11-20-2018, 06:20 | #5611 (permalink) |
No Life Poster Join Date: May 2007 Location: Indore
Member: 506648 Status: Offline Sonork: 100.1614254 Thanks Meter: 702 | Thanks To UMT Team |
The Following 3 Users Say Thank You to Ankit Verma For This Useful Post: |
11-20-2018, 08:07 | #5612 (permalink) |
Freak Poster Join Date: Nov 2016 Location: ---E-A-R-T-H---
Member: 2650572 Status: Offline Sonork: 100.107126 Thanks Meter: 151 | Samsung G532F ADB FRP Unlock DOne Samsung G532F ADB FRP Unlock DOne Code: Model : G531M Operation : ADB Reset FRP Searching for Device...Found Brand : samsung Model : SM-G532F Product : grandpplte Device : grandpplte Andriod Ver. : 6.0.1 Patch Level : 2017-03-01 PDA : G532FXWU1AQB5 Bootloader : G532FXWU1AQB5 Build ID : MMB29T.G532FXWU1AQB5 Build Date : Tue Feb 28 13:24:33 KST 2017 Checking Root Status...Done Root : No Root Resetting FRP Lock...Done Operation Finished. |
The Following User Says Thank You to monusah25 For This Useful Post: |
11-21-2018, 10:01 | #5614 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | G610F Remove Frp Done BIG BIG BIG THANKS REMOVE FRP ONE CLICK Model : G610F Operation : FRP Reset (Format UD) Searching for Phone...Found Port: : COM373 : SAMSUNG Mobile USB Modem #107 Checking for Device...Found [Normal Mode] Reading Phone Information...OK Model: : SM-G610F IMEI: : 35088XXXXXXXXXX Software: : G610FDDU1BQHA/G610FOJV1BQHA/G610FDDU1BQH5/G610FDDU1BQHA Product : TUR Init Download Mode...OK Waiting for phone in Download Mode...OK Port: : COM357 : SAMSUNG Mobile USB Modem #96 Reading Data from Phone...Done Chipset : LSI7870 [HiSpeed] Loading Data...Done Sending Data...Done Closing Session...Done Operation Finished. Elapsed Time 00:41 Module Ver. 0.1 LOG Saved to !Logs\181121_115254.log |
11-22-2018, 11:35 | #5615 (permalink) |
Freak Poster Join Date: Aug 2017 Location: Ukraine
Member: 2750401 Status: Offline Thanks Meter: 134 | repeir imei lenovo a6020a46 Port : COM137 : Qualcomm HS-USB Diagnostics 9091 (COM137) Baud Rate : 921600 Device : Qualcomm Android Operation : Write IMEI [NV Method] Opening Port... OK Reading Phone Information... OK Compile : May 27 2016 10:20:11 Release : May 18 2016 01:00:00 Hw Ver. : FAAAANUZ Build : MPSS.DPM.2.0.2.c1-00081-M8936FAAAANUZM-1.33522.1.56533.1 IMEI [1] : 899999999999999 IMEI [2] : 000000000000000 Method : NV Method Writing IMEI 1 [351506072885917]... OK New IMEI : 35150607288**** Writing IMEI 2 [351506072885925]... OK New IMEI : 3515060728**** Rebooting Phone... Done Please reboot maunally if does not reboot automatically. Operation Finished. Elapsed Time: 00:03 [Module Ver. 5.2] Log Saved to Logs\181122_092811.log |
The Following User Says Thank You to dimasc For This Useful Post: |
11-22-2018, 11:36 | #5616 (permalink) |
Member: 2750401 Status: Offline Thanks Meter: 134 | Reset FRP Xiaomi Redmi Note 5A [msm8937] Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM100) Driver Info : ZTE Corporation, zghsser.sys, 5.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1600500 [8917] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8917]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8917, eMMC, 16 GB LU Count : 1 [0x01D5A000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 5A [msm8937] Software : N2G47H, V9.6.2.0.NDFMIFD [Tue Aug 7 22:43:57 WIB 2018] Android Ver. : 7.1.2 Patch Level : 2018-07-01 Resetting FRP Lock......Done Operation Finished. |
11-22-2018, 12:15 | #5617 (permalink) |
Registered User Join Date: Feb 2004 Location: morocco Age: 52
Member: 54024 Status: Offline Thanks Meter: 34 | one plus a5010 8.1.0 frp ok Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM105) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1E00500 [8998] DB41702A OPK_DATA : 8EF1BA9BCEF942981995FE1BCAFDD191A636A0590E64C211AD 74CC849534857A Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Loader...Done Sending Loader [8998_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, UFS, 64 GB LU Count : 6 [0x00D7D800] [0x00000400] [0x00000400] [0x00008000] [0x00100000] [0x00060000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK Device : OnePlus Software : , 1808081927 [Wed Aug 8 20:14:14 CST 2018] Android Ver. : 8.1.0 Patch Level : 2018-08-01 Resetting FRP Lock.......Done Operation Finished. |
The Following User Says Thank You to bakkougsm For This Useful Post: |
11-22-2018, 12:17 | #5618 (permalink) |
No Life Poster Join Date: Nov 2016 Location: GUJARAT
Member: 2643730 Status: Offline Thanks Meter: 1,115 | Redmi note 5 frp Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1600400 [8953] 00000000 OPK_DATA : 079E496E26A477B120DFCD85DF7E4AD067164D8292DDD37993 0D5891E3D8240B Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi 5 Plus [msm8953] Software : ZQL1711-vince-build-20180710172756, V9.6.4.0.NEGMIFD [Tue Jul 10 17:27:53 WIB 2018] Android Ver. : 7.1.2 Patch Level : 2018-06-01 Resetting FRP Lock......Done Operation Finished. |
