All Qmobile hard reset easy way HELLO GUYS! I will show you very easy way to QMobile hard reset step by step guide. http://i.imgur.com/k2wKQ6l.png http://i.imgur.com/i2Tn1Um.png All QMobiles Hard Reset Via Hot Key Optimus Sydney
Optimus Sydney 1: In order to turn off the device press the Power button for a couple of seconds. 2: Afterwards press and hold together the Volume Up + Power key for a few seconds. 3: Then select option Recovery by using to navigate Volume Up, and to confirm Volume Down key. 4: As soon as the Android Image shows up on the screen hold down the Power key for a couple of seconds. 5: While you holding the Power button quickly press the Volume Up key. 6: Aftert that use the Volume Down to choose "wipe data/factory reset", and then push the Power button to confirm. 7: Select "Yes--delete all user data". Use Volume Down button to scroll and Power button to select. 8: To restart the phone, select "reboot system now" 9: Success! The hard reset is done! Optimus Sydney
Optimus Sydney
Optimus Sydney
Optimus Sydney
Optimus Sydney
Optimus Sydney
Optimus Sydney
Optimus Sydney
Optimus Sydney
Optimus Sydney
Optimus Sydney 1: In the first step hold down the Power key for a short while in order to switch off the smartphone. 2: Then press and hold together the Volume Up + Power key for a few seconds. 3: Next, hold down the Power key in order to go into Recovery Mode. 4: While holding Power key hit the Volume Up button once. 5: Use the Volume buttons to select "wipe data/factory reset" and tap the Power button to confirm. 6: Afterwards choose "yes" from the menu, and accept it with Power button. 7: As soon as the Recovery Mode appears again on the screen accept option "reboot system now" using Power rocker. 8: Excellent! The factory reset operation should be completed. Optimus Sydney 1: The smartphone must be switched off, so hold down the Power key for a short while. 2: After that, press and hold together the Volume Up + Power key for a few seconds. 3: Hold down the Power key in order to go into Recovery Mode. 4: While holding Power key press Volume Up button once. 5: Then use Volume buttons to select "wipe data/factory reset" and tap the Power button to confirm. 6: Afterwards choose "yes" from the menu, and accept it with Power button. 7: As soon as the Recovery Mode appears again on the screen accept option "reboot system now" using Power rocker. 8: Excellent! The factory reset operation should be completed. Optimus Sydney 1: First of all, hold down the Power key in order to switch off the cell phone. 2: After that, press and hold together the Volume Up + Power key for a few seconds 3: Let go of all keys as soon as the Android Robot pops up. 4: Hold down the Power key in order to go into Recovery Mode. 5: While holding Power key press Volume Up button once. 6: Then use Volume buttons to select "wipe data/factory reset" and tap the Power button to confirm. 7: Afterwards choose "yes" from the menu, and accept it with Power button. 8: As soon as the Recovery Mode appears again on the screen accept option "reboot system now" using Power rocker. 9: Excellent! The factory reset operation should be completed. Optimus Sydney 1: In the first step hold down the Power key in order to switch off the cell phone. 2: After that, press and hold together the Volume Up + Power key for a few seconds. 3: Let go of all keys as soon as the Android Robot pops up. 4: Hold down the Power key in order to go into Recovery Mode. 5: While holding Power key press Volume Up button once. 6: Then use Volume buttons to select "wipe data/factory reset" and tap the Power button to confirm. 7: Afterwards choose "yes" from the menu, and accept it with Power button. 8: As soon as the Recovery Mode appears again on the screen accept option "reboot system now" using Power rocker. 9: Excellent! The factory reset operation should be completed. Optimus Sydney
Optimus Sydney
Optimus Sydney
Optimus Sydney 1: First of all switch off the device by pressing the Power button. 2: In the next step hold down Volume Up + Power button for about 10 seconds. 3: You can release held keys when you see the Android Robot. 4: To enter the Recovery Mode hold down the Power key for a short while. 5: From the menu choose "Wipe Data/Factory Reset" by using Volume buttons to scroll and Power button to select options. 6: Tap "yes" to confirm the operation if you are certain you want to clear all your data. 7: Use the Power button to accept option "reboot system now". 8: Good job! Optimus Sydney 1: Begin by holding down the Power key for a few moments in order to switch off the cell phone 2: In the next step press and hold simultaneously the Volume Up + Volume Down + Power button for a few seconds. 3: You should release held keys as soon as the menu with two options appears on the screen. 4: Then hold down the Volume Up key in order to choose Recovery Mode. 5: When an Android Image displays on the screen press the Power button for a short while. 6: In order to choose "wipe data/factory reset" use the Volume Down to navigate and the Power button to confirm. 