07-06-2021, 14:43 | #40 (permalink) |
No Life Poster Join Date: Nov 2013 Location: pakistan P G L Age: 39
Member: 2067643 Status: Offline Sonork: 1611265 Thanks Meter: 474 | oppo a37f Device : Oppo A37f Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM50) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8916_014]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8916, EMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : OPPO A37f [msm8916] Brand : OPPO Prod.Name : A37f Software : A37fEX_11_190711, 1480422943 [Thu Jul 11 03:29:34 CST 2019] Android Ver. : 5.1.1 Patch Level : 2018-03-01 Formatting userdata [SafeMode]...Done Resetting FRP Lock......Done Operation Finished. |
The Following User Says Thank You to iftikharrana58 For This Useful Post: |
07-07-2021, 22:28 | #41 (permalink) |
Freak Poster Join Date: Dec 2013 Location: Mourocco Unlock Age: 42
Member: 2082183 Status: Offline Sonork: 100.1638535 Thanks Meter: 53 | Executing Loader...Failed! Possibly Wrong Loader Operation : Reset Mi Account (New) Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM13) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1500A00 [SD855] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Sending Loader [prog_ufs_firehose_sdm855_ddr.elf]...Done Executing Loader...Failed! Possibly Wrong Loader Please select Loader manually, or use Factory Loader in Custom Option. Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 7.0 |
07-08-2021, 14:40 | #43 (permalink) |
Freak Poster Join Date: Apr 2009 Location: kolkata
Member: 1015679 Status: Offline Thanks Meter: 15 | forbidden application 03 detected umt dear sir i have installed new version(7.0) since then this error is coming (forbidden application 03 detected umt) i have not use any usb sharing software. flexihub,WinPCap or USBPCap i have find npf.sys in System32\Drivers folder. i am not able to delete or rename it Edition Windows 10 Pro Version 20H2 Installed on 15-05-2021 OS build 19042.1083 Experience Windows Feature Experience Pack 120.2212.3530.0 system type- 64-bit operating system, x64-based processor |
07-08-2021, 15:36 | #44 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
Br, UMT | |
