01-04-2022, 19:18 | #1 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Discussion about MFC Version 3.9 🔥🔥🔥🔥🔥 2022/01/05 Changes - V3.9
Br., THE MFC TEAM |
01-04-2022, 20:46 | #3 (permalink) |
No Life Poster Join Date: Aug 2016 Location: A few details about yourself Age: 33
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Passcode lock on newer iPhones and newer versions 15.2?? Hello Can somebody tell me if I am able to find the passcode on newer iPhones and newer versions 15.2 like iPhone 7, 8, X, 11, 12 etc? I don't know what MFC can do apart from Watches iCloud remove series 1, 2 ,3 Also with this new update 3,8 that was released that says all iPads supported, does it mean that I can also change serial on newer iPads via diags or which functions are supported ? BR |
01-04-2022, 21:03 | #4 (permalink) | |
Product Supporter Join Date: Oct 2014 Location: MFC
Member: 2277861 Status: Offline Thanks Meter: 206 | Quote:
01-04-2022, 21:44 | #5 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | I have read them many times, but not understood what can I do with this: " 2022/01/02 Changes - V3.8 Add support all new iPad models Add support all new iPhone models" If you mean that I can flash or update iPads then it is useless for me , I am looking for Diagnostics and some other functions that no free tools can do it. |
01-04-2022, 22:31 | #8 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Quote:
01-05-2022, 15:40 | #9 (permalink) | |
is 1110 other free can do ? u talking like a big boss | |
01-05-2022, 17:24 | #10 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | I didn't ever needed that service that's why I heard it for the first time, but I deal with Watches and right now seems that you have broken support for them with this update now. Please let older version that worked to still use them because now I can not do watch diags like I did before with this 3,9 version. Server did not respond properly! Other software functions might fail! Please check your internet connection and or firewall! [info] Found device in DFU mode [done] Operation finished! [info] Selected port: COM26 [info] Use alternative connection method selected [info] Connection uses alternative backend [erro] Could not find device with ECID:45DD23C058026 in DFU mode! [info] Adding DFU rules... [info] Please reconnect your device and try again! [done] Operation finished! [info] Found device in DFU mode [done] Operation finished! |
01-05-2022, 17:35 | #11 (permalink) | |||
Member: 79315 Status: Offline Thanks Meter: 6,024 | Quote:
Not becoz the support broken, becoz of your actions as i check the logs Quote:
means the driver bad , u have to check driver, can delete driver in device manager and try again | |||
01-05-2022, 22:49 | #12 (permalink) | |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | Right now on a laptop with Win10 that MFC worked before it is working , but Flashing tab suddenly disappeared. Having problems with 2 watches activating. Flashed earlier, now Flash tab disappeared I am really really surprised where the Flash Tab went? Did you eat from there ?? Quote:
Edit: Now Flash tab appeared again, that's really an interesting play.... | |
01-05-2022, 23:11 | #13 (permalink) |
Member: 2612403 Status: Offline Sonork: 100.1575170 Thanks Meter: 108 | And sorry because I wanted to flash that Watch S2 which has problems activating, and I remember that I also have flashed before some days Watch S3, didn't know that trouble , now everything is understood.... So, as there is no signed firmware right now for S3 you remove Flash tab from the software |
01-06-2022, 06:19 | #14 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,024 | S3 - S6 there is no signed firmware now , so ya, everybody have to wait, as we check v8.4 should be soon No , the flash tab still there, only when device connected then the tab will show up |
01-06-2022, 12:47 | #15 (permalink) |
Insane Poster Join Date: Oct 2016 Location: Azerbijan Baku Age: 39
Member: 2642070 Status: Offline Thanks Meter: 15 | mfc 3.9 error Server init state canceled whats problem plz help me. [serv] Latest available software version is 3.9. Please update if necessary! [erro] Server init state canceled [erro] Server init state canceled [erro] Server init state canceled [erro] Server init state canceled |
