Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Lenovo
Lenovo General Lenovo phones discussion, firmwares, solution, help
Old 01-11-2017, 02:41   #1 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
need help in zuk z2132 flashing
phone come in frp i reset in fast boot mode after reset phone show zuk logo then black screen i got qfil firmwer
but phone cant be canect in 9008 port
i press both volume up and down any one help who flash this handset ?
Old 01-11-2017, 06:43   #2 (permalink)
Prem_India's Avatar
Member: 718725
Sonork: 100.1604953 QQ 2339690693
Thanks Meter: 6,702
USE Fastboot EDL Command OR MI Boot Cable Than Enter In EDL Mode
Here Flashing Success Post
http://forum.gsmhosting.com/vbb/12269666-post2.html
Old 01-11-2017, 22:09   #3 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
Originally Posted by prem_india View Post
use fastboot edl command or mi boot cable than enter in edl mode
here flashing success post
i try mi boot cabel but can not enter 9008 port
Old 01-11-2017, 22:39   #4 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 7,785
Try with volume keys and power on key, while cable connected,
there should be some menu when holding power + up or down volume keys,
and in that menu - option "Download". That's 9008 port mode .
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 01-12-2017, 09:31   #5 (permalink)
tapas770's Avatar
Member: 2171294
Sonork: 100.1659207(No More Use)
Thanks Meter: 706
Wink Instructions for installing firmware for Lenovo devices based on Qualcomm
Instructions for installing firmware for Lenovo devices based on Qualcomm...
It is recommended to all the manipulations on the firmware to make a backup copy of the EFS (if you do not already have sewn for the apparatus)
Warning:
Regardless of what you currently installed firmware, the settings menu to delete the account and make a factory reset !!!
Preparation
1. Download the utility QPST and drivers.
2. Set "vcredist_x86.exe". File embedded in QPST set.
3. Set the "flasher" - "QPST.XX.msi".
4. Install the drivers for the Qualcomm chips (downloaded above). It is desirable to disable the currently online. Windows sometimes sets "RELINK HS-USB QDLoader ...". It is necessary to remove them by clicking on the driver, open the context menu and click the "Delete" tick: Delete the driver software for this device.
5. Fully turn off the machine sews.
6. Tighten the volume up button (Volume Up), and holding it to connect USB-cable which is already connected to the USB 2.0 port of your PC.
7. In the "Device Manager" you should see the device "Qualcomm / Lenovo HS-USB QDLoader 9008".
8. Perform pairing the device with a package QPST (with item 4) to "Qualcomm Lenovo HS-USB QDLoader 9008".
Then flash
1. Unzip the firmware on any drive, preferably in the root and the shortest path
2.Open QFIL
3. In the "Programmer patch" Knop click on "Browse", in the window that opens, navigate to the folder with the firmware (in the example: ROW_S121), select the file "prog_emmc_firehose_89XX.mbn" (Example: prog_emmc_firehose_8916.mbn), click "Open" .
4. Press digging "Load XML ...", alternately pick in the window that opens - first "rawprogram0.xml", click "Open", then "patch0.xml" - "Open"
5. Open the "Task Manager". Make sure that QFIL program identifies the device as a Qualcomm Lenovo HS-USB QDLoader 9008.
6. Click on the "Download" button and wait for the end of the process. The device should restart at the successful process of firmware and boot into Android OS.
Here Video tutorials For Load XML File...
http://www.youtube.com/watch?v=g8d5g7la4z0
7. All Finished...Wait until flashing succes confirmation...
Old 12-22-2017, 20:05   #6 (permalink)
mundatelecom's Avatar
Member: 1841619
Thanks Meter: 50
Zuk zuk2 edl mode
press vol up and power key insert cable immediately continuously press vol up and power until hose to edl mode
The Following User Says Thank You to mundatelecom For This Useful Post:
Page generated in 0.16037 seconds with 8 queries
