11-23-2018, 15:28 | #5626 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | Vestel DynoLight [msm8909] Reset Frp Done Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM25) Driver Info : Qualcomm Incorporated, qu_usb_serial.sys, 2.1.2.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 8 GB LU Count : 1 [0x00E90000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Vestel DynoLight [msm8909] Software : VDL371 release-keys, eng.buildserver.20161018.142914 [Tue Oct 18 14:31:46 EEST 2016] Android Ver. : 6.0.1 Patch Level : 2016-10-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 3.3 |
The Following User Says Thank You to orhan5 For This Useful Post: |
11-23-2018, 19:37 | #5627 (permalink) |
Junior Member Join Date: Nov 2014 Location: Vietnam
Member: 2293053 Status: Offline Sonork: +84908182048 Thanks Meter: 14 | Port : Fastboot Interface Baud Rate : Not Applicable Device : ASUS X00DD Operation : FRP Reset Searching for Device in FastBoot Mode... OK Reading Information... OK FastBoot Ver. : GetVar Variable Not found Product : QC_Reference_Phone Bootloader : Locked Enabling ADB... OK Failed Operation Failed. Elapsed Time: 00:38 Asus Zenfone 5 ZE620KL enable adb done |
The Following User Says Thank You to long_101176 For This Useful Post: |
11-24-2018, 13:07 | #5630 (permalink) |
Freak Poster Join Date: Sep 2006 Location: INDIA Age: 48
Member: 350948 Status: Offline Thanks Meter: 32 | itel A20 FRP REMOVED SUCCESFULLY Itel A20 FRP removed by UMT succefully Firt put mobile in fastboot mode & then open UMT GSM TOOL select Miscellaneous & click on SPD FRP reset |
11-24-2018, 15:11 | #5631 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 577307 Status: Offline Thanks Meter: 58 | Huawei P20 Lite ANE-LX1 frp done in one click thank you umt Port : Not Applicable Baud Rate : Not Applicable Device : Huawei P20 Lite ANE-LX1 Operation : Remove FRP Enabling ADB Mode... OK Waiting for device... Found! Model : ANE-LX1 Version : 8.0.0 Build : ANE-LX1-user 8.0.0 HUAWEIANE-LX1 142(C185) release-keys Hardware : hi6250 Removing FRP Lock... Done Operation Finished. Elapsed Time: 02:53 [Module Ver. 5.2] Log Saved to Logs\181124_192406.log |
The Following User Says Thank You to B.thirumalaraju For This Useful Post: |
11-24-2018, 22:26 | #5632 (permalink) | |
No Life Poster Join Date: Jan 2012 Location: Morocco
Member: 1712203 Status: Offline Thanks Meter: 354 | Infinix Hot 6 Pro frp done . Quote:
The Following User Says Thank You to apologized For This Useful Post: |
11-24-2018, 22:26 | #5633 (permalink) | |
Member: 1712203 Status: Offline Thanks Meter: 354 | samsung G532F frp done . Quote:
11-25-2018, 08:50 | #5634 (permalink) |
Freak Poster Join Date: Jun 2009
Member: 1051138 Status: Offline Sonork: 123456 Thanks Meter: 382 | TECNO-IN5 frp Brand : Tecno Model : IN5 Operation : Reset FRP Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM Port (COM8) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing Target...OK Reading Partition Table...OK Reading Device Information...OK Brand : TECNO Manufacturer : TECNO Model : TECNO IN5 Prod. Name : H3721A1 Device : TECNO-IN5 Platform : mt6737t Android Ver. : 7.0 Display ID : IN5-H3721A-N-IN-180324V113 Patch Level : 2018-02-05 Userdata is ENCRYPTED Seeking FRP Data...Found Resetting FRP...OK Operation Finished. UltimateFRP Ver. 0.4 |
The Following User Says Thank You to akeel2000 For This Useful Post: |
11-25-2018, 14:17 | #5635 (permalink) |
No Life Poster Join Date: Apr 2008 Location: India
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Nubia NX569J Frp Code: Device : ZTE Nubia NX569J Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Qualcomm Incorporated, qcusbser.sys, 5.1.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1009900 [8976] 00000400 OPK_DATA : AD77E71A4DB8BE9E492E367384C7B01862DCA1E8A3C7BFE0F7CE6CED4C964295 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8976_009]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8976, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : nubia NX569J [msm8952] Software : NX569J_ENCommon_V1.07, eng.nubia.20170505.165817 [Fri May 5 17:01:56 CST 2017] Android Ver. : 6.0.1 Patch Level : 2017-02-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 3.3 |
The Following User Says Thank You to VIJAY2U2 For This Useful Post: |
11-25-2018, 14:20 | #5636 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Vivo Y53 Pinlock+Frp Code: Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM10) Driver Info : Qualcomm Incorporated, qcusbser.sys, 5.1.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4FFF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917_001]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo PD1628F_EX [msm8937] Software : MMB29M release-keys, eng.compiler.20181008.154817 [Mon Oct 8 15:54:58 CST 2018] Android Ver. : 6.0.1 Patch Level : 2018-08-01 Preparing Data...Done Formatting Userdata...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 3.3 |
