Super Moderator
Member: 824
Thanks Meter: 24,876 | All Qmobile hard reset easy way HELLO GUYS!
I will show you very easy way to QMobile hard reset step by step guide.
All QMobiles Hard Reset Via Hot Key Optimus Sydney - Power off your cell phone.
- Next hold and press Volume Up + Volume Down + Power button.
- Then you will see menu with 2 options.
- Select first "Recovery mode" by pressing Volume Up key.
- Now choose from the next menu option "wipe data / factory reset" using Volume Down to scroll, and Menu key to confirm.
- Afterwards select "Yes -- delete all user data".
- In the end confirm option "reboot system now" with Menu key.
- Success!
Optimus Sydney
1: In order to turn off the device press the Power button for a couple of seconds.
2: Afterwards press and hold together the Volume Up + Power key for a few seconds.
3: Then select option Recovery by using to navigate Volume Up, and to confirm Volume Down key.
4: As soon as the Android Image shows up on the screen hold down the Power key for a couple of seconds.
5: While you holding the Power button quickly press the Volume Up key.
6: Aftert that use the Volume Down to choose "wipe data/factory reset", and then push the Power button to confirm.
7: Select "Yes--delete all user data". Use Volume Down button to scroll and Power button to select.
8: To restart the phone, select "reboot system now"
9: Success! The hard reset is done! Optimus Sydney - Switch off your device.
- Reset QMOBILE Bolt A2 Lite
- Now hold and press Volume Up + Volume Down + Power button.
- Then select Recovery mode with taping Menu key.
- Accept option "wipe data/factory reset" using Volume buttons, and confirm with Menu key.
- Next select "Yes -- delete all user data".
- Afterwards choose "reboot system now".
- Success!
Optimus Sydney - Press Power button, until your phone is off.
- Press and hold together Volume Up + Volume Down + Power button.
- Now from the menu select option "Recovery mode" using Volume Up button.
- From the next menu choose "wipe data / factory reset" using Volume Down to browse, and Menu key to confirm.
- After that aceept this "reboot system now".
- Success!
Optimus Sydney - Switch off your handset.
- Next hold and press Volume Up + Volume Down + Power button, until you see menu with 2 options.
- From this menu choose option "Recovery mode" using Volume Up key.
- In Recovery mode choose option "wipe data/factory reset" using Volume buttons to scroll options, and Square Button(Menu key) to confirm.
- * This key is situated at Bottom Left of your phone.
- Now confirm option "Yes -- delete all user data".
- After that select "reboot system now".
- Good job!
- Next hold and press Volume Down + Power button for couple seconds.
- From the Factory Mode choose option "Clear eMMC" using Volume Down to scroll, and Power button to confirm.
- Now your phone will reset.
- After that select option "Reboot".
- Done!
- Next hold and press Volume Up + Volume Down + Power button, until you see menu of Factory/Recovery mode.
- Then select Recovery mode using Volume Up to confirm.
- Now scroll to option "wipe data/factory reset" using Volume Down to scroll, and Menu key to confirm.
- Afterwards choose "Yes -- delete all user data".
- In the end confirm option "reboot system now" using Menu key.
- Done!
- Next hold and press Volume Up + Power button.
- * If Volume Up key doesn't work, then press Volume Down.
- When you see logo of your phone, then release only Volume key.
- If you see Recovery mode, then release Power button.
- Now select "wipe data/factory reset" using Volume buttons to scroll, and Home button to confirm.
- Then choose option "Yes -- delete all user data".
- After that select "reboot system now" with Home button.
- Good job!
Optimus Sydney - Switch off your cell phone.
- Next hold and press this keys: Volume Up + Volume Down + Power button, or Volume Up + Power button.
- Then select this option "Recovery mode" using Volume Up button.
- Now from the menu of Recovery mode select "wipe data / factory reset" using Volume Down to scroll, and Menu key to confirm.
- In the end to reboot your phone select "reboot system now".
- Well done!
Optimus Sydney - Turn off your phone.
