HOW TO RESET FRP BY HUA? -GENERIC METHOD -DONT HAVE LIST MODEL -NEED CONNECT PHONE TO FASTBOOT http://uupload.ir/files/moo3_29.png |
HOW TO REPAIR IMEI ALLWINNER PHONES? -NEED ROOT AND USB DEBUGGING http://uupload.ir/files/seke_30.png |
HOW TO READ AND WRITE FLASH BY ADB MODE? -NEED ROOT AND BUSYBOX -NEED FACTORY RESET AFTER WRITE http://uupload.ir/files/dtf2_31.png 1) Make sure Your Device SD Ram has at least 1 GB Free Space 2) Make Sure your Phone has ROOT permission 3) Make Sure BusyBox application is already installed on phone Write Allwinner CPU Dump File Notes: 1) Make sure Your Device SD Ram has at least 2 GB Free Space 2) Make Sure your Phone has ROOT permission 3) Make Sure BusyBox application is already installed on phone 4) Copy 'system.tgz','data.tgz','bootloader.img','boot.img ','recovery.img' to your Phone's SD Card |
HOW TO READ UNLOCK BOOTLOADER CODE FOR HUAWEI PHONES? -NO NEED ROOT -NEED AUTHORIZE BY 1 CREDIT BY HDE TOOLS -NEED CONNECT PHONE TO MANUFACTOR MODE -NEED DB ADAPTER PORT FOR QUALCOMM PHONES -NEED PCUI PORT FOR HISILICON PHONES http://uupload.ir/files/7gs0_32.png http://uupload.ir/files/hus_33.png |
HOW TO REPAIR IMEI HUAWEI QUALCOMM PHONES? -NO NEED ROOT -NEED AUTHORIZ BY 1 CREDIT(HDE TOOL)FOR ENABLE DIAG PORT http://uupload.ir/files/94xv_66.jpg -NEED CONNECT PHONE TO MANUFACTOR MODE -NEED SELECT DB ADAPTER PORT http://uupload.ir/files/x8c4_34.png FREE SOLUTION FOR AUTHORIZE WIHTOUT CREDIT FOR G630/G6/Y530 active diag.7z PASSWORD : 9130898005 |
how to select manually loader for HQT ? NEED TO SELECT MANUAL LOADER http://uupload.ir/files/qy2q_2.jpg http://uupload.ir/files/vonv_3.jpg HOW TO SELECT? http://uupload.ir/files/st83_1.png |
HUA FRP TOOL SAMSUNG MANUALS : DL MODE METHOD -QUALCOMM FRP LIST MODELS -EXYNOS FRP LIST MODELS -2015/2016 OLD AND NEW this method is for old phones same g531h/j700h/j500h/j700f and other models and need write reset frp file or sboot if show error |
HUA FRP TOOL SAMSUNG MANUALS : ADB MODE METHOD this operation works for the mentioned above devices with Android 6.x firmwares' versions and may not work for some phones’ S-boot. In this case try to write another firmware version or only S-boot from firmware and repeat the operation again. WRITE SPECIAL FILE OR COMBINATION OR ENABLE ADB FILE + RESET FRP BY HUA + WRITE FULL FIRMWARE |
Press enable diag port then insert usb cable to phone apply usb deubgging and root done |
