01-18-2022, 17:24 | #31 (permalink) | |
Product Supporter Join Date: Oct 2014 Location: MFC
Member: 2277861 Status: Offline Thanks Meter: 206 | Quote:
01-18-2022, 17:41 | #32 (permalink) | |
Crazy Poster Join Date: Mar 2015 Location: iran
Member: 2365404 Status: Offline Thanks Meter: 9 | Quote:
Code: [warn] Incorrect driver detected! Please wait to update the drivers! [info] Found device in Recovery mode [info] Device ecid 000e14ee20f1a326 disconnect detected! [info] Repairing ... [info] Device a8bca4d3d2982062673b5716508efbaa0ea0bd31 has successfully entered restore mode [info] BoardID: 14 [info] ChipID: 32770 [info] UniqueChipID: 3963662661428006 [info] ProductionMode: true [erro] TZ0RequiredCapacity: 0x600000 | |
01-18-2022, 18:48 | #35 (permalink) | |
but error flashing Code: [info] Personalizing IMG4 component StaticTrustCache... [info] Sending IsFUDFirmware for StaticTrustCache... [info] Checkpoint 4874 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4865 complete with code 0 [info] Updating gas gauge software (47) [info] Checkpoint 4866 complete with code 0 [info] Updating Stockholm (55) [erro] FDR 145FBB10 Unable to receive proxy payload (-3) [info] Checkpoint 4868 complete with code 0 [info] Updating Stockholm (55) [erro] FDR 145FBC48 Unable to receive proxy payload (-3) [info] Checkpoint 4868 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 0 [info] Updating Stockholm (55) [info] Checkpoint 4868 complete with code 18446744073709551615 [info] Checkpoint 1589 complete with code 56 [info] Checkpoint 1659 complete with code 56 [info] Checkpoint 1660 complete with code 0 [info] Checkpoint 5652 complete with code 0 [info] Checkpoint 1607 complete with code 0 [info] Status message: Ramrod firmware update failed. Hint: The display of this model is not compatible, or you can replace the NFC module [sett] Log is available in ErrorLog plist [erro] Unable to successfully restore device [info] Checkpoint 1608 complete with code 0 [erro] Unable to restore device [done] Operation finished! [info] device disconnect... | |
01-18-2022, 19:28 | #36 (permalink) |
Member: 2277861 Status: Offline Thanks Meter: 206 | thats Hint: The display of this model is not compatible, or you can replace the NFC module so this is the error |
The Following 2 Users Say Thank You to mfcsupport For This Useful Post: |
01-20-2022, 11:27 | #37 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,024 | Don't not try with other tools except iTunes and MFC Software if u have 1110 issue @all, i just got some people report about 1110 issue So note, don't try other tool except iTunes and MFC Software , by somehow that may damage your device data by unknown reason ! Br., Denis |
01-20-2022, 11:53 | #38 (permalink) |
Insane Poster Join Date: Oct 2016 Location: Azerbijan Baku Age: 39
Member: 2642070 Status: Offline Thanks Meter: 15 | mfc 3.9 error 1110 [info] Using LOCAL IPSW F:\IPHONE FLASH FILES\iPhone11,2,iPhone11,4,iPhone11,6,iPhone12,3, iPhone12,5_15.2.1_19C63_Restore.ipsw [info] Starting repair... [info] Found device in Recovery mode [info] Device ecid 000a15101442002e disconnect detected! [info] Repairing ... [info] Device 00008020-000A15101442002E has successfully entered restore mode [info] BoardID: 14 [info] ChipID: 32800 [info] UniqueChipID: 2837908570636334 [info] ProductionMode: true [erro] Unable to repair device [info] Repair step 2... [info] Removing USB\VID_05AC&PID_12A8\00008020-000A15101442002E [info] Found device in Recovery mode [info] Device ecid 000a15101442002e disconnect detected! [info] Repairing ... [info] Device 00008020-000A15101442002E has successfully entered restore mode [info] BoardID: 14 [info] ChipID: 32800 [info] UniqueChipID: 2837908570636334 [info] ProductionMode: true [erro] Unable to repair device [done] Repair completed... rebooting ... [info] Found device in Normal mode whatsa problem ? ios 15.2.1 error 1110 |
01-20-2022, 12:55 | #39 (permalink) | |
01-26-2022, 08:55 | #45 (permalink) |
Freak Poster Join Date: Mar 2008 Location: kabul AFGHANISTAN Age: 35
Member: 724190 Status: Offline Sonork: zabih Thanks Meter: 16 | iPOWER X - Searching ... Error... Server did not respond properly! Other software functions might fail! Please check your internet connection and or firewall! This update adds new functionality to your MFC. Now the dongle will automatically adjust the birghtness before starting the unlock process. This will save battery and also will make the sensor detection more reliable than before. You need to connect the sensor and go to the emergency calling screen before connecting MFC Do not connect the sensor on the brightness display icon ! Waiting for program to exit ... Could not stop operation ! No current device selected! The opened file might not be a valid settings file! Aborting... iPOWER X - Searching ... Latest available software version is 3.9. Please update if necessary! This update adds new functionality to your MFC. Now the dongle will automatically adjust the birghtness before starting the unlock process. This will save battery and also will make the sensor detection more reliable than before. You need to connect the sensor and go to the emergency calling screen before connecting MFC Do not connect the sensor on the brightness display icon ! Login failed with no other informations provided! Unable to login, please check your username, password and be sure device is conencted! Server init state unknown Waiting for program to exit ... Could not stop operation ! No current device selected! The opened file might not be a valid settings file! Aborting... iPOWER X - Searching ... Latest available software version is 3.9. Please update if necessary! Waiting for program to exit ... Could not stop operation ! No current device selected! The opened file might not be a valid settings file! Aborting... iPOWER X - Searching ... Latest available software version is 3.9. Please update if necessary! This update adds new functionality to your MFC. Now the dongle will automatically adjust the birghtness before starting the unlock process. This will save battery and also will make the sensor detection more reliable than before. You need to connect the sensor and go to the emergency calling screen before connecting MFC Do not connect the sensor on the brightness display icon ! Server: Please check your username, password or dongle! Server init state canceled Waiting for program to exit ... Could not stop operation ! No current device selected! Server: Hello fastunlock, Welcome to our iMFC server The opened file might not be a valid settings file! Aborting... iPOWER X - Searching ... Latest available software version is 3.9. Please update if necessary! Waiting for program to exit ... Could not stop operation ! No current device selected! |