- Now press and hold this buttons: Volume Up + Volume Down + Power button.
- When you see menu with 2 options, then release holded buttons.
- Then choose option "Recovery mode" by pressing Volume Up key.
- Next select option "wipe data / factory reset" using Volume Down to navigate, and Menu key to accept option.
- Accept this "Yes -- delete all user data", and wait.
- Afterwards confirm operation "reboot system now".
- The end!
- Success!
- Then press Volume Up to enter to Recovery mode.
- Now use Volume Down to confirm your choice.
- After that from the menu choose option "wipe data/factory reset" using Volume buttons to choose, and Menu key to confirm.
- In the end accept option "reboot system now" with Menu key.
- Good job!
Optimus Sydney
1: In the first step hold down the Power key for a short while in order to switch off the smartphone.
2: Then press and hold together the Volume Up + Power key for a few seconds.
3: Next, hold down the Power key in order to go into Recovery Mode.
4: While holding Power key hit the Volume Up button once.
5: Use the Volume buttons to select "wipe data/factory reset" and tap the Power button to confirm.
6: Afterwards choose "yes" from the menu, and accept it with Power button.
7: As soon as the Recovery Mode appears again on the screen accept option "reboot system now" using Power rocker.
8: Excellent! The factory reset operation should be completed. Optimus Sydney
1: The smartphone must be switched off, so hold down the Power key for a short while.
2: After that, press and hold together the Volume Up + Power key for a few seconds.
3: Hold down the Power key in order to go into Recovery Mode.
4: While holding Power key press Volume Up button once.
5: Then use Volume buttons to select "wipe data/factory reset" and tap the Power button to confirm.
1: First of all, hold down the Power key in order to switch off the cell phone.
3: Let go of all keys as soon as the Android Robot pops up.
4: Hold down the Power key in order to go into Recovery Mode.
5: While holding Power key press Volume Up button once.
6: Then use Volume buttons to select "wipe data/factory reset" and tap the Power button to confirm.
7: Afterwards choose "yes" from the menu, and accept it with Power button.
8: As soon as the Recovery Mode appears again on the screen accept option "reboot system now" using Power rocker.
9: Excellent! The factory reset operation should be completed. Optimus Sydney
1: In the first step hold down the Power key in order to switch off the cell phone.
9: Excellent! The factory reset operation should be completed. Optimus Sydney - The smartphone must be switched off, so hold down the Power key for a short while.
- After that, press and hold together the Volume Up + Power key for a few seconds.
- When the Android Robot appears on the screen release held keys.
- Hold down the Power key in order to go into Recovery Mode.
- While holding Power key press Volume Up button once.
- Then use Volume buttons to select "wipe data/factory reset" and tap the Power button to confirm.
- Afterwards choose "yes" from the menu, and accept it with Power button.
- As soon as the Recovery Mode appears again on the screen accept option "reboot system now" using Power rocker.
- Excellent! The factory reset operation should be completed.
Optimus Sydney - Turn off the smartphone by holding down the Power key for a short while.
- Release all keys as soon as Android Robot appears in front of you.
- As soon as the Recovery Mode appears again on the screen accept option "reboot system now" using Power rocker,
Optimus Sydney - At first, switch off the tablet by pressing the Power button.
- Then hold down Volume Up + Power button for about 10 second
- Release held keys when you see the Android Robot
- To enter the Recovery Mode hold down the Power key for a short while
- From the menu choose "Wipe Data/Factory Reset" by using Volume buttons to scroll and Power button to select options.
- Tap "yes" to confirm the operation if you are certain you want to clear all your data
- Use the Power button to accept option "reboot system now"..
- Good job!
Optimus Sydney
1: First of all switch off the device by pressing the Power button.
2: In the next step hold down Volume Up + Power button for about 10 seconds.
3: You can release held keys when you see the Android Robot.
4: To enter the Recovery Mode hold down the Power key for a short while.
5: From the menu choose "Wipe Data/Factory Reset" by using Volume buttons to scroll and Power button to select options.
