05-31-2019, 18:25 | #50 (permalink) |
Freak Poster Join Date: Nov 2016 Location: India
Member: 2650288 Status: Offline Sonork: live:hackb151 Thanks Meter: 153 | vivo v9 1723 rest lock done Operation : Reset Locks (Vivo) Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM98) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_014]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1723 Software : OPM1.171019.026 release-keys, eng.compil.20190218.190612 [Mon Feb 18 19:06:12 CST 2019] Android Ver. : 8.1.0 Patch Level : 2019-02-01 USERDATA : Encrypted Reading Extended Information...OK Model : vivo 1723 Product : PD1730F_EX Cust. Name : PD1730F_EX_IN_NULL_NULL Version : PD1730F_EX_A_1.11.12 Resetting Locks (Vivo)...Done Please wait for phone to reboot. Operation Finished. |
The Following User Says Thank You to neyaz007 For This Useful Post: |
06-01-2019, 03:24 | #51 (permalink) |
Junior Member Join Date: Nov 2018 Location: punjab
Member: 2878314 Status: Offline Thanks Meter: 3 | unable repair imei of vivo y55s. qc fire says success but imei stil invalid. i also downgrade modem to lower version. but when i read imei with any tool both imei numbers are correct. what to do . |
06-01-2019, 22:28 | #52 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,447 | Quote:
Next time, you must post logs / screenshots so we can see it. Br, UMT | |
06-02-2019, 09:11 | #53 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 705173 Status: Offline Thanks Meter: 57 | vivo v7+ done Operation : Format FS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM36) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1716 [msm8953] Software : N2G47H release-keys, eng.compil.20180528.223559 [Mon May 28 22:35:59 CST 2018] Android Ver. : 7.1.2 Patch Level : 2018-05-01Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 4.2 |
The Following User Says Thank You to MONU5363 For This Useful Post: |
06-02-2019, 12:43 | #56 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2211005 Status: Offline Sonork: no Thanks Meter: 1 | Xiaomi Redmi Note 6 Pro evice : Xiaomi Redmi Note 6 Pro Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : HS-USB Diagnostics 9008 (COM10) Driver Info : Mobile, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : Xiaomi Redmi Note 6 Pro Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...Failed VIP Enabled / Auth Enabled Device! |
06-05-2019, 07:44 | #58 (permalink) |
Insane Poster Join Date: Apr 2019 Location: Toamasina Madagascar
Member: 2903727 Status: Offline Thanks Meter: 22 | Please ADD more OPPO Hello Sir! Thanks for your hard work so We are waiting for These Models In Next Update: A3S (CPH1803) A5 (CPH1809) A7 (CPH1901) A83(2018) (CPH1729) F5 (CPH1723) F5 YOUTH (CPH1725) F7 (CPH1819) F9 (CPH1881) F9 PRO (CPH1823) REALME 1 (CPH1859) REALME 2 (RMX1805) REALME C1 (RMX1811) REALME 2 PRO (RMX1801) |
06-05-2019, 18:08 | #59 (permalink) |
Crazy Poster Join Date: May 2012
Member: 1756543 Status: Offline Thanks Meter: 3 | Operation : Format Userdata Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1100900 [E1100900] 03007300 OPK_DATA : 7C81953E833D16B94703B743C9B7F41CBF1608F0990A4C2B3A 112C52810CB8F1 Initializing Protocol...OK Sending Loader [prog_firehose_ddr.elf]...Done Executing Loader...OK Initiazling Storage...OK Read : Not Allowed Write : Not Allowed Formatting userdata...Failed Operation Failed. QcFire Ver. 4.2 am trying to remove user password x23 vivo got the firmware but ever complaining about loader |
06-05-2019, 18:22 | #60 (permalink) |
Member: 1756543 Status: Offline Thanks Meter: 3 | Operation : Reset Locks (Vivo) Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1100900 [E1100900] 03007300 OPK_DATA : 7C81953E833D16B94703B743C9B7F41CBF1608F0990A4C2B3A 112C52810CB8F1 Initializing Protocol...OK Sending Loader [prog_firehose_ddr.elf]...Done Executing Loader...OK Using User Defined Storage Type : UFS Using Alternate Method... Hardware : E1100900, UFS, ERASED GPT Payload Info : In: 262144 [65536], Out: 1048576, Sector Size: 4096 Reading Partition Table...OK SYSTEM partition is missing! USERDATA : Encrypted Reading Extended Information...Missing! Ignored Resetting Locks (Vivo)...Data Missing! Operation Failed. QcFire Ver. 4.2 |
The Following User Says Thank You to alimawanda For This Useful Post: |