7: Next, select "Yes--delete all user data". Use Volume Down button to scroll and Power key to select. 8: To restart the phone, select "reboot system now". 9: Congratulations! You have just performed the hard reset operation. Optimus Sydney 1: In the first step hold down the Power key for a short while in order to switch off the device. 2: Afterwards press and hold simultaneously the Volume Up + Power button for a few seconds. 3: You should release held keys as soon as the menu with two options appears on the screen. 4: Then hold down the Volume Up key in order to choose Recovery Mode. 5: When an Android Image displays on the screen press the Power button for a short while. 6: In order to choose "wipe data/factory reset" use the Volume Down to navigate and the Power button to confirm. 7: Next, select "Yes--delete all user data". Use Volume Down button to scroll and Power key to select 8: To restart the phone, select "reboot system now". 9: Success! Your phone should begin the hard reset operation. Optimus Sydney 1: Begin by holding down the Power key for a few moments in order to switch off the cell phone 2: In the next step press and hold simultaneously the Volume Up + Power button for a few seconds. 3: You should release held keys as soon as the menu with two options appears on the screen. 4: Then hold down the Volume Up key in order to choose Recovery Mode. 5: When an Android Image displays on the screen press the Power button for a short while. 6: In order to choose "wipe data/factory reset" use the Volume Down to navigate and the Power button to confirm. 7: Next, select "Yes--delete all user data". Use Volume Down button to scroll and Power key to select. 8: To restart the phone, select "reboot system now". 9: Congratulations! You have just performed the hard reset operation. Optimus Sydney 1: Start by switching off the device by holding down the Power key for a short while. 2: In the next step press and hold together the Volume Up + Power button for a couple of seconds. 3: Release held keys as soon as the menu with two options appears on the screen. 4: Afterwards hold down the Volume Up key in order to choose Recovery Mode. 5: When an Android Image displays on the screen press the Power button for a short while. 6: In order to choose "wipe data/factory reset" use the Volume Down to navigate and the Power button to confirm. 7: Next, select "Yes--delete all user data". Use Volume Down button to scroll and Power key to select. 8: To restart the phone, select "reboot system now 9: Success! Your phone should begin the hard reset operation. Optimus Sydney 1: In the first step hold down the Power key for a short while in order to switch off the device. 2: Afterwards press and hold simultaneously the Volume Up + Power button for a few seconds. 3: You should release held keys as soon as the menu with two options appears on the screen. 4: Then hold down the Volume Up key in order to choose Recovery Mode. 5: When an Android Image displays on the screen press the Power button for a short while. 6: In order to choose "wipe data/factory reset" use the Volume Down to navigate and the Power button to confirm 7: Next, select "Yes--delete all user data". Use Volume Down button to scroll and Power key to select. 8: To restart the phone, select "reboot system now". 9: Success! Your phone should begin the hard reset operation. Optimus Sydney 1: Start by turning off the phone, by using the Power button. 2: Afterwards press and hold together the Volume Up and Power key for a few seconds. 3: You can release held keys when you see an Android icon. 4: Then use Volume buttons to select "wipe data/factory reset" and tap the Power button to confirm. 5: Afterwards choose "yes" from the menu, and accept it with Power button. 6: When a Recovery Mode appears again on the screen accept option "reboot system now" using Power rocker. 7:That's all. The hard reset operation should be completed. Optimus Sydney 1: Power on your device. 2: Just type this: 277634#*# or47328545454# 3: Then select "Factory Reset". 4: Done! Optimus Sydney 1: Turn on the device. 2: Press this in sequence: 277634#*# or47328545454# 3:After that choose "Factory Reset". 4: Next your phone will reset and restarts. 5:Success! Optimus Sydney
Optimus Sydney
Optimus Sydney
Optimus Sydney
Optimus Sydney
Optimus Sydney
Optimus Sydney
Optimus Sydney 1: Switch off your device. 2:Now hold and press Volume Up + Volume Down + Power button. 3:Then select Recovery mode with taping Menu key. 4:Accept option "wipe data/factory reset" using Volume buttons, and confirm with Menu key. 5:Next select "Yes -- delete all user data". 6:Afterwards choose "reboot system now". 7:Success! Optimus Sydney 1-Power Off Your Phone Take The battery Out and Reinsert 2-Press and Hold Volume Down Button and Power On it will show an Exclamation Mark 3-Next press the keys in this Order Press Volume Up then Volume Down then Power And Again Volume Down The Process Will Start Automatically 4:Success! |
