06-05-2019, 18:50 | #62 (permalink) | |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,267 | Quote:
You keep waiting once it is done we will announce in update for sure | |
06-12-2019, 10:22 | #64 (permalink) |
Insane Poster Join Date: Jan 2016 Location: Derbent
Member: 2516133 Status: Offline Thanks Meter: 55 | Still same problem while flashing Redmi Note 5 android 9.0 but android 8.1 is ok. Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Writing [storsec.mbn] -> [storsec] ...Done Writing [storsec.mbn] -> [storsecbak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [hyp.mbn] -> [hyp] ...Done Writing [hyp.mbn] -> [hypbak] ...Done Writing [pmic.elf] -> [pmic] ...Done Writing [pmic.elf] -> [pmicbak] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib.mbn] -> [cmnlibbak] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done Writing [abl.elf] -> [abl] ...Done Writing [abl.elf] -> [ablbak] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [mdtpsecapp.mbn] -> [mdtpsecapp] ...Done Writing [mdtpsecapp.mbn] -> [mdtpsecappbak] ...Done Writing [keymaster.mbn] -> [keymaster] ...Done Writing [keymaster.mbn] -> [keymasterbak] ...Done Writing [BTFM.bin] -> [bluetooth] ...Done Writing [xbl.elf] -> [xbl] ...Done Writing [xbl.elf] -> [xblbak] ...Done Writing [dspso.bin] -> [dsp] ...Done Writing [mdtp.img] -> [mdtp] ...Done Writing [splash.img] -> [splash] ...Done Writing [NON-HLOS.bin] -> [modem] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [cache.img ] -> [cache]...Done Writing [system.img ] -> [system]... Operation Finished. QcFire Ver. 4.2 Please solve it. Can not flash any xiaomi device with android 9.0. Thanks. |
The Following User Says Thank You to ramsay05 For This Useful Post: |
06-12-2019, 16:41 | #65 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,452 | Quote:
Br, UMT | |
The Following User Says Thank You to U.M.T For This Useful Post: |
06-14-2019, 19:53 | #66 (permalink) |
Freak Poster Join Date: Nov 2016 Location: India
Member: 2650288 Status: Offline Sonork: live:hackb151 Thanks Meter: 153 | hallo sir why this error card expire Card ID: UMT990 Connecting to server... [updatecard]Card activation expired, contact your reseller and renew activation. Card active untill: Thursday 13 of September 2018 Ultimate Multi Tool 1 Year Activation |
06-14-2019, 23:56 | #67 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2648991 Status: Offline Thanks Meter: 0 | xiomi note 5 8.0 Operation : Full Reset EFS Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM37) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...Failed VIP Enabled / Auth Enabled Device! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 4.2 |
06-15-2019, 08:31 | #68 (permalink) | |
Insane Poster Join Date: Aug 2016 Location: kolkata
Member: 2616576 Status: Offline Sonork: 100.1674982 Thanks Meter: 24 | Quote:
does redmi 6 pro redmi note 6 pro and note 7 reset mi account is supported?? | |