6: Tap "yes" to confirm the operation if you are certain you want to clear all your data.
7: Use the Power button to accept option "reboot system now".
8: Good job! Optimus Sydney
1: Begin by holding down the Power key for a few moments in order to switch off the cell phone
2: In the next step press and hold simultaneously the Volume Up + Volume Down + Power button for a few seconds.
3: You should release held keys as soon as the menu with two options appears on the screen.
4: Then hold down the Volume Up key in order to choose Recovery Mode.
5: When an Android Image displays on the screen press the Power button for a short while.
6: In order to choose "wipe data/factory reset" use the Volume Down to navigate and the Power button to confirm.
7: Next, select "Yes--delete all user data". Use Volume Down button to scroll and Power key to select.
8: To restart the phone, select "reboot system now".
9: Congratulations! You have just performed the hard reset operation. Optimus Sydney
1: In the first step hold down the Power key for a short while in order to switch off the device.
2: Afterwards press and hold simultaneously the Volume Up + Power button for a few seconds.
9: Success! Your phone should begin the hard reset operation. Optimus Sydney
2: In the next step press and hold simultaneously the Volume Up + Power button for a few seconds.
1: Start by switching off the device by holding down the Power key for a short while.
2: In the next step press and hold together the Volume Up + Power button for a couple of seconds.
3: Release held keys as soon as the menu with two options appears on the screen.
4: Afterwards hold down the Volume Up key in order to choose Recovery Mode.
1: Start by turning off the phone, by using the Power button.
2: Afterwards press and hold together the Volume Up and Power key for a few seconds.
3: You can release held keys when you see an Android icon.
4: Then use Volume buttons to select "wipe data/factory reset" and tap the Power button to confirm.
5: Afterwards choose "yes" from the menu, and accept it with Power button.
6: When a Recovery Mode appears again on the screen accept option "reboot system now" using Power rocker.
7:That's all. The hard reset operation should be completed. Optimus Sydney
1: Power on your device.
2: Just type this: 277634#*# or47328545454#
3: Then select "Factory Reset".
4: Done! Optimus Sydney
1: Turn on the device.
2: Press this in sequence: 277634#*# or47328545454#
3:After that choose "Factory Reset".
4: Next your phone will reset and restarts.
5:Success! Optimus Sydney - Switch on the cell phone.
- Tap this secret code: 277634#*# or 47328545454#
- Afterwards accept operation "Factory Reset".
- Now your handset will reset and reboots.
- Good job!
Optimus Sydney - Make sure, that your handset is on.
- Now enter this code: 277634#*# or47328545454#
- Then navigate to "Factory Reset", and accept it.
- Afterwards you will see, that your phone will reset and restarts with factory settings.
- Finito!
- Finito!
- Tap this secret code: 277634#*# or47328545454#
- Good job!
Optimus Sydney - Turn on the device.
- Press this in sequence: 277634#*# or47328545454#
- After that choose "Factory Reset".
- Next your phone will reset and restarts.
- Success!
Optimus Sydney - Power on your device.
- Just type this: 277634#*# or47328545454#
- Then select "Factory Reset".
- Done!
Optimus Sydney - Press Power button to turn on your device.
- Tap this code: 277634#*# or47328545454#
- Now select "Factory Reset".
- After that your phone will reset and reboots.
Optimus Sydney
1: Switch off your device.
2:Now hold and press Volume Up + Volume Down + Power button.
3:Then select Recovery mode with taping Menu key.
4:Accept option "wipe data/factory reset" using Volume buttons, and confirm with Menu key.
5:Next select "Yes -- delete all user data".
6:Afterwards choose "reboot system now".
7:Success! Optimus Sydney
1-Power Off Your Phone Take The battery Out and Reinsert
2-Press and Hold Volume Down Button and Power On it will show an Exclamation Mark
3-Next press the keys in this Order Press Volume Up then Volume Down then Power And Again Volume Down The Process Will Start Automatically
4:Success!
__________________ Just Follow the Rules and Be Polite
Saying "thank you" can be hard. But it's so important. |