11-25-2018, 14:21 | #5637 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Micromax Q4202 Frp Code: Device : Micromax Q4202 Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM33) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 8 GB LU Count : 1 [0x00E90000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Micromax Micromax Q4202 [msm8909] Software : MMX_Q4202_IND_SW_V3.0_HW_V0.2_06032017, eng.spwork.20170306.211258 [Mon Mar 6 21:19:21 CST 2017] Android Ver. : 6.0.1 Patch Level : 2017-02-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 3.3 |
11-25-2018, 14:23 | #5638 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Jio Phone F30c Flashing Code: Operation : Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM33) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1400900 [8909] 00000000 OPK_DATA : C02DD744909A3EB457FF7E3528CB17435EF4A2D1B64B1DA2EA646B55A0748744 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8909_ddr.mbn]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 4 GB LU Count : 1 [0x00710000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Writing [NON-HLOS.bin] -> [modem] ...Done Writing [sbl1.mbn] -> [sbl1] ...Done Writing [sbl1.mbn] -> [sbl1bak] ...Done Writing [emmc_appsboot.mbn] -> [aboot] ...Done Writing [emmc_appsboot.mbn] -> [abootbak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [splash.img] -> [splash] ...Done Writing [sec.dat] -> [sec] ...Done Writing [system_1.img] -> [system] ...Done Writing [system_2.img] -> [system] ...Done Writing [system_3.img] -> [system] ...Done Writing [system_4.img] -> [system] ...Done Writing [system_5.img] -> [system] ...Done Writing [system_6.img] -> [system] ...Done Writing [system_7.img] -> [system] ...Done Writing [system_8.img] -> [system] ...Done Writing [system_9.img] -> [system] ...Done Writing [system_10.img] -> [system] ...Done Writing [system_11.img] -> [system] ...Done Writing [persist_1.img] -> [persist] ...Done Writing [usbmsc_1.img] -> [usbmsc] ...Done Writing [usbmsc_2.img] -> [usbmsc] ...Done Writing [usbmsc_3.img] -> [usbmsc] ...Done Writing [usbmsc_4.img] -> [usbmsc] ...Done Writing [usbmsc_5.img] -> [usbmsc] ...Done Writing [usbmsc_6.img] -> [usbmsc] ...Done Writing [usbmsc_7.img] -> [usbmsc] ...Done Writing [usbmsc_8.img] -> [usbmsc] ...Done Writing [usbmsc_9.img] -> [usbmsc] ...Done Writing [usbmsc_10.img] -> [usbmsc] ...Done Writing [usbmsc_11.img] -> [usbmsc] ...Done Writing [usbmsc_12.img] -> [usbmsc] ...Done Writing [usbmsc_13.img] -> [usbmsc] ...Done Writing [cache_1.img] -> [cache] ...Done Writing [cache_2.img] -> [cache] ...Done Writing [cache_3.img] -> [cache] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [userdata_1.img] -> [userdata] ...Done Writing [userdata_2.img] -> [userdata] ...Done Writing [userdata_3.img] -> [userdata] ...Done Writing [userdata_4.img] -> [userdata] ...Done Writing [userdata_5.img] -> [userdata] ...Done Writing [userdata_6.img] -> [userdata] ...Done Writing [userdata_7.img] -> [userdata] ...Done Writing [userdata_8.img] -> [userdata] ...Done Writing [userdata_9.img] -> [userdata] ...Done Writing [userdata_10.img] -> [userdata] ...Done Writing [userdata_11.img] -> [userdata] ...Done Writing [userdata_12.img] -> [userdata] ...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 3.3 |
11-25-2018, 14:24 | #5639 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | vivo Y51 Pinlock+Frp Code: Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM33) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8916_014]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8916, eMMC, 16 GB LU Count : 1 [0x01D5C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo Y51 [msm8916] Software : LMY47V release-keys, eng.compiler.20180116 [Tue Jan 16 10:41:18 CST 2018] Android Ver. : 5.1.1 Patch Level : 2018-01-01 Preparing Data...Done Formatting Userdata...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 3.3 |
11-25-2018, 14:26 | #5640 (permalink) |
Member: 1039903 Status: Offline Thanks Meter: 2,040 | Xiaomi Redmi 2 Mi Account Reset Done Code: Device : Xiaomi Redmi 2 Operation : Reset Mi Account Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM33) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.7 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1507000 [8916] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8916_014]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8916, eMMC, 8 GB LU Count : 1 [0x00E98000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 16384, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi 2014811 [msm8916] Software : KTU84P, V8.2.1.0.KHJMIDL [Tue Feb 14 18:25:16 CST 2017] Android Ver. : 4.4.4 Patch Level : 2016-10-01 Resetting Mi Account Data...Done Preparing Data...Done Formatting Userdata...Done When phone is completely ON, connect to Internet and add Mi Account. -------------- INFORMATION -------------- New Firmware may cause hang on logo. In such case, you need to flash phone to recover. Or downgrade firmware and try Reset Mi Account again. Operation Finished. QcFire Ver. 3.3 |