The Following User Says Thank You to djj007 For This Useful Post: |
11-22-2018, 14:35 | #5619 (permalink) |
Member: 506648 Status: Offline Sonork: 100.1614254 Thanks Meter: 702 | Redmi Mi Max 2 Mi Account Removed By UMT Dongle Thanks To UMT Team |
11-22-2018, 14:39 | #5620 (permalink) |
Member: 506648 Status: Offline Sonork: 100.1614254 Thanks Meter: 702 | Xiaomi MD140 Phone Lock | Pattern Lock | Frp Lock Removed by UMT Dongle Thanks To UMT Team |
11-22-2018, 18:51 | #5621 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | Lenovo TB2-X30L FRP reset done Code: Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM378) Driver Info : Huawei Incorporated, qu_usb_serial.sys, 2.1.1.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1009600 [8909] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A26AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [2] Preparing Loader...Done Sending Loader [8909_012]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8909, eMMC, 16 GB LU Count : 1 [0x01D1F000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : LENOVO Lenovo TB2-X30L [msm8909] Software : TB2-X30L_S000031_160720_ROW, TB2-X30L_S000031_160720_ROW [Wed Jul 20 07:37:21 CST 2016] Android Ver. : 5.1.1 Patch Level : 2016-07-01 Resetting FRP Lock......Done Operation Finished. QcFire Ver. 3.3 |
The Following User Says Thank You to technomak For This Useful Post: |
11-22-2018, 20:49 | #5622 (permalink) |
Insane Poster Join Date: May 2018
Member: 2841001 Status: Offline Thanks Meter: 22 | Huawei vns-l21 frp done with umt frp ADB enabled Operation: Generic ADB FRP Reset Searching for Device...Found Brand: HUAWEI Model: HUAWEI VNS-L21 Product: hi6250 Device: HWVNS-H Andriod Ver.: 6.0 Patch Level: 2016-05-01 Bootloader: unknown Build ID: VNS-L21C185B120 Build Date: Tue May 24 04:11:12 CST 2016 Resetting FRP Lock...Done Operation Finished. UltimateFRP Ver. 0.4 Sent from my HTC One_M8 using Tapatalk |
The Following User Says Thank You to Ridhor For This Useful Post: |
11-23-2018, 08:37 | #5623 (permalink) |
Freak Poster Join Date: Apr 2010
Member: 1280685 Status: Offline Thanks Meter: 59 | Samsung Galaxy J5 Prime (SM-G570Y) FRP ON Done UMT Code: Brand : Samsung Model : G570Y Operation : Reset FRP Searching for Phone...Found Port: : COM258 : SAMSUNG Mobile USB Modem #204 Checking for Device...Found [Normal Mode] Reading Phone Information...OK Model: : SM-G570Y IMEI: : 355************ Software: : G570YDXU1BQJ1/G570YOLB1BQJ1/G570YDXU1BQJ1/G570YDXU1BQJ1 Product : XTC Init Download Mode...OK Waiting for phone in Download Mode...OK Port: : COM83 : SAMSUNG Mobile USB Modem #18 Reading Data from Phone...Done Chipset : LSI7570 [HiSpeed] Loading Data...OK Resetting FRP Data...OK Closing Session...Done Wait for phone to turn on completely. goto Menu > Settings > Backup and Reset and do Factory data Reset. Operation Finished. UltimateFRP Ver. 0.4 |
The Following User Says Thank You to @ndoy For This Useful Post: |
11-23-2018, 10:31 | #5624 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | Casper Via V8C Imei Repair Done Operation : IMEI Reapir [META (Old)] Checking for existing META ports... No existing META port found. Connect powered off phone... Found MediaTek PreLoader USB VCOM (Android) (COM255) on COM255 Device Path : \\?\usb#vid_0e8d&pid_2000#6&17fa971a&0&3#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Rebooting to META mode... Waiting for phone in META mode... Found USB Serial Device (COM360) on COM360 Device Path : \\?\usb#vid_0bb4&pid_0005#6&17fa971a&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Reading Phone Information... CPU: MT6592, E00 SW Ver.: MOLY.WR8.W1315.MD.WG.MP.V34.P1 Hw Ver.: TINNO92_WET_KK_HSPA_HW Reading Data.... Repairing IMEI[1] to 3559XXXXXXXXX.... Repair success |
The Following 2 Users Say Thank You to orhan5 For This Useful Post: |
11-23-2018, 14:43 | #5625 (permalink) |
Junior Member Join Date: Jun 2011 Location: DHANIAKHALI.WEST BENGAL
Member: 1590413 Status: Offline Thanks Meter: 8 | Samsung A6 plus frp unlock done Device: SM-A605G Operation: Reset FRP Searching for Device... Found Model: SM-A605G Baseband: A605GDXU3ARJ1 Bootloader: A605GDXU3ARJ1 PDA: FA80_A605GDXU3ARJ1 Android Version: 8.0.0 Resetting FRP Lock... Done ---------------- IMPORTANT ---------------- Accept Agreement on phone to enter Home Screen. Goto Menu > Settings > Backup and Reset > Factory data reset. Operation Finished. Elapsed Time: 00:08 [Ultimate Samsung Flasher v1.4] |
The Following User Says Thank You to bangla bandhu For This Useful Post: |
