213_28.png |
